Track Cycling: Velodrome Racing and Training Area Looking to enter into the realm of track racing? Want to share your experiences and tactics for riding on a velodrome? The Track Cycling forums is for you! Come in and discuss training/racing, equipment, and current track cycling events.
Numbness
Old 05-09-13 | 08:43 AM
Jaytron's Avatar
Brown Bear, Sqrl Hunter
Bikes: CAAD 10 4, Dolan DF4, Fuji Track Classic
Numbness
This may not be the right forum to ask this, but I had some numbness... in the nether region after racing last night.
Weird thing is, my road bike and track bike were fit by the same guy, and I'm using the same seat on both bikes. The fits are slightly different, seat more forward on the track bike but with a longer stem. The seat is slightly lower on the track bike to accomodate spinning. I have a positive stem with compact drops on my track bike, so it's not really that agressive.
I have no problems with my road bike. Any tips? I'm going to try tilting the saddle down slightly to see if that helps at all but theoretically everything should be fine since I have the same seat on my roadie right?
Jaytron is offline
Reply
Old 05-09-13 | 08:54 AM
Not the Slowest's Avatar
Bikes: 2002 Seven Axiom
My experience with ANYONE having numbness "there" is simple. it's usually the saddle angle
A) Make sure the saddle is level (with a level)
B) Make sure the seat post or saddle have not moved since the fitting
C) Remember you are in the drops and track drops will put you in a much more forward leaning, crunching position than say the usual road bike fit.
D) Not all saddles will work well on the Track
Blah Blah, Okay I would check with your fitter, that's always the best place to start. Most likely he will do what you are doing, but isn't that why you paid him.
All fitters will take the time to correct=tweak a fit. That is what I would do, but yes I think the saddle a tad down "may" do it.
Not the Slowest is offline
Reply
Old 05-09-13 | 10:23 AM
Jaytron's Avatar
The saddle was level (with a level).
I'll look into different saddles too if the problem persists.
My fitter was involved in a crazy bike accident and is recovering, I'd rather not bother him with my fitness issues now
Jaytron is offline
Reply
Old 05-09-13 | 10:24 AM
Brian Ratliff's Avatar
20 Anniversary
Bikes: Three road bikes. Two track bikes.
On the track you are pulling an extra half g or so in the bankings depending on speed and turn radius. This might be contributing. Your 150lb body might weigh over 200lbs through the turns.
Also, do you have trouble standing during a race (some people do)? Just standing every once in a while usually makes any numbness go away.
Cat 2 Track, Cat 3 Road.
"If you’re new enough [to racing] that you would ask such question, then i would hazard a guess that if you just made up a workout that sounded hard to do, and did it, you’d probably get faster." --the tiniest sprinter
Brian Ratliff is offline
Reply
Old 05-09-13 | 10:50 AM
Sqrl
I use a TT Saddle on my track bike, mostly because more of my weight in on the perenium instead of the sit-bones, because you are generally rolled further forward. That said, your butt is pretty much as personal as it gets. Some people I know do very well with a cut-out saddle.
Originally Posted by carleton
Doing one-legged squats while holding chickens in each hand will make someone strong...that doesn't mean it's the best way to train for track racing.
Originally Posted by Nagrom_
That would be spectacular. A trail of blood and sealant.
David Broon is offline
Reply
Old 05-09-13 | 12:14 PM
zizou's Avatar
15 Anniversary
I have major comfort issues if i dont use chamois cream - I dont need to wear chamois cream for long all day rides on my mountain or road bike, but an hour at the track and it is a essential. Also wearing assos shorts help too, i think due to there being more padding towards the front.
zizou is offline
Reply
Old 05-09-13 | 12:21 PM
carleton's Avatar
Elitist
+1
carleton is offline
Reply
Old 05-09-13 | 09:17 PM
Kayce's Avatar
Another non-equipment issue may be your spin. Is your seated spin really clean, or do your hips bounce? If there is bounce you are putting extra pressure on your bits every time you bounce down.
Kayce is offline
Reply
Old 05-09-13 | 11:43 PM
Jaytron's Avatar
I think it's pretty clean.
What I've noticed though, is that sometimes when I transition from OTS to seated, I don't go far back enough. This puts pressure on the not so happy bits. I noticed it today when I was out at the track. The nose down definitely helped though, no numbness today.
Jaytron is offline
Reply
Old 05-10-13 | 06:13 AM
queerpunk's Avatar
aka mattio
Bikes: yes
A red flag goes up in my head when I see "seat more forward" + "seat lower": that seems at odds with me. Rule of thumb that I'm familiar with is, when your saddle goes forward, it oughta go up in order to keep leg extension the same. Keeping it at the same height and moving it forward effectively lowers it; lowering it further could be a real change, and possibly - possibly - contribute to some of your numbness if, due to low saddle and awkward weight distribution, you're putting more of your weight on your saddle.
Mark your current fit, but try raising your saddle a little.
queerpunk is offline
Reply
Old 05-10-13 | 08:49 AM
kato7997's Avatar
Also a lower saddle usually means more of the weight balance will move from your hands to the saddle.
kato7997 is offline
Reply
Old 05-10-13 | 11:18 AM
Jaytron's Avatar
His reason for lowering was because it would be easier to spin at higher rpms. Is that correct?
Jaytron is offline
Reply
TheRealFaux
Fitting Your Bike
3
04-25-14 12:38 PM
Jaytron
32
11-20-13 11:36 PM
mcafiero
3
07-01-11 11:30 AM
seejohnbike
4
10-13-10 01:27 AM
Pt_Lumberjack
4
03-03-10 07:40 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
