Long Distance Competition/Ultracycling, Randonneuring and Endurance Cycling Do you enjoy centuries, double centuries, brevets, randonnees, and 24-hour time trials? Share ride reports, and exchange training, equipment, and nutrition information specific to long distance cycling. This isn't for tours, this is for endurance events cycling
Do Aero bars help?
Old 04-22-13 | 06:24 AM
Lamabb's Avatar
Doesn't ride enough
Bikes: 2010 Cannondale Caad9 5 / 2010 Surly Long Haul Trucker/ 2013 Orbea Orca Bli2 / 2011 Specialized Rock Hopper
Do Aero bars help?
I'm getting into randonneuring and only have done a 200k, although I've also ridden a couple 150 milers with my local club. The thing that always stops me isn't my legs or fatigue... but my butt. I have experimented with 5 different saddles, and it seems that something is rubbing against me until it hurts so much that I cringe and bear it until the end of the 150. I weight 188, so I don't think it's my weight. I've also tried shammy lube, but I've never carried enough around with me to keep refreshing it.
I'm thinking perhaps an aero bar will help because my friend who uses them tells me that for long rides, it can be used to take weight off your butt. Sure, I can stand, but I can only do it for so long.
What do you guys think? Do aero bars help with long distance, especially when my limiting factor is sitting for too long.
Lamabb is offline
Reply
Old 04-22-13 | 06:28 AM
Machka's Avatar
In Real Life
Titanium Club Membership
20 Anniversary
Bikes: Lots
Have you tried riding without padded shorts? Just use the shorts that look like cycling shorts, but don't have any padding in them.
Machka is offline
Reply
Old 04-22-13 | 09:37 AM
Carbonfiberboy's Avatar
just another gosling
15 Anniversary
IME aero bars don't help with saddle issues. If anything it's the other way 'round. 5 saddles is not nearly enough. Think about exactly what's rubbing you and start testing saddles that don't have anything in that area. I'm not a no-padding guy, but IME it is true that there are certain shorts pads that match certain saddles and others which do not. I carry a 35mm film can with extra butt cream in it. If it takes more than that, you aren't close on the saddle choice. So where does it rub?
Carbonfiberboy is offline
Reply
Old 04-24-13 | 10:32 AM
Lamabb's Avatar
Doesn't ride enough
Riding without shorts only worsens it. I think it has to do with my habit of moving around on the saddle a lot. Every so often (more than you) I feel like alleviating the pressure, so I kind of hop to a subtly different position on the saddle. After between 80 to 100 miles on the saddle, it starts to hurt. If you run your finger up your leg, as soon as your skin curves at the start of your butt is where it hurts. I never understood why no one else ever had this problem, and it makes rides longer than 150 nearly impossible for me.
Lamabb is offline
Reply
Old 04-24-13 | 10:58 AM
I have that exact problem if I ride a bike with not enough setback, or on long rides if I don't use chamois cream.
Commodus is offline
Reply
Old 04-24-13 | 11:14 AM
Bikes: Metabikes Metaphrastic Rival
don't know about aerobars but in your case, something like this might work:
https://www.meta-bikes.com/randoedition.html
henkie327 is offline
Reply
Old 04-24-13 | 11:15 AM
15 Anniversary
I get that exact problem from saddles that are too wide in the nose or don't have a sufficiently smooth roll-off between top and skirt. What saddle are you riding?
Reply
Old 04-24-13 | 11:23 AM
^^ that's a good point I have that problem on saddles like that too. I have a Fizik Pave that's very 'abrupt' on the sides and it leads to such chafing.
Commodus is offline
Reply
Old 04-24-13 | 12:03 PM
photogravity's Avatar
Hopelessly addicted...
Bikes: 1949 Hercules Kestrel, 1950 Norman Rapide, 1970 Schwinn Collegiate, 1972 Peugeot UE-8, 1976 Raleigh Sports, 1977 Raleigh Sports, 1977 Jack Taylor Tandem, 1984 Davidson Tandem, 2010 Bilenky "BQ" 650B Constructeur Tandem, 2011 Linus Mixte
+1 What saddles have you been riding up to now? If you can remember all 5, that might be useful information.
photogravity is offline
Reply
Old 04-24-13 | 12:06 PM
Administrator
20 Anniversary
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Could be the saddle but also the saddle position/way it's adjusted. Since you tried five, my bet is it's the position.
StanSeven is offline
Reply
Old 04-24-13 | 12:22 PM
Randomhead
when my butt really hurts, I shift up a gear, helps a little.
Have you tried chamois cream?
unterhausen is offline
Reply
Old 04-24-13 | 12:26 PM
RaleighSport's Avatar
Hogosha Sekai
10 Anniversary
Bikes: Leader 725, Centurion Turbo, Scwhinn Peloton, Schwinn Premis, GT Tequesta, Bridgestone CB-2,72' Centurion Lemans, 72 Raleigh Competition
What saddle are you using?
RaleighSport is offline
Reply
Old 04-25-13 | 03:39 AM
Machka's Avatar
In Real Life
20 Anniversary
Bikes: Lots
I also move around on my saddle quite a bit. It's one of the challenges I have with riding a tandem ... I have to sit still.
But one reason for hopping around on the saddle is a poor bicycle fit. Another reason is poor core strength and poor cycling fitness. I move more when my saddle isn't quite the right height (often too low, or with the nose pointed down too far), and when I'm a bit out of shape.
If those aren't the problems, then I'd look at the saddle. You might need something more suited to you.
Machka is offline
Reply
Old 04-25-13 | 09:16 AM
Lurking Under a Rock
is the rubbing always on one side? and in the same spot? you may have some asymmetry and/or pedal stroke issues that can be addressed with cleat shims.
ronocnikral is offline
Reply
Old 04-25-13 | 05:10 PM
Lamabb's Avatar
Doesn't ride enough
I have ridden on:
1. Cannondale Caad9 5 stock saddle (not comfortable at all, quick replaced)
2.
WTB SST Comp, stock on the LHT
3. Stock Mountain bike saddle (decent, but not for long riding)
4. Brooks Flyer
5. Selle Anatomica's Titanico
Lamabb is offline
Reply
Old 04-25-13 | 08:57 PM
15 Anniversary
So try the Performance Forte Classic and the Specialized Romin. I'm sure others will chime in.
Reply
Old 04-25-13 | 09:05 PM
Machka's Avatar
In Real Life
20 Anniversary
Bikes: Lots
Is one of your legs shorter than the other?
Do you experience this pain equally on both sides or just one?
Can you post a photo of your bicycle? And then a photo of you on your bicycle?
Machka is offline
Reply
Old 04-26-13 | 08:09 AM
rhm's Avatar
rhm
multimodal commuter
I don't think aero bars would help, but what do I know. I don't have the problem you're having. If you think they might help, it's worth a try.
I'm inclined to think it's a setup problem of some kind. Machka's questions --especially regarding symmetry-- seem on point.
You seem to have tried a good variety of saddles. Were any of them really hard, like a new Brooks Professional?
rhm is offline
Reply
Old 04-27-13 | 02:59 PM
Bikes: 8
Just means your hands wont be supporting your weight for a little while..
as the weight goes on your fore arms where the pads are..
and being so bent over the frontal area you push through the air will be a bit smaller..
fietsbob is offline
Reply
Old 04-27-13 | 07:10 PM
trescojones's Avatar
I have ridden on:
2.
4. Brooks Flyer
They do all seem a bit narrow, I found many saddles were concentrating force in some areas until i tried an old ideale.
the titanico and flyer can hammock which might make things worse. Some people find the floppe selle's a bit much for a lower more agressive position, the movement can be problematic. A wider giles berthoud perhaps. I found the narrower brooks were not my friend. I now use a b66 which is comfortable and sit on the center section even though the back is huge and the saddle looks funny on my setup. Also my left leg is very slightly shorter than mmy right, it took a thin insole in one shoe to get rid of similar problems and i found i could spin so much more easily
trescojones is offline
Reply
DrDyno
Fifty Plus (50+)
42
10-06-18 11:58 AM
beachape
Road Cycling
19
08-18-13 06:32 PM
hhnngg1
Road Cycling
11
12-05-11 12:24 PM
Pontoons
Triathlon
8
10-14-11 09:43 AM
rotti
"The 33"-Road Bike Racing
28
09-07-11 07:56 AM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
