Inner tube & tire problem
Bike Recycler
Bikes: Huffy Cruiser
I just got a bike given to me and it says 26 x 2.00 on the tire. But to me it seems to be the wrong tire. It seems awful loose on the rim and I can take it off and on without any effort. I measured the rim and it is 23" in diameter. Is this right.
Also, how do I fit an inner tube to the wheel. I am afraid to go and get a 26 x.200 inner tube and find out it is just as loose as the tire. Is there a way to measure to make sure that I have the proper tire and tube for the frame.
Thanks...Greg
Thanks...Greg
Don't mean to be rude Greg - but seriously suggest you take the bike to a shop and / or watch someone else do this first before tackling it yourself. The tire is probably the right size, you're just not familiar with sizing conventions and the basics of changing a tire and tube.
A repair will run you about $15. Believe me - you can inadvertently do a lot more damage than that trying to tackle things yourself if you don't know what you're doing. Scrapped rims, pinched tubes and stripped axle bolts are just a few. Everything is easy when you know how - but for every right way to do something there's usually multiple ways to screw things up.
Bikes: Specialized, Trek, Diamondback, Schwinn, Peugeot
+2 on what Burton said. 26x2.00 is a typical size. Various tires seem to fit tighter or looser these days. If you look carefully you should be able to find the marking on the rim to confirm it is a 26".
Check for a bicycle co-op in your area. They are nicer to newbie mechaincs than many bike shops.
-SP
-SP
Bike Recycler
Bike Recycler
-SP
-SP
I checked the rim and it says 26 x 1.50 and again the tire says 26 x 2.00
Thanks..
Bike Recycler
Thanks..
The tube is designed to fit the tire, not the rim. Typically you should be looking for a tube size that covers 1.95 to 2.3 to use with that same tire.
Tube sizes are pretty standard - so are rim sizes. Any size stamped on the rim DOESN'T refer to the actual rim diameter.
Still suggest you drop by a shop - you have to buy a tube anyway - whats the problem?
Bike Recycler
Mechanic/Tourist
Bikes: 2008 Novara Randonee - love it. Previous bikes:Motobecane Mirage, 1972 Moto Grand Jubilee (my fave), Jackson Rake 16, 1983 C'dale ST500.
The 1.5 vs 2.0 is irrelevant. On the rim especially the listed width has little to do with the actual width. What is important is that both the tire and rim say 26. It is quite common for 2" wide 26" tires to fit loosely when uninflated - be grateful you are not dealing with the opposite problem. Get some instruction in-person on tire/tube installation, or study a bunch of videos.
I strongly doubt you have a wrong size since the nearest sizes are over 10mm different than the 559 ISO bead diameter of your rim and tire so the tire couldn't mount at all.
It seems that you have the best of both worlds, ie mounts easily, and holds well when seated, so stop obsessing over nothing and enjoy it.
FB
Chain-L site
One accurate measurement is worth a thousand expert opinions - Adm Grace Murray Hopper - USN
FB
Chain-L site
Bike Recycler
looseness or tightness on a rim for the right size tire is a function of rim design. Rims with center wells leave more room for the tire to shift across and produce slack at the far end. Shallow rims don't which is why we see so many "can't mount my tight tire" threads on this forum.
Really Old Senior Member
Bikes: 87 RockHopper,2008 Specialized Globe. Both upgraded to 9 speeds. 2019 Giant Explore E+3
I bought a couple cheap Kenda Kwest k193's (26x1.50) for a CL flipper that were sloppily loose on a pair of old steel rims.
I don't know if it was the rim, wheel or both.
I had to take extreme care to keep the tube from blowing out under the bead when inflating.
What tire are you using?
Mechanic/Tourist
Old steel rims did not have the "hook bead" common on more modern rims and sometimes do not hold as well at higher pressures.
Bike Recycler
I get a lot of bikes given to me to refurbish and give away but all they are only ever from the Big Box Stores. But they will do just fine. This is the first time that I have ever found a rim and tire that sloppy. But you learn something new every day.
Mechanic/Tourist
I've been out of the retail loop for a while but I'm not aware of steel rims having hook bead. I do know that cheaper mountain bikes from at least as late the 80's did indeed have non-hook bead steel rims.
From: England, currently dividing my time between university in Guildford and home just outside Reading
Bikes: Too many to list here!
I've got a bike with a 559mm 26" steel rear rim with a hooked bead, so they do exist.
late 80s is when i entered the retail loop
and steel rims did have hook beads
as far as i can recall
SamSam
Bicycle Mechanics
15
01-31-13 02:06 PM
