Which Chain Lube?
Bikes: Airborne Ti HT, Santa Cruz Nomad C, Litespeed C1R
Which Chain Lube?
At the risk of starting a big debate, just want to know what others are using for chain lube in the winter?
I recently moved from a place with heated underground bike parking where I had a chance to rinse my bike very often to a place with an unheated garage and now have a chance to wash it every few weeks.
I am currently using White Lightning-Clean ride wax and notice that it is not doing a good enough job at keeping the chain free of rust.
Suggestions? (BTW, the climate in which I live is Calgary, AB)
Bikes: Trek 730 (quad), 720 & 830, Bike Friday NWT, Brompton M36R & M6R, Dahon HAT060 & HT060, ...
From the stand-alone lubes, I found T9 to be the best in winter and in rain. However, I now mix the lubes and specifically T9, LPS3 and ACF50 in comparable proportions. The mixture works very well.
Bikes: Lotus Odyssey - Shogun 400 - '75 Raleigh Tourist - Raleigh Grand Prix - Gitane Tour de France- Schwinn Le Tour - Univega Maxima Sport (winter bike) Trek 950
I've given mine a blast of PB Blaster, spun it, spun it wiping it, let it sit & T9
'Sides its winter, eventually its gonna kill the chain no matter what you use
your god hates me
Bikes: 2026 Crumpton T5, 2016 Richard Sachs, 2010 Carl Strong, 2006 Cannondale Synapse
These sort of propositions are good when one rides infrequently under harsh conditions. I would sooner dump the bike than do it twice a day
My preferred chain lubrication for sub-freezing conditions is Tri-Flow. It stays liquid down to -60 degrees Fahrenheit (-51 degrees Celsius).
I wipe the chain clean with Simple Green Solution and then apply the Tri-flow. The process in the link below takes me two paper towels and about 3 minutes total to do both.
https://www.youtube.com/watch?v=7GwXA...EDB1A7&index=2
To prevent rust you will need to at least clean the chain off with Simple Green Solution after a ride where the chain gets wet. That will take about 90 seconds total time.
In the old days of car driving, they recommended checking oil level before every ride, pressure in the tires, acid in the battery and few other things that slip my mind.
ammarolli
Winter Cycling
16
01-22-17 07:40 PM
kiltedcelt
Bicycle Mechanics
7
12-06-13 01:24 PM
