Toe Clips—universal?
Bikes: '85 Pinarello track, '74 Peugeot PR-10 L, '73 Motobecane Mirage (RIP 2014), '81 Raleigh Roadster (RIP 2013), '88 Peugeot Santé Fixed (RIP 2014)
Hi all,
I'm installing a set of Lyotard 45s on my SL cranks and wanted to add toe clips (the old steel types with the leather straps). I'm wondering if its a universal fit- could I just buy an old campy set or a newer MKS set?
Thanks,
Ash
Thanks,
Ash
While pedal and toe clip designs are not universal, there is one standard that convers the vast majority. Your Lyotard fit this category. Most non-standard designs are easily recognizeable as non-standard, such as the various low profile, aerodynamic pedals of the early and mid-1980s. I beleive that the only concession for toe clips on the 45s is that you have to use a backing plate and nuts.
They also come in different sizes for different foot/shoe size! S,M,L... Proper foot placement on the pedals is important!
'75 Fuji S-10S bought new, 52k+ miles and still going!
'84 Univega Gran Tourismo
'84 Univega Viva Sport
'86 Miyata 710
'90 Schwinn Woodlands
Unknown brand MTB of questionable lineage aka 'Mutt Trail Bike'
Plus or minus a few others from time-to-time
'86 Miyata 710
Yeah, make sure you get the right length. BTW, If you happen need a Large, (11-12?) size I have a set of NOS of chrome Balillas you can have for the price of shipping if you like. Just a thought. They're just sitting here doing zip.
Also remember to check the front wheel turning clearance - Some cages will scrape the front tire when turning sharply...
I would think that most bikes have enough toe overlap to scrape the front tire when turning sharply and it is really not an issue that needs to be considered. The only bikes that don't have toe overlap have exsessively extended forks that would seemingly cause overly slow steering.
Old fart
If the Lyotard pedals don't have an opening in the center of the front cage plate (the mod. 45 cage design seems to have changed several times over the years), then the Campy toe clip won't fit.
You should have no problems with a standard MKS or Christophe toeclip, though, as long as you avoid the models with the wide mounting bolt pattern.
The only one I really had a problem with toe overlap was my Univega - So I went to medium cages instead of extra large - I had to do this because I often ride at slow speeds on twisting paths in the State Park...
Hey guys, thanks for all the info and responses. Im
a size ten shoe, and as much as I'd love to accept Balillas, I think they'd be a bit big for me... Then again I only ride in my boots, so they'd probably end up being ideal. Thoughts? You guys are too kind!
BOOTS? What kind of boots?
Haha. I knew someone would say something. I ride in the city and longer 50+ mile rides in my RM Williams and Wolverine boots. I've worn nothing else for twenty years and they're the most comfortable on my foot. I'm a little crazy, I know. I'm a photojournalist, so I need to be dressed for all occasions- board room to breaking news. Boots for that bill.
Hmmm. I guess I'll have l ride in my RMs with clips then. Or just ride without them altogether. Thanks for your kind offer all the same!
Bikes: '73 Raleigh RRA, 1986 Trek 500 commuter
You might be able to get away with half clips or if those wouldn't work, perhaps power grips? Never used either myself.
Does it really make that much difference?
Underground
Singlespeed & Fixed Gear
5
03-23-10 11:16 AM
