Advertise on Bikeforums.net
Page 1 of 2 12 LastLast
Results 1 to 25 of 40
  1. #1
    Engineer Asi's Avatar
    Join Date
    May 2010
    Location
    Bucharest, Romania, Europe
    Posts
    410
    Chairings - why aluminum? why not steel?
    I looked at my chainring from time to time and i could see that is wearing out a bit too fast. I searched the market for a new one and see that is somehow a bit pricey (I mean I ride a 1989 steel bike all original, all dura-ace, and a proper chainring costs half of the price I paid for the bike).
    I made a good use for a laser cutter I got at work, and made myself a chainring (a steel one).
    The real question.. why most of them are aluminum? Aluminum chainrings and steel chain wears a lot faster, also titanium cogs on some cassettes.
    I see steel chainrings only on very low grade stuff. (and not sold seperatly, and not that i would want one of those, I made one from a steel plate 4mm thick, and some beveling on a lathe, but that's another story). The weight issue is almost non-existing, steel can be much thinner than Al. Yet for weight weenies I understand, but the normal way should be steel and the niche class should be Al-Ti-Mg-Carbon fiber stuff - stuff that the main advantage is weight (density to be specific) and the rest are disadvantages (especially price for Ti and carbon stuff)
    Is there any argumentation on using improper materials? (Al chainrings, Ti-cogs, Ti-chains, anodized Al for rims, etc)
    I guess there are some B-class engineers at work in the bike department... The A-class is into aviation/automotive.
  2. #2
    Join Date
    Apr 2009
    Location
    New Rochelle, NY
    Posts
    11,566
    Steel would last longer, but not as much longer as you seem to expect. In any case, bike specs are driven by weight, and it wold be hard to justify steel rings on anything but the lowest entry level bikes (where they are used).
    It should be noted that not all aluminum rings are created equal. There are numerous grades of aluminum, and some are incredibly wear resistant. Also consider that, excepting the smallest granny rings used for mtb which are usually steel, most chainrings tend to hold up fairly well, and tend to outlast chains and cassettes by a big factor. In over 100k road miles I have never replaced a chainring, including one pair with well over 50,000 miles on them (and believe me, I don't baby my bikes).
    All in all, it would be very hard to justify using steel rings as an improvement. The added life would not be enough to justify the weight penalty.
    FB
    Chain-L site
    "One measurement is worth one thousand opinions", unknown
    "A little learning is a dangerous thing" , Alexander Pope, 1709
  3. #3
    Join Date
    Jun 2008
    Location
    Vancouver, BC
    Posts
    4,057
    Most people don't complain if they get 23 yrs of life from their aluminium chain rings.
  4. #4
    Join Date
    Aug 2005
    Location
    New Hampshire
    Posts
    727
    There are some touring/trekking triple cranks that use steel for wear resistance, particularly on the smaller rings which get used more. Two that come to mind are the Shimano Deore LX 48/36/26 (M583?) and the Sugino XD300. I think the Sugino is all steel while the Shimano used Alu for the big ring. While these certainly aren't top-of-the-line cranksets, they aren't department store grade either.
  5. #5
    Join Date
    Aug 2005
    Location
    Pittsburgh, PA
    Posts
    22,325
    Steel granny rings are fairly common but the larger chainrings, particularly road rings, last so long with any decent care that improved longevity would be a non-issue.
  6. #6
    aka Tom Reingold noglider's Avatar
    Join Date
    Jan 2009
    Location
    Maplewood, NJ and High Falls, NY
    Posts
    14,732
    I've seen worn chainrings, so now that I think about it, they must have worn from use of insanely worn chains. Of course, these chainrings were not on MY bikes.
    In other words, FBinNY is right: chainrings don't wear out, but maybe they do, only if you abuse your bike. Replace your chain when it starts to wear.
    Please email me rather than sending me a private message. My address is noglider@pobox.com
    Tom Reingold
  7. #7
    Join Date
    Nov 2008
    Location
    Bay Area, Calif.
    Posts
    3,861
    The last chainring I replaced had slightly over 90 kmiles of use. A steel one would presumably have lasted longer but with a tradeoff of greater weight. Since I can get a replacement for about $40, the cost is about 0.04 cents per mile, or one extra penny on each 23 mile ride. Don't think I'm ready to accept a heavier chainring for savings of that magnitude.
  8. #8
    Senior Member zukahn1's Avatar
    Join Date
    Oct 2011
    Location
    Denver Co
    Posts
    2,568
    Well steel would be likely as good I have several that are steel in my collection. The thing is steel is a lot harder on chains and much less forgiving on gearing setups. Plus as others have said they last longer than most bikes I have alloy rings with several thousand miles on them that are 30 years old or better with no prolblems.
  9. #9
    Constant tinkerer FastJake's Avatar
    Join Date
    May 2010
    Location
    Madison, Wisconsin
    Posts
    5,074
    +1 Weight savings is why they use Al rings. The durability factor just isn't justified. FWIW:
    Shimano 48T Biopace aluminum: 77g
    Shimano 48T Biopace steel: 220g
    So on a standard double you might be looking at a 250g weight penalty, which is over half a pound.
    Tri-color fan
  10. #10
    George Krpan
    Join Date
    Jan 2007
    Location
    Westlake Village, California
    Posts
    801
    Suley's take on their stainless steel chainrings.
    On a drivetrain with a steel chain and steel cogs, why wouldn’t you want to use a steel chainring? Most chainrings on the market are made from aluminum, which is 35% softer than stainless steel. A softer metal means a shorter lifespan. Enter the Surly Stainless Steel chainring, made from 304 grade stainless. You can now have an all-steel drivetrain that will love you long time. Stainless, as it’s name implies, is a rust and corrosion-resistant alloy steel that is known for it’s toughness. Like all things mechanical, it will eventually wear out. When it does, simply flip the chainring around and you’ll get another lifespan out of it. Our chainring is ideal for single-speed, fixed gear or tandem timing chain applications. It is not ramped or pinned for shifting assistance, so shifting will be a bit slower if using these with a front derailleur. Check out all the sizes we carry:
  11. #11
    Join Date
    Apr 2009
    Location
    New Rochelle, NY
    Posts
    11,566
    Quote Originally Posted by GeoKrpan View Post
    ....Most chainrings on the market are made from aluminum, which is 35% softer than stainless steel.....:
    Just like a coin which has 2 sides, there are two ways to look at the chainring material argument.
    Yes, steel rings may last longer, but given what you're spending per gram to save weight, the higher cost of replacing rings sooner than you might otherwise is still one of the cheapest ways to save weight.
    FB
    Chain-L site
  12. #12
    Senior Member AEO's Avatar
    Join Date
    Jun 2007
    Location
    A Coffin Called Earth. or Toronto, ON
    Posts
    12,244
    There is no point in having steel chainrings in sizes over 34t.
    Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
    http://sanfrancisco.ibtimes.com/arti...ger-photos.htm
    Note to self: Buy twister.
  13. #13
    Join Date
    May 2010
    Location
    Posts
    410
    Well, maybe 23years lifespan seems ok, but the point is:
    1989 - dura-ace - shaved (the chain was replaced from time to time, and the rear cassette is in very good condition with no visible wear on cogs, so the weak part was the chainring itself)
    1962 - xb3 (some russian thing, steel) - like new, and I still use it as a fixie.
    1974 - xb3 - Steel, it has some wear, but i have plenty of lifespan remaining
    197? - stronglight - steel, still usable, some wear may be noticed
    First two are 53t (but the BCD, and number of bolts is different, otherwise I would just put a like new xb3 that I have around)
    the rest are 50-51t
    And another thing: On a bike 20-30-40-50years old that is in working condition and at low price (50$ or so).. you don't change parts ,more expensive than the bike itself (on some occasions you may).
    So in terms of old bikes, most of them that are all steel, are still on the road. (not referring only to the chainring) - and yea, I don't like Al on gears and other important moving parts like crankshafts, drive-shafts, bearings - and you don see them made out of Al in cars/motorcycles/industry, wonder why? But you see them in bike industry. Weird.
  14. #14
    Senior Member wle's Avatar
    Join Date
    Jan 2004
    Location
    atlanta ga
    Posts
    118
    35,000 unbabied miles on shimano 600 chainrings, both the 40 and the 53
    usually using the 40
    wle
  15. #15
    Join Date
    May 2006
    Location
    Romania
    Posts
    161
    Quote Originally Posted by Asi View Post
    The thickness of the chainrings is the same regardless of the chainring material (the chainring thickness is correlated with the inside width of the chain).
  16. #16
    coprolite fietsbob's Avatar
    Join Date
    Jun 2010
    Location
    NW,Oregon Coast
    Posts
    25,433
    7075t6 alloy is quite long wearing, it must be machined,
    the softer alloys lend them selves to punch presses, so production costs are lower.
    For Single speed and IG hubs, I have found Surly Stainless steel chainrings very nice.
    20 years ago,
    I did find and install steel chainrings, on my cyclo-camping tour-bike,
    50,38,24
    and my winter, studded tire, old mtb,
    48,36,22
    weight matters less, on those rigs.
    and drivetrain is simplified for durability, friction bar end shifting
    and 6 or 7 speed freewheels,
    so latest shift pins and ramps features, absence is not an issue.
  17. #17
    rugged individualist wphamilton's Avatar
    Join Date
    Apr 2011
    Location
    Alpharetta, GA
    Posts
    3,164
    hypothesis: it is cheaper and easier to machine chainrings from aluminum.
  18. #18
    Join Date
    Apr 2009
    Location
    New Rochelle, NY
    Posts
    11,566
    Quote Originally Posted by wphamilton View Post
    Which goes a long way toward explaining why low end OEM cranksets have steel chainrings, while pricier cranksets have aluminum chainrings.
    FB
    Chain-L site
  19. #19
    SE Wis dedhed's Avatar
    Join Date
    Apr 2005
    Location
    Milwaukee, WI
    Posts
    1,985
    I guess you've never changed a timing chain on an older small block Chevy. Nylon teeth on an alum hub for the timing chain. Supposed to be quiter than a steel gear.
    '68 Raleigh Sprite, '02 Raleigh C500, '84 Raleigh Gran Prix, '87 Trek 400T Elance
  20. #20
    Join Date
    Apr 2011
    Location
    Alpharetta, GA
    Posts
    3,164
    Quote Originally Posted by FBinNY View Post
    It doesn't completely kill the hypothesis, since other cost variables may be involved for manufacturing low end vs higher end crank rings. Is it easier to stamp something out of softer steel than to manufacture using some other technique, with more exacting tolerances and other specs? I suspect so, but it's just a hypothesis.
  21. #21
    Join Date
    Apr 2012
    Location
    Nv
    Posts
    49
    Now that's funny. I like aluminum because I'm such a spode they last forever.
  22. #22
    Join Date
    Apr 2005
    Location
    Milwaukee, WI
    Posts
    1,985
    See 1:37 for how it was done "back in the day"
    http://www.youtube.com/watch?v=ZPLRF5F5SZY
    See 10:43 for the "British" method
    http://film.britishcouncil.org/how-a-bicycle-is-made
  23. #23
    Senior Member Shimagnolo's Avatar
    Join Date
    May 2008
    Location
    Zang's Spur, CO
    Posts
    5,743
    I just wore out a 32T aluminum middle chainring on a triple. I had installed a new chain at the usual wear point. Everything worked like a charm on the workstand, but when I tried riding the bike, the lower portion of the chain "stuck" to the chainring, jamming against the underside of the FD. Closer examination revealed the teeth had taken on a slight "hook" shape. The worn-out chain had a large enough pitch for the links to slip off the teeth, but the new chain "stuck" in the hooks when pedaling under load.
  24. #24
    Old fart JohnDThompson's Avatar
    Join Date
    Nov 2004
    Location
    Appleton WI
    Posts
    10,350
    Yeah, baby!
  25. #25
    George Krpan
    Join Date
    Jan 2007
    Location
    Posts
    801
    It doesn't really make a difference to me. If the bike came with aluminum chainrings I use them until they're worn out, same with steel.
    But, if I have to buy new cranks or chainrings and there is a steel option at a comparable price, I will get steel, it lasts longer.
    I ride 15,000 miles a year, it makes a difference.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
