Advertise on Bikeforums.net
Results 1 to 10 of 10
  1. #1
    Join Date
    Dec 2007
    Location
    WI
    Posts
    91
    Late 80s early 90s Nishiki Tri-A: What's Stock?
    I'm going to be picking up this Tri-A tomorrow and was wondering if anyone one knew what was stock on these. Brakes, levers, drive train, and cranks are all Suntour GPX which I assume is definitely stock. What I'm most curious about is the saddle, pedals, and stem. These pedals look to be crap and definitely a late entry, saddle is Specialized and also not original. I'm also suspicious of the stem, as one does not often see a riser on a racing frame. Does anyone know what was original to this model? I always like to bring'em back to factory settings....
    Over in the "what's it worth," someone suggested this was a 1989, any confirmation on this would be great too.
  2. #2
    Senior Member mikemowbz's Avatar
    Join Date
    Aug 2011
    Location
    Vancouver, BC
    Posts
    702
    Too bad about the pedals not matching the rest of the group - I just picked up some GPX pedals, which are really cool, very big platform and take toe clips very nicely. What are the ones on there? Look a bit like MKS AR-2s (which are quite decent), but a lot of pedals look like that.
    You can see what the GPX pedals look like in this scan from the catalogue entry on the GPX group (which may be of some interest to you generally):
    http://equusbicycle.com/bike/suntour...GPX-page-2.jpg
    Saddle looks newer to me, but I really don't know. Ditto for the stem. But I'm sure others have ideas...
  3. #3
    Senior Member Andycapp's Avatar
    Join Date
    Aug 2011
    Location
    Puyallup, WA
    Posts
    449
    I have an '87 Tri-A 'equipe'. It's came stock with Shimano 600 and Sante' shifters and derailleurs. The non 'equipe' model this year was full 600. Unlike yours mine has lugs all around. A buddy of mine has an '89 Nishiki International with the same frame as yours with the mono seat-stay and fillet-brazed construction. His also came with Suntour GPX components and says 'Performance Equipe' on the down tube. I'll check what stem he has next time I see him. My bike came with a stem (pretty sure it's a re-branded SR, I'll check when I get home) that has an "N" on the front like this-
    You should be able to determine the year using the date code on you components. Look for two letters on the back side of your rear derailleur and look it up here - http://www.vintage-trek.com/component_dates.htm
    As far as the saddle goes, I have no idea what would have been stock, but I'd go with something 'period' and comfy as this was/is the first thing we change for personal preference anyway.
    -Andy
  4. #4
    Bianchi Goddess Bianchigirll's Avatar
    Join Date
    Apr 2009
    Location
    Somewhere within 175 miles of Harrisburg PA.
    Posts
    17,957
    Bianchis '87 Sport SX, '90 Proto (2), '91 Boarala 'cross, '93 Project 3, '88 Trofeo, '86 Volpe, '89 Axis, '79 Mixte, '99 Mega Pro XL Ti, '97 Ti Megatube, , '90 something Vento 603, 87 Mondiale for sale, '88 Grizzly sold
    Others but still loved,; '80 RIGI, '80 Batavus Professional, '87 Cornelo, '86 Bertoni (sold), '09 Motobecane SS, '98 Hetchins M.O., '09 K2 Mainframe, '9? Univega Rover 304 Sold , '89 Trek 2000, '?? Jane Doe (still on the drawing board)
  5. #5
    Bike Junkie roccobike's Avatar
    Join Date
    Jun 2005
    Location
    South of Raleigh, North of New Hill, West of Harris Lake, NC
    Posts
    8,615
    I have very little information specific to 1989. However, although the Tri-A was not available in 1988, I can tell you that in 1988, that level Nishiki would have had a "Vetta Racing" saddle. In 2001, the Vetta Gel was found on all the mid and upper level road and MTBs. It's a good bet that if you put a Vetta on there, it will look original. White or Black, either will do, but white is REALLY hard to find.
    Edit: No way that's the original stem.
    Roccobike BF Official Thread Terminator
  6. #6
    Join Date
    Dec 2007
    Location
    WI
    Posts
    91
    Bianchigirll - I'm going to have to figure out how to size my own photos so you stop having to do it for me....
    I'll check those numbers on the rear derailleur. I also think that even if they weren't stock, getting a pair of the GPX pedals would round out the components into the full group nicely. But, it would still be nice if the pedals on there aren't complete junk so I can use them elsewhere.
    Andycapp - That would be great! I figured this stem was definitely an add-on, and an SR would make sense, but I thought Nitto, 3t, or Cinelli were also a possibilities.
  7. #7
    Join Date
    Dec 2007
    Location
    WI
    Posts
    91
    So, the derailleurs are stamped "EG" for July 1988, making this either a 1988 or 1989, if roccobike is correct in that they didn't offer a Tri-A in 1988, then it is definitely a 1989.
    One more question. If I was to replace the brake lever hoods, what model of the currently available replacement hoods would fit? Can I make due with any of the Hudz stuff, for example, or will this not work?
  8. #8
    Join Date
    Aug 2011
    Location
    Puyallup, WA
    Posts
    449
    Sorry for the short notice, but here's you stem - http://www.ebay.com/itm/Nishiki-Badg...#ht_500wt_1413
  9. #9
    I blame you. RobbieTunes's Avatar
    Join Date
    Dec 2007
    Location
    NC Coastal Plain.
    Posts
    13,523
    No modern hoods are exact fits, and Shimano's aren't as close as the Dia Compe aero hoods.
    A little trimming with a razor knife may work out just fine. If the hoods are black and just faded, consider dyeing them.
    Robbie ♪♫♪...☻
    You will not believe how fast I used to be...
    84 Simoncini SLX
    85 Cinelli Equipe Centurion
    85 Centurion Ironman
    85 Eddy Merckx Corsa Extra
    88 Schwinn Paramount
    91 Cannondale SC800
    95 Hot Tubes TT
    98 Trek Y Foil
    98 Giant MCR
    08 Cannondale Six13
  10. #10
    Join Date
    Dec 2007
    Location
    WI
    Posts
    91
    Crap.....totally missed that stem Andycapp, thanks for the heads up though. Oh well, the wife seems to like the riser, so for now, I suppose I'll let her use it...
    The hoods are servicable, I think I might take a little cleaner to them to get some of the sticky off, but no major rips or tears, so hopefully they'll last a bit.
    Went with a pair of matching GPX pedals.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
