Advertise on Bikeforums.net
Results 1 to 12 of 12
  1. #1
    everyday I'm hustlin' brandonspeck's Avatar
    Join Date
    Aug 2008
    Location
    Portland, OR
    My Bikes
    Surly Crosscheck, Surly Steamrolla
    Posts
    453
    Surly LHT fork on a Mountain Bike frame?
    Hey folks-
    I'm curious about using a non suspension corrected Surly LHT fork (one for the 26 inch) on a newer steel mountain frame (Soma Groove) that has geometry for a 80mm suspension fork. It's mostly been my mountain bike, and winter commuter, but I'm wanting to turn it into a touring bike, and I'm curious which rigid fork to buy. I was thinking the 1x1, but I prefer the mid blade eyelets for a lowrider.
    Will using a non-suspension corrected fork like the LHT on a mountain frame totally ruin the handling? Would it be better or worse for touring?
    "I think it’s dumb when you take the inherently fun like riding bikes and singing songs and say they’re not for everyone as if for your whole life you were cool as $h!t."
    -Bomb the Music Industry!
  2. #2
    Senior Member Thor29's Avatar
    Join Date
    Aug 2005
    Posts
    757
    That would be a horrible idea. A shorter fork will cause the handling to be twitchy, which is not something you want when fully loaded. Soma has a rigid fork that is made for the Groove or you could get the Surly Troll fork which has the eyelets. The Troll was designed for a 100mm suspension fork, so it might cause the handling to be a little slower and will raise the bottom bracket, but that's better than going the other direction. Skinnier tires would help to mitigate the issue a little bit. Better yet, just buy an Old Man Mountain rack and keep the fork you already have.
  3. #3
    Senior Member rockpilex's Avatar
    Join Date
    May 2006
    Location
    Whitefish, MT
    My Bikes
    TREK 520, CANNONDALE R800 FIXED, 1954 SCHWINN TIGER, 1963 SPACELINER
    Posts
    83
    Kona sells the Kona Project 2-26 inch forks in two axle crown lengths 410mm and 440mm This fork has eyelets at the dropout but not at mid fork. You can use p-clips as a mid blade mounting point here is tech instructions from Jandd on how to mount them http://www.jandd.com/Technotes/technotes_front_rack.asp
  4. #4
    coprolite fietsbob's Avatar
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    My Bikes
    7
    Posts
    26,334
    Suspension correction is about blade length, so the head tube will not be lowered,
    changing the steering geometry.
    So you need to match the fork crown race seat to axle distance with in a few cm.
    there is some sag when you get on the bike from your weight, on the suspension fork,
    so an inch shorter is probably close to design..
  5. #5
    Have bike, will travel Barrettscv's Avatar
    Join Date
    Feb 2006
    Location
    Windy City
    My Bikes
    A road bike for every purpose
    Posts
    7,315
    Get the 1X1 Surly fork and forget about using a LHT fork: http://surlybikes.com/parts/1x1_fork
    Just use P clamps to install your front rack.
    2012 Pedal Force CG2: "Secolo Bicicletta"
    2012 Pedal Force CX2: "Carbone CX" the carbon fiber Cyclocross bike
    2010 Origin 8 CX 700: "Servizio Grave" Monstercross/29er bike for severe duty
    1983 Trek 970: "Columbo" the Columbus SP steel road racing Trek.
    1985-ish Serotta Nova Special X: A Columbus SPX steel road racing bike
  6. #6
    Join Date
    Jul 2011
    Posts
    988
    If 453 mm works for your frame:
    http://www.nashbar.com/bikes/Product...0052_174928_-1
    I'd order one. Be sure wherever you order whatever from, you can return it cheaply. Then check it for straightness when you get it.
  7. #7
    Join Date
    Apr 2011
    Posts
    89
    Quote Originally Posted by Barrettscv View Post
    Hi Barrettscv
    Curious as to this recommendation as opposed to the Troll fork with all the bolt on ability?
  8. #8
    Join Date
    Feb 2006
    Location
    Windy City
    My Bikes
    Posts
    7,315
    Quote Originally Posted by rifraf View Post
    Hi Barrettscv
    After reviewing the post, I agree that the Troll fork would provide more rack options.
  9. #9
    __________ seeker333's Avatar
    Join Date
    Feb 2004
    Posts
    2,551
    From FAQ at
    http://www.somafab.com/archives/product/groove
    "Hardtail geometry is based on a 440mm fork (approximately 80mm travel fork)".
    430-450mm should do fine.
    This is close:
    http://classic.aebike.com/product/su...k0098-qc30.htm
    OIC now it is already mentioned.
  10. #10
    Senior Member clasher's Avatar
    Join Date
    May 2009
    Location
    Kitchener, ONT
    Posts
    1,345
    The tubus adapters for front forks are really well designed in my opinion. I've seen perfectly fine touring done with u-bolts holding the front rack on the forks. Since you're in Portland there must be a neighbourhood frame builder or two you can get to put eyelets into the fork.
  11. #11
    Senior Member Medic Zero's Avatar
    Join Date
    Apr 2011
    Location
    Seattle
    My Bikes
    Old steel GT's, for touring and commuting
    Posts
    969
    Here's my notes from when I was researching replacing a Rockshox 21R on a GT Pantera for my girlfriends new commuter build:
    (IIRC, I measured it at 430mm, and it was an 80mm travel fork, but I could be mis-remembering, 440mm seems to be a common replacement size for this, but as noted there are 453mm forks available as well.)
    Kona Project 2: 60-70$, ugly?, eyelets, crown hole, no disc tabs, 440mm, 1040g/813g(triple butted)
    disc tabbed http://www.cycle-solutions.com/Project-2-26-P4797.aspx
    http://www.cambriabike.com/shopexd.asp?ID=87429
    http://www.bikeman.com/KON-P2MTN440.html
    IRD MTB CrMo Canti rigid 26" 440mm fork
    96$ IRD 440, 40mm rake, black, unicrown, 907g, eyelets,
    http://www.speedgoat.com/Catalog.asp...116&Prod=22806
    $103 for Soma, canti, 40mm rake, 440mm length,
    http://www.niagaracycle.com/product_...ucts_id=802955
    http://store.somafab.com/socrmtbfoca.html
    One One Inbred fork is 440mm.
    Van Nicholas VNT TRX Alloy MTB Fork is only 420mm
    IndyFab no-Travel fork is 430mm for 80mm fork replacement.
    She doesn't really ride in foul weather, so I have yet to tackle the MTB conversion build, I've still got my fingers crossed that the fork I picked up will end up matching correctly, given I had to guess at how much it compresses usually. I'll dig it out of that parts box tomorrow and post which one I chose. I want to say it was the IRD, which it doesn't look like they are offering right now, but could probably be tracked down somewhere.
    EDIT: Yeah, this was the fork I got --> IRD MTB CrMo Canti Fork Black, 1-1/8" Threadless, Cantilever, 26", 440mm fork, 40mm rake, black, unicrown, 907g, eyelets, 96$
    I might have some more notes in an earlier draft of my research for her bike that I edited out as I narrowed down my search. If I come across those, I'll post them up too. Hope this helps!
    Here is some errata from my research, quotes from sources all over the internet that I was using to inform my decision:
    " Kona and Surly forks are too short at 410mm, unless you want crazy twitchy handling. Vicious and Salsa are the only two currently available that (I know of that) are the correct lenght 425mm (or so). "
    " Surly 1x1 100mm for is 453mm long which would make the HT angle about 1 degree more slack, one set of eyelets, rim brake mounts, the disc caliper mount, and the line guides but it is corrected for frames designed for 100mm suspension forks. Straight blade."
    " The 21 R uses the Mag fork brace, MCU spring, SL crown to give 60mm of travel while weighing in at 3.0 lb. "
    And a note to myself about forks I found that I coveted, but were too rich for my blood:
    Vicious Cycles forks are very expensive i.e 275+15 for fender tabs + 60 $ for low rider rack mounts, Straight blade.
    All that said, I wish I knew about the Troll fork when I purchased the IRD. The Troll has mid fork eyelets and double eyelets down low, making it easy to mount both fenders and a variety of racks, and cleanly at that. Myself, I'd be tempted to cut off the disc tabs and repaint it, but then again, I'll probably experiment with discs up front at some point on one of our rigs.
    Tail winds and sunshine to you all!
  12. #12
    Join Date
    Apr 2011
    Location
    Seattle
    My Bikes
    Posts
    969
    Quote Originally Posted by clasher View Post
    I attached the Nitto Big Front Rack to an old mountain bike ('93 GT Outpost) with homemade P clamps out of aluminum stock bent to fit because the P clamps that came with it were a little small. It's holding on like a champ and I've had two large Ortlieb panniers filled to the brim with books hang off it for an 8 mile hilly ride home from work. P clamps are definitely a viable solution.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
