Advertise on Bikeforums.net
Results 1 to 15 of 15
  1. #1
    Join Date
    May 2012
    Posts
    3
    replacing tires on old bikes
    Hi all,
    I just bought a schwinn suburban from the late 70s off craigslist. It's in pretty good shape mechanically, but the tires are in pretty bad shape. You can see through the rubber on the sidewall in one spot on the front tire, the sidewalls of both tires are pretty cracked. I have a couple questions--
    -do I need to replace the rear tire if it's just cracked? Most of what I'm finding is saying not necessarily, but since the front tire is in such bad shape and I think they're probably the original (30 year old) tires, it seems like probably I do in this case?
    -assuming they are also 30 years old, should I replace the tubes as well, or are they okay if they hold air?
    -am I taking my life into my hands if I ride it around the neighborhood this afternoon before I replace that front tire at the very least?
  2. #2
    Thrifty Bill wrk101's Avatar
    Join Date
    Jan 2008
    Location
    The NC Mountains
    Posts
    17,274
    Would you drive a car with 30 year old tires? And replacement tires, depending on your car, might cost $100 each, probably more (my last set of tires on my pickup cost me $700). Well, on a bicycle, a decent tire might cost $15 each, and you only need two, for a $30 investment.
    Myself, I don't try to squeeze the last bit of life out of a tire, whether it is my pickup, one of my bicycles, or one of my motorcycles. Its up to you.
    Realize a tire failure on a two wheel vehicle can be a lot more serious than a tire failure on a four wheel vehicle (don't need to balance a four wheel vehicle). And a failure of a front tire can be the most serious.
  3. #3
    Senior Member echo's Avatar
    Join Date
    Jul 2007
    Location
    Washington State
    Posts
    530
    Be sure to replace the rim strips and tubes to.
    "After all is said and done, a hell lot of a lot more is said than done."
  4. #4
    Senior Member randyjawa's Avatar
    Join Date
    Apr 2007
    Location
    Thunder Bay, Ontario, Canada - burrrrr!
    Posts
    5,456
    Replace the tires, inner tubes and rim liners. Use modern rim liners, not those soft rubber ones common on old Ten Speeds.
    You just might get lots of miles out of an old set of hoop huggers, but then again, you might not. My Peugeot PX10, on its test ride, created a small mushroom cloud when the rear tire blew, and I do mean blew!
    In fact, if I would have been clenching a piece of coal between my two gluteus maximus muscles, that piece of coal would have instantly turned into a diamond, at the loud kapow I heard just before my bicycle started to dance a little bit...
    If that had happened on the front wheel, I might have crashed the bicycle.
    Get the tires or learn how to carry pieces of coal. Best advice I can offer.
    Learn how to find, restore and maintain vintage road bicycles at... MY "TEN SPEEDS"
  5. #5
    Join Date
    Mar 2006
    Location
    NYC
    Posts
    65
    If your going pretty fast, a Front tire pop can result in a fall. I don't worry much about my rear tire too much, but the front is a different story.
  6. #6
    Senior Member Mort Canard's Avatar
    Join Date
    Oct 2011
    Location
    Kansas
    Posts
    622
    You can try a jaunt around the block with the old tires but if you are going to keep this bike and be riding this bike in traffic, I would get new tires as soon as possible.
    The old tires could give out and leave you having to walk several miles home, or spit you off in any number of traffic situations.
    Kinky Friedman for President!
    "The future's all yours, you lousy bicycles" Butch Cassidy
    57 years strange!
  7. #7
    Join Date
    May 2011
    Posts
    317
    +1 what Mort says.
  8. #8
    Senior Member catonec's Avatar
    Join Date
    Apr 2009
    Location
    burlington VT.
    Posts
    1,596
    change the tires and tubes. dont buy them used off craigs list.
    2010 Kestrel RT900SL, 800k carbon, chorus/record, speedplay, zonda
    2005 Lemond Tourmalet, 6066 w/carbon fork, 105/ultegra, bontrager select
    1997 Trek ZX6000, 6061w/manitou spyder, xt/xtr, time atac
  9. #9
    Join Date
    Mar 2012
    Location
    NE oHIo
    Posts
    131
    Glad to see some posts sticking up for the right thing to do.
    If the bike was some sort of museum piece and needed to be original and NEVER ridden then those old tires would stay on. Since this isnt the case, do it right so you can ride reliably and safely.
    -SP
  10. #10
    Bike Junkie roccobike's Avatar
    Join Date
    Jun 2005
    Location
    South of Raleigh, North of New Hill, West of Harris Lake, NC
    Posts
    8,617
    Old tires with cracks are a failure waiting to happen. As for old tubes, I've used a few. They continue to hold up, but they leak air much faster than new tubes resulting in the need to pump up the tires more often. If it's your regular rider, I'd replace the tubes too. As for rim strips, well, I've had good luck with old rim strips that were in good condition and bad luck trying to make damaged rim strips work. If you have any doubt, replace them. Performance has some really nice cloth rim strips at about half the price of Velox.
    One comment about replacing tubes. I tried some cheapo tubes from a big box bicycle store, they flatted faster than the 30 year old tubes. If you replace your tubes, use good tubes from an LBS, stay away from bargain basement tubes.
    Roccobike BF Official Thread Terminator
  11. #11
    I blame you. RobbieTunes's Avatar
    Join Date
    Dec 2007
    Location
    NC Coastal Plain.
    Posts
    13,528
    1-Try to locate that one person you've always wanted to get even with.
    2-Restore the bike, keep the tires and tubes (they hold air, right?)
    3-Give the bike to him/her.
    Wait for the phone call.
    Otherwise, put new tubes and tires on the bike.
    I "second" roccobike's advice: get good tubes, the extra $2 apiece is worth it if one fails.
    The failure rate is lower, and they'll often back it up if it does.
    (actualy, I pay more for Conti tubes because they have cool yellow caps)
    Robbie ♪♫♪...☻
    You will not believe how fast I used to be...
    84 Simoncini SLX
    85 Cinelli Equipe Centurion
    85 Centurion Ironman
    85 Eddy Merckx Corsa Extra
    88 Schwinn Paramount
    91 Cannondale SC800
    95 Hot Tubes TT
    98 Trek Y Foil
    98 Giant MCR
    08 Cannondale Six13
  12. #12
    Join Date
    May 2009
    Posts
    1,841
    Some Schwinns came with an unusual 597 mm tire size.
    I hope you regrease the thing before you ride it. It is possible for old grease to be dried up in the hubs. Actually, the oil creeps out of the thickener and makes dusty stains around the hubs. At a minimum, carefully oil the hubs and bottom bracket, or learn to disassemble and correctly reassemble bicycle hubs and put in some fresh grease.
  13. #13
    SE Wis dedhed's Avatar
    Join Date
    Apr 2005
    Location
    Milwaukee, WI
    Posts
    1,985
    Quote Originally Posted by garage sale GT View Post
    This can be an issue when trying to buy new tires for old Schwinns.
    http://www.sheldonbrown.com/tire-sizing.html
    You may need something like this
    http://www.biketiresdirect.com/produ...-8x11-4-37-597
    '68 Raleigh Sprite, '02 Raleigh C500, '84 Raleigh Gran Prix, '87 Trek 400T Elance
  14. #14
    match-burning commuter ThermionicScott's Avatar
    Join Date
    Aug 2011
    Location
    SW CR IA US NA PE
    Posts
    5,415
    If it's like the 1970s Schwinn Suburbans I've had in my hands thanks to my girlfriend's budding interest in bikes , they have 27" wheels. Still quite a few decent options for them.
    Quote Originally Posted by chandltp View Post
    RUSA #7498
  15. #15
    Join Date
    Nov 2006
    Location
    Greenville, NC
    Posts
    622
    +1 to those who say it's worth replacing the tires if you'll be riding it a lot.
    Another thing that's relevant this time of year: if you're going to keep the old tires/tubes, keep in mind that changes in temperature can affect pressure fairly dramatically. I've seen old tires that seemed just fine, when fully inflated in a cool basement, literally explode when the bike was parked after a ride on hot summer asphalt.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
