Microshift thumb shifter question
Old 04-26-13 | 11:19 AM
<deleted>
Raging_Bulls is offline
Reply
Old 04-26-13 | 12:32 PM
The front shifter isn't indexed and the rear is a self-contained unit so removing the levers from the mounts won't upset anything. See if the mounting bosses can be loosened and reoriented a partial turn on the clamp band. I know the shifter bodies can be turned 180° on their bosses but that's probably too much.
HillRider is offline
Reply
Old 04-26-13 | 12:33 PM
Looigi's Avatar
Thumb shifters go under the bars, not on top. Looks like you got them reversed left to right too.
Looigi is offline
Reply
Old 04-26-13 | 01:02 PM
songfta's Avatar
Cycling Skier
Bikes: 2019 Moots Vamoots DR, 2008 Pedal Force ZX3, 2006 Jamis Eclipse, 1997 Marin Indian Fire Trail
Old-school thumb shifters go over the bars, and these are somewhat old-school in look-and-feel.
I'm not sure whether they can be rotated on their mount points to achieve the alignment that the OP wants, but it's worth a try.
songfta is offline
Reply
Old 04-26-13 | 02:39 PM
Looigi's Avatar
Originally Posted by songfta
Old-school thumb shifters go over the bars, and these are somewhat old-school in look-and-feel...
You have a point there. I was thinking more like trigger shifters.... Still looks like the cable pull direction is wrong though...
Looigi is offline
Reply
Old 04-26-13 | 03:41 PM
<deleted>
Reply
Old 04-26-13 | 04:00 PM
Titanium Club Membership
15 Anniversary
Lever systems vary, and I don't know most of them by hear. But it's common construction to locate the mechanism on the body via a pin which engages a pocket in the body.
Remove the entire lever unit from the clamp body, and see how the back plate is anchored. You might be able to drill a new pin hole in the body, or dremel pockets to accept the unit.
Also I know you already own these, but some time back SunTour (I think) made levers where the lever itself clamped to a shaft, and allowed the position vs. the index click to be adjusted. If it's rally an issue you might track down one of these.
FB
Chain-L site
FBinNY is offline
Reply
Old 04-27-13 | 07:56 AM
<deleted>
Reply
Old 04-27-13 | 01:09 PM
Looigi's Avatar
Originally Posted by Raging_Bulls
I suppose that may be down to the angle at which I took the photo. The "cables" you see are actually the brake lines. I guess all the black doesn't make it obvious at first sight.
The shifters aren't connected yet, but their cables will go in the bits that run parallel to the brake lines, just below them....
Yep. I see/understand it now. Thanks.
Looigi is offline
Reply
taguy4
Classic & Vintage
1
05-28-18 02:29 PM
arcocelli
Bicycle Mechanics
5
01-31-16 09:19 AM
davidjuliano
Road Cycling
2
04-09-12 06:08 PM
spymaster
Classic & Vintage
7
04-28-10 10:52 PM
divineAndbright
Bicycle Mechanics
4
01-14-10 09:15 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
