On my way back home, my Edge would not count distance. Lifting the rear wheel and pedaling forward, it outputs both speed and cadence, so it's something else. While riding, both cadence and speed show, but distance wouldn't accrue. I've turned it on/off, started/stopped, the lap button, and reset it several times. Eventually I went into History/Activities and had it read the data. After that, it started counting distance after pressing start. I've had this problem before a few times, but I never had to spend 15 minutes fiddling with it get it back to working. Capacity wise the data used is only 1/4 full, so what's going on?
Also my top right start/stop button is squishy. It's starting to crack. Naturally, it uses polydrive or line screws or whatever they are which I don't have the tool for.
