Advertise on Bikeforums.net
Results 1 to 15 of 15
Thread: Grips
  1. #1
    hey peoples,
    I was just wondering if anyone has any ideas about making grips stick better. I've got the mat kind of finish on my bars and grips just slip all over the place. Is glueing a good idea? What about those lockjaws things?
    thanks in advance.
    my site: http://www.geocities.com/nothing4130
  2. #2
    Join Date
    Jan 2000
    Posts
    85
    My tip.
    When i install new grips on any of my bikes, i always use hairspray, just spray your bar and the inside of your grip, and slide the grip on, let dry for a few hours, and you will never get thoes grips off, and they wont slide around.
    How come wrong numbers are never busy?
  3. #3
    Join Date
    Sep 2000
    Posts
    3
    Use some sort of glue. Red Hot Blue Glue for PVC pipe works excellent and only takes about 2 hours to dry, you can buy it at your local Home Depot for about a buck. Or you could use a motorcycle grip glue like Three-Bond, but that costs more. Just make sure to keep it out of your grip shifters.
  4. #4
    Join Date
    May 2000
    Location
    Bozeman, MT
    Posts
    34
    Some more ideas...
    Like Roadrash said, hairspray works well. Make sure you get the gnarliest old lady big hair type (like Aqua Net) because it is impervious to water. Some types of hairspray wash off very easy, so if the grips get wet at all you're back to slip-sliding. Just used compressed air when you want to remove the grips.
    Lock jaw grips work extremely well and are easy to get on and off.
    Glue works well also, but can be a hassle to get the grips off. I used to glue my BMX grips on, but you practically had to cut them off if you needed to remove them.
    I've also used hexane. It breaks down a thin layer on the inside of the grip which makes it very sticky. Once dry (it evaporates quickly, like in a few minutes) they are stuck pretty well.
    My favorite method is wiring. I use thin (0.032") stainless steel wire (aircraft safety wire) on both ends of the grip. It works very well and is easy to remove. Just make sure to stick the end of the wire into the grip so that it doesn't poke into your hands.
  5. #5
    Member zx12rider's Avatar
    Join Date
    Mar 2008
    Location
    westport ma
    Posts
    30
    Quote Originally Posted by cooldude View Post
    hey peoples,
    thanks in advance.
    i use lock-on's, both on my bike and on my quad
  6. #6
    Join Date
    Jan 2008
    Location
    Georgia
    Posts
    1,831
    Quote Originally Posted by Tony Smith View Post
    Lol yea I Gorrilla glued my BMX grips... It took a razor knife and a screwdriver lol
  7. #7
    Nitro xcracer13's Avatar
    Join Date
    May 2007
    Location
    canyon lake, tx
    Posts
    829
    You could get some Extrem Steering Inc. grips and not have to use hairspray or a lock on bolt or anything and not worry about throttle. www.esigrips.com
    www.teamnrc.com
    When you feel good, racing is hard. When you're not good, its worse.. - Sager
  8. #8
    Fourth Degree Legend junkyard's Avatar
    Join Date
    Jun 2005
    Location
    American Gardens Building
    Posts
    3,832
    lock ons
    Quote Originally Posted by dminor View Post
    The caveat with a strap-on, of course, is you will have to get creative with a couple of lock cables and an anchor point
  9. #9
    Senior Member rankin116's Avatar
    Join Date
    Jun 2007
    Location
    Troylet
    Posts
    3,290
    8 years? Wow. What did you search on that brought up this thread?
  10. #10
    Join Date
    Jun 2005
    Location
    Posts
    3,832
    wow. good catch.
  11. #11
    Long haired freak. wethepeople's Avatar
    Join Date
    Jun 2005
    Location
    Still stuck in hell.
    Posts
    6,303
    Quote Originally Posted by Cheeto View Post
    wow....
    "the bus came by and I got on, that's when it all began...there was Cowboy Neal at the wheel of a bus to never-ever land."
  12. #12
    Bicycle Rider & Mechanic Trekbikedude's Avatar
    Join Date
    Dec 2004
    Location
    Delaware
    Posts
    687
    +1
    +1 on the ESI's I just ordered some chunkys from jenson I've been using the racer's edge and can't wait to get something a little thicker.
    On top of the world.
  13. #13
    World's slowest cyclist.
    Join Date
    Oct 2007
    Location
    Londonderry, NH
    Posts
    1,355
    Wow, congrats on using the search feature. Cool to see a little picture of what the world looked like in 2000.
  14. #14
    Join Date
    Jan 2008
    Location
    Boca Raton, Florida
    Posts
    20
    The ergon grips that lock down have to be hands down the best grips on the market.
  15. #15
    PBR Racing RIC0's Avatar
    Join Date
    Aug 2006
    Location
    Wifes $hit List
    Posts
    967
    Just put them on the bar using nothing and they will not budge. It's not easy to do but it works great.
Posting Permissions
  • You may not post replies
  • You may not edit your posts
