Playing With Tire Pressure
Old 05-10-13 | 06:57 AM
TandemGeek's Avatar
hors category
20 Anniversary
For sh*ts and giggles, when I put our conventional wheels back on the Calfee I only went to 100psi vs. 135psi on our 700x25 Vredesteins; lets call it the lower-limit for those tires and our 275lb combined team weight.
Handling: Significant reduction in stability and tracking through the corners.
Comfort: Quite plush up front, even over the broken pavement sections. Debbie said nothing and was unware that I'd changed the pressure.
Rolling Resistance: Definitely more drag / less responsive when climbing above 5% grades, but otherwise not much difference and no real change to average speed over our normal loop.
Out of the Saddle: Much more "springy" and heavy-feeling.
TandemGeek is offline
Reply
Old 05-10-13 | 10:41 AM
waynesulak's Avatar
Bikes: Custom 650B tandem by Bob Brown, 650B tandem converted from Santana Arriva, Santana Noventa, Boulder Bicycle 700C, Gunnar Sport
Matches my experience that with good tires the lower pressure makes the ride feel much slower before actually effecting speed very much.
Observation - 25mm at 100 psi is pretty low - you do have smooth roads.
waynesulak is offline
Reply
Old 05-10-13 | 11:35 AM
TandemGeek's Avatar
hors category
20 Anniversary
It's a beautiful thing....
Reply
Old 05-10-13 | 04:27 PM
Carbonfiberboy's Avatar
just another gosling
Titanium Club Membership
15 Anniversary
For some time, I've been playing with the idea that, given load and tire width, it should be possible to calculate the appropriate tire pressure. If we go:
((all-up weight)*8)/(nominal tire width) = minimum pressure
that's somewhere close. So for us, in summer trim, that's 350*8/25=112. We use 120 and never pinch flat. Ride is a little stiff, but it goes where I point it.
This falls apart at light rider weights, though I don't see quite why, f.i: 150*8/23=52. Which might be correct in a way. A 125 lb. rider probably wouldn't normally pinch flat at 52 lbs., but the bike would handle terribly.
At heavy weights, it seems decent, f.i: 450*8/32=112.5, though it might be hard to find a 32c with that high a maximum pressure. And about there, one starts to run into rim problems.
Thoughts?
Carbonfiberboy is offline
Reply
Old 05-10-13 | 05:13 PM
zonatandem's Avatar
20 Anniversary
We run 120 PSI on Maxxis Re-Fuse.
On Pasela TGs on rear of tandem cut down from 120 to 110PSI at stoker'srequest.
We are a sub-250 lb duo.
zonatandem is offline
Reply
Old 05-11-13 | 07:09 AM
PMK's Avatar
PMK
Bikes: 2006 Co-Motion Roadster (Flat Bars, Discs, Carbon Fork), Some 1/2 bikes and a couple of KTM's
Interesting calculation and differs considerably from the chart that has been posted here on occasion.
PK
PMK is offline
Reply
Old 05-11-13 | 08:44 AM
gracehowler's Avatar
Rod & Judy
Bikes: Specialized S-works E-5, Davinci joint venture , CoMotion Pangea
Interesting formula CF, we are relegated to 26" wheels, run narrow as we can get, 26 to 28mm, formula says 85 for us, a 260 lb team. We tend to run 90-95 psi. Started out three years ago, more at 105-115 psi , and interestingly enough, we had more flats. Sure seems to perform better at higher psi, but our roads are terrible, so we both enjoy the softer ride.
R&J
gracehowler is offline
Reply
Old 05-11-13 | 09:30 AM
waynesulak's Avatar
Thoughts?
How did you decide on a factor of 8?
Reply
Old 05-11-13 | 10:44 AM
Bikes: Spec. Roubaix, Cannondale RT2, BF NWT, BF tandem
I suspect it is not a linear function.
Tom Spohn is offline
Reply
Old 05-11-13 | 03:29 PM
waynesulak's Avatar
Given that the area of a circle's relationship to its diameter I agree.
Reply
Old 05-11-13 | 05:40 PM
15 Anniversary
Empirical.
Reply
Old 05-11-13 | 05:42 PM
15 Anniversary
Correct. We have a wide range of empirical values, from this forum and the 41. Given the number of engineers and maths on this forum, it seems to me someone should be able to fit a curve through those points. Rim width might also be a factor.
Reply
Old 05-11-13 | 06:39 PM
waynesulak's Avatar
Below is the chart posted by twocicle in the 19mm rim thread:
I have not measured the interior width of a Dyad but Velocity lists the outside measurement at 24mm. If we subtract 3mm (and 2mm might be more accurate) on each side then the interior rim width is 18mm. Using the chart above that would make a 25mm tire marginal. 25mm tires may work well on Dyads but they may also be subject to some additional pinch flats and sidewall damage. On the other hand carefully keeping the tires fully inflated may avoid problems.
It will be interesting to read TandemGeek's results.
Reply
jtburn
Road Cycling
16
04-07-17 02:03 PM
Roadie607
Road Cycling
38
02-25-14 01:28 PM
Tandem Tom
Tandem Cycling
7
07-31-12 09:20 AM
FasterNearGirls
Road Cycling
61
05-05-11 07:20 PM
c_dinsmore
Road Cycling
5
04-02-10 11:21 PM
Trackbacks are Off
Pingbacks are Off
Refbacks are Off
