Can I patch a patch?
Old 05-04-12 | 10:46 AM
When inspecting the tube, I noticed a bubble around the extreme edge of a previously patched area. I fiddled with it which revealed a hole there.
Rimmer is offline
Reply
Old 05-04-12 | 10:55 AM
Bikes: 8
Poor patch technique , peel it off and do it over, more surface prep ..
fietsbob is offline
Reply
Old 05-04-12 | 10:58 AM
DiabloScott's Avatar
It's MY mountain
15 Anniversary
Bikes: Klein, Merckx, Trek
You can patch a patch, the success probablity is a little lower than a virgin puncture.
DiabloScott is offline
Reply
Old 05-04-12 | 11:12 AM
puchfinnland's Avatar
MIKE is my name!
10 Anniversary
Bikes: hans lutz, , puch mistral ultima,2x Austro Daimler Smoked chrome Ultima,Austro Daimler Mixte,Austro Daimler 531 mixte, flying arrow,F Moser,
Originally Posted by DiabloScott
a virgin puncture.
is that possible???
I had a vespa inner tube with no less then 16 patches in it, but I agree to take off the ols patch and do it over- try asetone to loosen the old glue-wear gloves
puchfinnland is offline
Reply
Old 05-04-12 | 11:19 AM
WonderMonkey's Avatar
Bikes: 2011 Cannondale Quick 5, 2014 Raleigh Revenio 2.0
Originally Posted by puchfinnland
is that possible???
ha!
WonderMonkey is offline
Reply
Old 05-04-12 | 11:27 AM
Thanks, I'll keep it as a spare. I used another tube with a couple patches already on it. It had a weird bulge when I inflated it, but it seems to work fine mounted with tire on.
Rimmer is offline
Reply
Old 05-04-12 | 12:38 PM
IthaDan's Avatar
Bikes: Click on the #YOLO
Can you find $5 in your couch cushions?
IthaDan is offline
Reply
Old 05-04-12 | 01:06 PM
Titanium Club Membership
10 Anniversary
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
This....
That said I have successfully patched over a patch.
Sir Mark, Knight of Sufferlandria
Black wallnut is offline
Reply
Old 05-05-12 | 08:50 AM
No, I didn't.
Rimmer is offline
Reply
Old 05-05-12 | 09:18 AM
Heating the patch will make it easy to remove. I use an old knife I found on the road and heat it on my gas range.
davidad is offline
Reply
Old 05-05-12 | 09:45 AM
Guest
15 Anniversary
Bikes: I never learned to ride a bike. It is my deepest shame.
If you have a punctured inner tube and a patch kit, a new tube would be a waste of money.
You can patch over a patch, but if the problem is a failed patch, try to remove the old one and start anew. If you can easily peel off the old patch it wasn't done very well in the first place.
LarDasse74 is offline
Reply
Old 05-05-12 | 09:53 AM
10 Wheels's Avatar
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
yep:
Fred "The Real Fred"
10 Wheels is offline
Reply
Old 05-05-12 | 01:53 PM
MIKE is my name!
10 Anniversary
last time I went to the store the bloody patch kit costs more then a new tube!
how many patches in this tube??
Reply
Old 05-05-12 | 02:41 PM
Guest
15 Anniversary
Great work on being frugal, everybody!
For the record, I would estimate it takes about 10 minutes extra to patch a tube compared to installing a brand new one, provided you have a brand new one on hand.
I would guess you can patch at least 5 punctures with a single $4 patch kit - that works out to $0.80 per puncture. But, in spending the extra 10 minutes, you have avoided spending $5 on a new tube, for a new savings of $4.20 per puncture. Considering it only took an extra 10 minutes, you are actually earning $4.20 / 1/6 hour = $25.20 / hour... so patching instead of buying new is like having a part time job making $25/ hour!
And for you patching aficionados who shuddered when I suggested you only get 5 repairs from a patch kit, if you manage to get 10 repairs from a patch kit, you make $50.50/hour, and if you can squeeze 15 repairs out of a kit, $75.60/hour!
I don't know about you guys, but I am going to go for a ride right now and try to get a flat tire!
Reply
Old 05-05-12 | 04:02 PM
I bought 100 patches for less than $17 way back. That comes out to less than 17 cents per patch. So yeah... I might as well use them.
Rimmer is offline
Reply
Old 05-05-12 | 04:09 PM
Retro Grouch's Avatar
20 Anniversary
I don't patch over patches. When they get to where the patches overlap, I give up on the tube. Aside from that I'll patch the same tube any number of times. I've never had a patch leak either.
I haven't tried it in awhile, but I've never successfully removed one of my patches either. I follow the directions on the patch kit including waiting 5 minutes for the glue to dry before installing the patch. I don't think I could get one off without tearing a big hole in the tube.
Retro Grouch is offline
Reply
Old 05-05-12 | 04:10 PM
20 Anniversary
Bulk patches are fine but what do you use for glue?
Reply
Old 05-05-12 | 04:12 PM
Easy, I bought a 10g tube of vulcanizing fluid. That was less than $3. FYI, I didn't want too big of a tube, because it may dry out.
Rimmer is offline
Reply
Old 05-05-12 | 04:16 PM
20 Anniversary
My thoughts exactly.
Reply
Old 05-05-12 | 04:18 PM
Shimagnolo's Avatar
I tried *once* to patch a hole so close to an existing patch that I had to overlap the patches.
So when did it decide to leak?
In the winter, while descending Flagstaff Mt.
So there I was, with my fingers frozen numb, standing in a snowbank by the road trying to fix a flat.
The air was escaping under the new patch, right along the edge of the old patch.
Never again.
Shimagnolo is offline
Reply
Gresp15C
Bicycle Mechanics
26
11-02-14 10:27 PM
IknowURider
Bicycle Mechanics
25
04-04-14 06:28 PM
djb
Bicycle Mechanics
26
02-07-14 02:05 PM
OldBlueJeans
Bicycle Mechanics
55
09-09-12 02:16 AM
work4bike
Bicycle Mechanics
19
09-19-11 08:03 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
