Advertise on Bikeforums.net
Results 1 to 3 of 3
  1. #1
    Join Date
    May 2012
    Posts
    2
    Rubber sealed vs metal sealed hub
    Hi,
    I have recently bought new rear freehub Shimano Deore for disc breaks as replacement for stock Author freehub not with disc mounting.
    But that Shimano's hub hasn't rubber seal as Author's has, but it has some metal seal ring instead.
    My question is: Is that significant difference between rubber seal and metal ring seal? Why is it still on the market, since I saw that almost every hub sold today has rubber sealing?
    Specs of mentioned hub: http://techdocs.shimano.com/media/te...525-A-3287.pdf
    Thanks in advance.
  2. #2
    Join Date
    May 2012
    Posts
    2
    Maybe simpler question:
    What difference is between Shimano FH-M525A and FH-M525? There is different sealing, but what is better?
  3. #3
    Senior Member Mr. Fly's Avatar
    Join Date
    Jan 2007
    Location
    Silicon Valley, CA.
    Posts
    639
    All Shimano hubs I've seen use a labyrinth seal design. The parts that protect against bearing contamination are actually the (metal/rubber) parts that present a non-direct path for contaminants. It's not the material but the design that should interest you, and in this respect, Shimano delivers. Unless you submerge and run the hub in water, labyrinth seals are allegedly better than those rubber covers on cartridge bearings (that I presume is what you refer to as "rubber sealing").
Posting Permissions
  • You may not post replies
  • You may not edit your posts
