Originally Posted by
LuMax
It's actually not that heavy until the cooler gets completely filled with ice and beverages, then it's a bit of work on the uphills. With the cooler empty I can barely tell it's hooked up, the trailer itself is quite light. The basket weighs about ~6 pounds because I used perforated steel and lighter gauge steel for it's construction. The combined weight of my dogs is 14.4 pounds. I plan to convert my rear wheel from a Nexus 3-speed hub to a Nexus 8 this winter, then trailer weight will no longer be an issue. I road and mountain bike a lot and spin in the winter months, so my fitness is generally quite good. Not certain how much weight the sound system will add just yet. Also contemplating adding a front wheel drum brake hub.
