Advertise on Bikeforums.net
Results 1 to 9 of 9
  1. #1
    Join Date
    May 2012
    Posts
    2
    Steerer tube cut botched? (pictures)
    Hello,
    I cut the steerer tube of my fork today, but did a terrible job. The cut is not very even and now I am afraid that I cut it too low. It is about 4mm below the top of the stem. The top of the higher stem bolt is just peeking above the cut, is this safe? Please let me know if this looks ok or if it is dangerous is some way. Thank you for your time.
  2. #2
    Join Date
    Dec 2010
    Location
    Above ground, Walnut Creek, Ca
    Posts
    2,078
    the star nut positioning probably helps.
    that wouldn't bother me, but knowing BFers, there will be differing opinions.
    if you decide that it indeed bothers you, (it's hard to see what you've got under the stem) you may be able to find a shorter upper bearing cover, and i wouldn't be surprised if the stack height of stems vary somewhat too. so THAT may be an option.
  3. #3
    Join Date
    Apr 2009
    Location
    New Rochelle, NY
    Posts
    11,554
    It isn't ideal, but not bad enough to worry about in any way, unless you're a professional mechanic expecting to charge for the job. The evenness doesn't matter since the issue is for the steerer to be cut sub-flush. The evenness of the gap doesn't matter since nothing touches on the end of the steerer.
    As to the height, 2mm longer would have been better, but what you have is functionally OK. Finish the job, assemble the top cap, adjust the headset and tighten it all up and don't let anyone look at it. Next time, measure twice, cut once, and plan on one 3-5mm spacer below the stem, so you have a fall back position if it comes out short.
    FB
    Chain-L site
    "One measurement is worth one thousand opinions", unknown
    "A little learning is a dangerous thing" , Alexander Pope, 1709
  4. #4
    Join Date
    Jan 2012
    Location
    Spokane, WA
    Posts
    1,543
    That is fine. I would not worry about it. Like the other poster said, its not acceptable for a professional mechanic but it is functionally fine and usable as is. Just looks ugly. When the cap is in place, you won't even know.
  5. #5
    Senior Member commo_soulja's Avatar
    Join Date
    Aug 2008
    Location
    C-Ville
    Posts
    1,125
    Hard to tell from the pics but looks like the top of the steerer tube is just below the threads of the stem pinch bolt. If it were below the pinch bolt I'd be concerned.
    Mythical Creatures Touched Me in my Bathing Suit Area.
  6. #6
    Senior Member JonathanGennick's Avatar
    Join Date
    Apr 2007
    Location
    Munising, Michigan, USA
    Posts
    1,745
    Quote Originally Posted by hueyhoolihan View Post
    ...and i wouldn't be surprised if the stack height of stems vary somewhat too. so THAT may be an option.
    Truvative AKA stems run shorter than usual stack heights. Crank Brothers headsets also have short stacks. I have used both in the past as solutions when a steering tube has been shorter than I wanted. Either one would probably gain you enough for a second go at cutting that steerer -- if that's what you wanted.
    Just pointing out that all is not lost in the event you don't like that gap. You do have some options.
  7. #7
    Join Date
    May 2012
    Posts
    2
    Thank you very much everyone!
  8. #8
    Join Date
    Aug 2005
    Location
    Pittsburgh, PA
    Posts
    22,320
    This is a metal steerer so it's pretty forgiving. If it was a carbon steerer, I'd be much more concerned.
  9. #9
    The Left Coast, USA FrenchFit's Avatar
    Join Date
    Feb 2008
    Posts
    1,672
    LOL, I've had mine halfway down the stem..maybe more. Not a problem; you'd have to be superman to twist off the stem or deform that steerer tube even with one securing bolt. A metal steerer tube and stem with decent pinch bolts...you're talking about a component that is majorly overbuilt.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
