Advertise on Bikeforums.net
Results 1 to 22 of 22
  1. #1
    I was poisoned! dstrong's Avatar
    Join Date
    Aug 2005
    Location
    Awesome, Austin, TX
    Posts
    3,529
    Wow...does that stuff stink up the house!!!
    We have a slow running shower drain so I went to our local hardware store and asked for a recommendation. He grabbed a bottle off the shelf and told me it works the best but it smells pretty bad. What an understatement. The bottle is labeled as "Virgin Sulfuric Acid". It states that while the product itself doesn't have an odor, the smell it generates when mixed with organic materials can be quite strong. The instructions are to pour in 8 oz, let sit for 15 minutes then flush with cold water for 5 minutes.
    I poured it in, turned on the exhaust fan, closed the door and set the timer for 15 minutes. 10 minutes later, my wife came out of the bedroom and said "Wow...that stuff really stinks!". 5 minutes later we opened the door and literally, were almost knocked over by the fumes. Full on rotten eggs/sewage at an eye watering level. My wife immediately bolted for the downstairs and discovered that through the connectivity of plumbing, the fumes had spread throughout the house. I got the flush going and started flushing toilets and running water in sinks, hoping to get the odor moving out of the house. All the windows are open, fans are on and the "scent" still lingers. My wife is still outside an hour later!
    Good times!
    Hopefully the drain is running faster.
    2003 Interloc Impala2003 Interloc Impala2007 ParkPre Image C62003 Interloc Impala2004 Specialized Rockhopper
  2. #2
    You Know!? For Kids! jsharr's Avatar
    Join Date
    Apr 2005
    Location
    Just NW of Richardson Bike Mart
    Posts
    5,626
    I would rent a snake and just run that through the drains. Your pipes are most likely clogged with human hair. Have to do mine pretty often, or i did until I started using a surface strainer to trap hair before it got in the drain.
    Are you a registered member? Why not? Click here to register. It's free and only takes 27 seconds! Help out the forums, abide by our community guidelines.
    Quote Originally Posted by colorider View Post
    Phobias are for irrational fears. Fear of junk ripping badgers is perfectly rational. Those things are nasty.
  3. #3
    Join Date
    Sep 2007
    Posts
    844
    Quote Originally Posted by dstrong View Post
    Good times!
    Could it be that there is a small leak in your drain / soil pipes somewhere, and what you're smelling is something still reacting with the acid, which wasn't washed into the sewer when you did the cold water rinse?
  4. #4
    Senior Member himespau's Avatar
    Join Date
    Jun 2008
    Location
    Louisville, KY
    Posts
    6,154
    Hmmm, I'm more familiar with sulfuric acid burning the insides of my nose than stinking, but then I'd guess the stuff I use is rather higher concentration in the lab than the stuff they'd let you pour down drains. We have a snake we use on the toilet here (I find it more effective than a plunger - I save that for the garbage disposal -, but you have to be careful not to scratch the porcelain), I'd guess you need a smaller one to do the shower pipes.
    Punctuation is important. It's the difference between "I helped my uncle, Jack, off a horse" and "I helped my uncle Jack off a horse"
  5. #5
    Mythic Member ahsposo's Avatar
    Join Date
    Jan 2010
    Location
    Beyond Space & Time
    Posts
    6,166
    Oh! Cool! I'll have to try this next time I'm sent on drain patrol.
    That'll put a stop to that.
    Quote Originally Posted by 20grit View Post
    I want this to be someone's sig.
  6. #6
    Join Date
    Jul 2006
    Posts
    3,569
    How did a human wind up down his shower drain?
  7. #7
    Join Date
    Jun 2008
    Location
    Rochester MN
    Posts
    682
    Quote Originally Posted by spry View Post
    In small pieces. Somebody was really ticked of at that guy.
    We have met the enemy and they is us.
    Pogo
  8. #8
    Refrigerator Raider Hater fordmanvt's Avatar
    Join Date
    Aug 2008
    Location
    Barre, VT
    Posts
    822
    The smell shouldn't have spread through the pipes, that is what traps and vents are for.
  9. #9
    Database Error mikeybikes's Avatar
    Join Date
    May 2009
    Location
    Edgewater, CO
    Posts
    2,875
    Quote Originally Posted by fordmanvt View Post
    This.
    My Bikes: 2009 Breezer Uptown EX | 1980 Miyata Six Ten | 1970 Hercules Three-Two-Speed
    Wife's Bikes: 2008 Globe City 7 | 1972ish Peugeot UO-18 (in progress)
  10. #10
    Join Date
    Jan 2010
    Location
    Beyond Space & Time
    Posts
    6,166
    Quote Originally Posted by mikeybikes View Post
    This.
    Damn.
    My house's pipes and vents are good.
    What should I do now?
  11. #11
    Pedaled too far. Artkansas's Avatar
    Join Date
    Oct 2005
    Location
    La Petite Roche
    Posts
    11,049
    Quote Originally Posted by ahsposo View Post
    Damn. My house's pipes and vents are good. What should I do now?
    You could cut up a wig and wash that down the tub. That should give you a good start.
    "When you strip it all away, there is only God." - George Harrison
    On giving up:
    Everyone knows that Christopher Columbus discovered the New World for Spain on his first voyage. But few people realize that on his 4th voyage, Columbus gave up, turned back and sailed for home; within 10 miles of where he could have discovered the Pacific Ocean.
  12. #12
    on by skijor's Avatar
    Join Date
    Mar 2006
    Location
    Wisconsin
    Posts
    856
    Have you exercised the gaskets?
  13. #13
    Join Date
    Jul 2006
    Location
    Middle of the road, NJ
    Posts
    1,719
    Quote Originally Posted by jsharr View Post
    +1
    Unless your pipes are really rotten, this is the safest way to clean them.
    But it can be messy, and the stuff you pull up will be quite disgusting.
  14. #14
    Senior Member ModoVincere's Avatar
    Join Date
    Aug 2006
    Posts
    1,634
    Damn.
    Fill the old pipes with cement to contain the issue.....then re plumb the entire house.
    Quote Originally Posted by Cyclaholic View Post
    You just haven't been here in P&R all that long, believe me it gets far stupider than this sometimes. :D
  15. #15
    Senior Member bikebuddha's Avatar
    Join Date
    Oct 2003
    Location
    Concord TN for Now
    Posts
    1,131
    I thought this was going to be a thread about kimchi.
    The few, the proud, the likely insane, Metro-Atlanta bicycle commuters.
  16. #16
    Join Date
    May 2009
    Location
    Edgewater, CO
    Posts
    2,875
    Quote Originally Posted by leob1 View Post
    +1
    Hehe. The plumbers came and snaked out our bath tub drain line and destroyed the lead drain pipes in the crawl space. Fortunately, we rent, so the landlord got to pay to replace the lead pipes they destroyed with their snake.
  17. #17
    Join Date
    Apr 2005
    Location
    Posts
    5,626
    Wow, must be a relatively old house. Lead presents a challenge that I did not consider. Our house is black iron drain pipes.
  18. #18
    Join Date
    Apr 2005
    Location
    Posts
    5,626
    BTW, the smell most likely spread through your air ducts, not your plumbing, just so you know.
  19. #19
    Join Date
    May 2009
    Location
    Edgewater, CO
    Posts
    2,875
    Built in 1947. I thought by then they would have switched to something else, but it definitely had and still has some lead drain pipes. Also, the water main is still lead.
  20. #20
    Join Date
    Aug 2005
    Location
    Awesome, Austin, TX
    Posts
    3,529
    This is actually the second go around with this stuff. The first was a few weeks ago with my daughter's shower drain. The stinky stuff did not do the job and we ended up calling a company to come snake it out...they pulled up a pretty nasty clump of hair.
    +1
    I'm thinking of investing in a small, powered snake. I have two manual snakes but it's impossible to get them past the p-traps on the showers. All the other places you'd want to snake (sinks and toilets) you can get around the p-traps (remove the toilet or disconnect under the sink) but you can't get to shower p-traps unless you want to take the house apart or dig up the slab.
    Prolly...this was an upstairs shower so the smell likely "settled" throughout the house and depending on whether the A/C was running at the time, may have gone into the ducts for distribution.
    The good news is that the shower drain did just fine when I showered after my run last night.
  21. #21
    Join Date
    Jul 2006
    Location
    Posts
    1,719
    It can be done with a manual snake. The trick is to push and twist at the same time. Only try to push it in an inch or so at a time. You'll feel it when it's past the trap, which is usually where a hair clog will be. Plus you have much less of a chance of flinging the stuff around the room. Did I mention, the stuff that come out is nasty, nasty, nasty.
    For a toilet, get a toilet auger. No need to take anything apart.
  22. #22
    Join Date
    Apr 2005
    Location
    Posts
    5,626
    Toilet augers rock.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
