Bunny Hop
Bunny Hop
Old 07-02-12 | 09:03 AM
datlas's Avatar
Should Be More Popular
Titanium Club Membership
15 Anniversary
Community Builder
Community Influencer
Bunny Hop
OK, gang. I like to think I am a decent road cyclist with above average skills.
However, one thing I have never done (or even attempted) is the dreaded "bunny hop."
I sometimes see my club-mates do this to hop over a set of railroad tracks...or the occasional pothole.
Anyway, is this a skill that's really worth learning, or is it more like doing a "wheelie" that looks cool but has minimal value other than showing off??
Originally Posted by rjones28
Addiction is all about class.
datlas is offline
Reply
Old 07-02-12 | 09:04 AM
tagaproject6's Avatar
15 Anniversary
Skill worth learning...sometimes you have no time nor the space to swerve to avoid an obstacle.
tagaproject6 is offline
Reply
Old 07-02-12 | 09:05 AM
I learned it a few weeks ago when I had no other option. Worked beautifully.
AMFJ is offline
Reply
Old 07-02-12 | 09:22 AM
merlinextraligh's Avatar
pan y agua
20 Anniversary
+1.
More important if you race, or do training rides where you're in a pack (as oppossed to a paceline) and sometimes don't have the option to move laterlally.
Even without racing, there are still times it's handy; pothole on a narrow shoulder, and traffic prevents you moving laterally, wet railroad track that cuts across the road on a diagonal, and traffic doesn't allow you taking it at a 90 degree angle.
Done right, hopping is going to be both safer, and easier on your wheels than the alternative in a number of cases.
You could get lost and die.
You could hit a tree and die.
merlinextraligh is offline
Reply
Old 07-02-12 | 09:43 AM
mpath's Avatar
Recusant Iconoclast
Bikes: Look 695, Wilier Izoard
But if you don't know how to bunny hop.......
mpath is offline
Reply
Old 07-02-12 | 09:51 AM
Jaymadd's Avatar
Bikes: 2011 Boardman Team Carbon
Yes it is worth learning. I hopped a 1 foot gap in the pavement the other day due to road construction which most likely saved me from a pinch flat or worse. Another 100 yards up the road was a dude changing a flat due to hitting that very same gap. It is easy to do, just hold on to the bars and jump.
Jaymadd is offline
Reply
Old 07-02-12 | 09:55 AM
Bikes: Mikkelsen custom steel, Santa Cruz Chameleon SS, old trek trainer bike
I didn't think it was a skill to be learned... you just, do it. Maybe its because I started out mountain biking?
garciawork is offline
Reply
Old 07-02-12 | 10:05 AM
EdIsMe's Avatar
Bikes: 2011 Neuvation FC100, 2013 Mercier Kilo TT Pro, 1984 Peugeot SV-L
I've used it before. It's much better to jump an obstacle than to swerve around it if you're in a group. Just don't crash...
EdIsMe is offline
Reply
Old 07-02-12 | 10:21 AM
Homebrew01's Avatar
Super Moderator
20 Anniversary
Looks like you answered your own question.
If you ride in groups, then I consider it a basic skill for reponsible cycling.
Homebrew01 is offline
Reply
Old 07-02-12 | 10:26 AM
datlas's Avatar
15 Anniversary
Community Builder
Ok, Ok.
Thanks for the feedback.
I will have to add this to the arsenal.
datlas is offline
Reply
Old 07-02-12 | 01:22 PM
dleccord's Avatar
ask this guy.
dleccord is offline
Reply
Old 07-02-12 | 01:28 PM
Seattle Forrest's Avatar
Definitely worth learning, but rarely used. It's just ... in those times when you didn't see a pothole (or other obstacle) coming, or can't move out of the way in time, it's much easier on you and on your wheels to go over it than to it it.
Very easy with clipless pedals, it isn't like being on a BMX.
Seattle Forrest is offline
Reply
Old 07-02-12 | 01:49 PM
ColinL's Avatar
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
when you are on platforms, you have to position the pedals just right so you can lift the rear wheel as you jump. if you are right-footed, you would do this with the pedal roughly at the 7 o'clock position when viewed from the drive side.
when clipped in, you just pull the front end up and then jump.
ColinL is offline
Reply
Old 07-02-12 | 01:56 PM
LesterOfPuppets's Avatar
The space coyote lied.
15 Anniversary
Community Builder
Bikes: everywhere
There was a German forumite who said they called it a pig hop when you do it with foot retention.
You can actually get off a decent bunnyhop just by unweighting the pedals as you yank up on the bars then push them forward and down a bit and also twist grips (hoods, whathaveyou) forward.
LesterOfPuppets is offline
Reply
Old 07-02-12 | 01:58 PM
pan y agua
20 Anniversary
I'm trying to talk my wife into bunny hopping the tandem, so far not a lot of interest.
Reply
Old 07-02-12 | 02:01 PM
15 Anniversary
Community Builder
Bikes: everywhere
Hahaha! I bet with enough attempts a good team could pull off one or two. I'm off to search youtube for this.
Reply
Old 07-02-12 | 02:02 PM
15 Anniversary
Community Builder
Bikes: everywhere
OMG. Look how easy it is
They weren't going fast enough to clear a pothole, though.
Reply
Old 07-02-12 | 02:03 PM
Hoshnasi's Avatar
A few of the cement to asphalt transitions on the MUP are really bad. If you're traveling at speed, hit them would be a tube replacement. You have to hop them more of the time.
Hoshnasi is offline
Reply
Old 07-02-12 | 02:12 PM
Bikes: Carbon Topstone 105(factory) Size XL, 2012 Specialized Secteur
How does one bunny hop? I must be too fat Everytime I try, I can lift up the front tire a bit but my jump usually doesn't get he back tire off the ground. I'm vertically challenged.
blargman is offline
Reply
Old 07-02-12 | 02:18 PM
datlas's Avatar
15 Anniversary
Community Builder
I am no expert, as should be obvious...that said, I believe you need to bend your knees to pull up the bike, especially the rear.
Probably best to paint some lines in the road and practice jumping over them.
Any other ideas from the collective?
datlas is offline
Reply
Old 07-02-12 | 02:22 PM
15 Anniversary
Community Builder
Bikes: everywhere
Beer cans. Once you can do 12oz stacked two-high on a regular basis you're ready to clear just about any curb.
Also speed bumps. You can feel it if you stack on 'em (code for not landing in the landing zone) but it ain't so harsh as to wreck your rear rim, like a curb would be.
Reply
Old 07-02-12 | 03:04 PM
Stealthammer's Avatar
Still spinnin'.....
Bikes: Fisher Opie freeride/urban assault MTB, Redline Monocog 29er MTB, Serrota T-Max Commuter, Klein Rascal SS, Salsa Campion Road bike, Pake Rum Runner FG/SS Road bike, Cannondale Synapse Road bike, Santana Arriva Road Tandem, and others....
I am no expert, as should be obvious...that said, I believe you need to bend your knees to pull up the bike, especially the rear........
Yep, I love to see riders bunny hop obstacles on road bikes, because I immediately know how they learned to ride. BMX'ers and MTB riders approach a bunny hop quite differently than road riders, and the bunny hop seems to be more instinctive than planned or "handled". I would guess that those of us that were raised on BMX and MTB learned how to maintain our torso path to maintain momentum and to use our legs to raise the bike rather than to hop the bike, while those that started on the road actually attempt to hop the bikes over yhe obstacle. Either method works, but using your legs as suspension results in a smoother transition.
Stealthammer is offline
Reply
Old 07-02-12 | 03:18 PM
I bunnyhopped a wooden road debris hidden by shade going 30 mph on a descent. Made i thru but holy crpp that scared the heck out of me. I slowed it to 20 rifht after.
hhnngg1 is offline
Reply
Old 07-02-12 | 03:25 PM
Nachoman's Avatar
well hello there
20 Anniversary
I bunny hop all the time. It's also really fun.
Nachoman is offline
Reply
Old 07-02-12 | 04:10 PM
milkbaby's Avatar
blah blah blah
Traditional bunny hop:
If you ride clipped in, you can just brute force it without properly "preloading" the pedals and having timing finesse pushing the bars forward... Technically you probably still "preload" the jump but can just pull the whole bike up by brute force when clipped in.
milkbaby is offline
Reply
