Felt F75x?
Bikes: felt
Felt F75x?
Thinking about getting into a cyclocross bike. Alot of gravel roads around here. Leaning towards the felt f75x. 1,500 is about all I have for budget. Any other suggestions?
Bikes: felt
Bikes: '12 Felt F75X, '11 Scott CX Team, '08 Specialized Singlecross
I picked one up in May and I am very happy with it. Due to a number of factors, it has seen mostly on-road use.
I had two issues early on that were addressed by my LBS. First, after the first ~200 miles, there was creaking from the BB. LBS re-lubed and the issue went away. Second, after about ~400 miles, there was a creaking from the rear hub. LBS re-built the rear hub and the issue went away. I have put well over 1000 miles on the bike since then without any issues.
Bikes: felt
Bikes: 2010 S1, 2011 F75X
I race on a 2011 F75x - its been a solid bike. I bit of BB creaking, but easily solved by cleaning out the shell and greasing. Comes with the territory when racing cross.
Bikes: 2013 Felt F75X
I'm in the same position - I can't find anything with the same component quality as the Felt F75x without spending a few hundred dollars more. And the 2013 model does look pretty slick.
SoggySandwich
10
09-25-12 06:59 AM
