Compact DIRT Drops?
Compact DIRT Drops?
Hello
Was wondering if anyone might know about dirt drop handlebar availability.
Have just tried out the Nitto dirt drop rm014, and definetly like the width ~50cm and flare angle
but feel like I want something with less drop -as it is the vertical difference between hoods and drops seems a little too much to make both work well
The Soma Junebug def has less drop, but feels too wide
I hear the midge and woodchipper are also wider still, so no go
Know of a dirt drop thats narrow-ish like the nitto, but more compact/less drop?
Thanks
Thanks
Two-Wheeled Aficionado
Bikes: Santa Cruz Blur TR, Cannondale Quick CX dropbar conversion & others
I was curious because my CX bike has ultegra brifters and I'm not that happy with the lever travel controlling Avid BB7s. I hear they are coming out with redesigned BB7s made just for this purpose, with a different leverage ratio.
I use regular drop bars on that bike-- FSA Omega Compact. I only rode them briefly, but I got a strong 'single position' vibe from Salsa Woodchippers. Kind of defeats the purpose of drop bars if you only have one hand position...
I'm looking for dirt drops that are smaller, not bigger
anyhow, other small people may be interested, I've found:
Soma Portola bars, theyre nearly identical shape to the Soma Junebug (which is Midge-like); however they come in 53cm instead of junebug's 56cm width.
Nitto Dirt Drop, comes in 50cm width, but have a ton of drop and almost looks more like a rando bar than a dirt drop
currently trying out the Portola, a few cm wider than ideal, but between being slightly wide and having too much drop (nitto) its probably a better option
Moar cowbell
Bikes: Bike list is not a resume. Nobody cares.
Dirt drops - - now that's an oxymoron.
RST Suspension | Canfield Bikes | 7iDP Protection | Maxxis | Renthal | Hayes | VonZipper Optics | GoPro
Originally Posted by Mark Twain
"Don't argue with stupid people; they will drag you down to their level and then beat you with experience."
Yup
From: where the sunbeams end and the starlight begins
Bikes: Kona Unit, planet X cx bike, khs fixed gear
When you mean wide are you refering to c-c width, or actual barend to end width?
Not going to find a narrow end to end dirtdrop. The one one midge is the narrowest I know of at 53cm end to end. Woodchippers are either 42 or 46 c-c, but 60cm end to end. Ragley luxy bars are about 65wide with a 42 wide top. But it you want narrow look for compact drops with flair like the salsa cowbells. I have them on my cx bike.
Not sure why you want dirtdrops if you want to ride the hoods, dirt drops are designed so you ride in the drops all the time.
When sadness fills my days
It's time to turn away
And then tomorrow's dreams
Become reality to me
Yup
Moar cowbell
There's a "bars below saddle rule"?
I go with the "bars wherever the hell I want them" rule.
Bikes: ritcheys{2** rm blizzard Geo elrick drop frame and acollection of parts bikes in waiting
Wide shallow , flip a Nitto Albatross, cr-mo, accepts bar ends. On one rat-bike, I flipped a Nitto Dove, looks track racer 1890's
