Advertise on Bikeforums.net
Page 1 of 2 12 LastLast
Results 1 to 25 of 32
  1. #1
    Raleigh20 PugFixie, Merc LittlePixel's Avatar
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    So my LocalBikeShop FINALLY finished lacing the SRAM hub into the rim on Friday so I've been able to finish the build and take her for a spin; needed some adjustment to get the steering non-skittery but she's running like a dream now. The frame was stripped, blasted, new v-brake bosses added and sprayed/laquered/decaled by the good folks at M.Steel Cycles, Newcastle who did a wonderful job
    http://www.msteelcycles.co.uk/
    Ok here's the anal bit
    Original Parts used:
    Frame
    Frame Bolt
    Rear Rack (Sprayed with matt-black 'barbecue paint')
    Handlebars ( " " )
    Parts list:
    2x 406 Diamondback Black Alloy Rims
    2x Schwalbe Stelvio 'Dahon Speed edition" tyres
    Shimano Deore V-Brakes front and rear.
    Chili Works 1" threaded Suspension fork (cheap and cheerful and a bit 'divey')
    Tange 1" threaded headset
    Kalloy 1" Angle-Adjustable quill Stem
    Second hand Scott ATB Brake handles (eBay)
    Cane Creek ergonomic bar-ends
    Shimano UN-72 Bottom Bracket, held in with Phil Wood rings
    Shimano Tiagra Chainset w.52 tooth cog and long arms (175mm?) (will remove second ring when I get pre-ordered singlespeed bolts)
    Shimano SPD clipless pedals
    SRAM Spectro 7 hub and shifters
    SRAM silver link chain
    Selle Italia lightweight road saddle
    Altura Saddlebag
    KF seatpost clip
    Ultralight suspension seatpost (can't remember manufacturer but was not a cheapy!)
    Cateye Lights
    Marware iPod clip
    New Raleigh headpost badge from eBay
    No-name lightweight mudguard (rear)
    Cateye Velo 5 cycloputer
    You can see a full gallery of my wee beauty at:
    http://littlepixel.info/twenty/Anoth...y/Gallery.html
  2. #2
    Senior Member randya's Avatar
    Join Date
    Jul 2003
    Location
    in bed with your mom
    Posts
    14,196
    Nice! Does it handle better? It looks like the suspension fork has raised the front of the frame and changed the wheelbase and fork rake angle a bit. I should think that would improve the handling.
  3. #3
    Car-Free Flatlander Stacy's Avatar
    Join Date
    Sep 2004
    Location
    Below 14th Street
    Posts
    1,973
    Beautiful!
    Just out of curiosity how much does it weigh?
  4. #4
    Join Date
    Nov 2004
    Location
    Virginia
    Posts
    5,383
    That looks really nice. Fine job!
  5. #5
    www.getafolder.com wpflem's Avatar
    Join Date
    Jan 2005
    Location
    Santa Fe & Gallup, New Mexico
    Posts
    400
    Nice work!
  6. #6
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    Quote Originally Posted by randya
    Thanks - glad you like it! I haven't really ridden it that far yet but it seems very lively and responsive. Though saying that the ride on a stock twenty is pretty good too. My first ride was a bit hairy so I increased the angle of the stem. It felt very 'tiller' like and unstable but just a few degrees and an inch or so height added to the bar and it made all the difference...
  7. #7
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    Quote Originally Posted by Stacy
    Beautiful!
    Thanks for the kind comments. I'm especially happy with the way the yellow tyres set off against the black wheels and forks. As for your question - hmm it's hard to say as I don't have a good way of weighing it. I picked it up today and it felt kinda ok weightwise. Not as heavy as I was expecting but not light like I'm sure a Dahon must seem. It probably weighs a wee bit less than than it did unmodified but the light rims, mudguards, saddle and seatpost are offset against a heavier fork and hub so its diet helped to cover its new heavy bits.
  8. #8
    Join Date
    Nov 2003
    Location
    Forest Park Il
    Posts
    929
    It looks very nice . I am sure you will enjoy it.
  9. #9
    Senior Member cheg's Avatar
    Join Date
    Sep 2004
    Location
    Seattle
    Posts
    839
    Very nice. I love the black wheels and that's a really nice paint job. The rear V-brake is great also.
    One comment - you may end up wanting a front fender to keep the grit out of your face when riding in the rain. My 20 has Bike Friday fenders, but they are a bit expensive if you get them new. Recumbent fenders may work. Check out Gaerlan for some ideas. You may also want a waterbottle cage for distance riding.
    Do you plan to travel with the bike?
  10. #10
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    Quote Originally Posted by cheg
    Thanks - I thought you'd appreciate it.
    I actually do have a front mudguard but opted not to fit it right now for reasons of pure aesthetics. More honestly put - it looks a bit silly with those slick tyres. Neccessity will probably dictate I fit it very soon though as arriving at work with spots of mud like a dalmation is bound to wear a little thin. But I'll have a look at your links as a skinnier guard is what I'm really after. I had to abandon the plan to use the black skyway wheel as its axle was not long enough for the forks, plus the fact those tyres didn't sit very safely on the rim because of their lack of inner flanges.
    Do I plan to travel? Well I do an 8 mile round commute every day to work and plan to use her on that for a while. My partner and I also have a semi-plan to get a VW camper so if we do this one and the purple stowaway you probably saw in a couple of the shots will come with and be our local day transport wherever we go.... Thanks again for your help and inspiration - if I hadn't seen yours none of this would have happened!
    Huw
  11. #11
    Join Date
    Sep 2004
    Location
    Seattle
    Posts
    839
    Quote Originally Posted by LittlePixel
    They do look better without the front fender and I sometimes take it off on nice days.
    Huw
    I'm glad you got inspired. That is a really nce result and I'm sure you will enjoy it.
    I was wondering more about whether you plan to pack it for air travel. My website is out of date in that regard. When I switched to the different bars and rear wheel I had to invert the frame in the case to make it fit. I'll update the site next time the bike is at home. I've left it in Florida since the beginnning of the year because of frequent business trips there.
  12. #12
    Join Date
    Nov 2003
    Location
    Forest Park Il
    Posts
    929
    Despite the looks you might want to go with the fattest front fender you can get if it is too skinny water and dirt will get by.
  13. #13
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    I was wondering more about whether you plan to pack it for air travel..
    Oh right - I see what you mean...
    Maybe - I haven't really considered it but I suppose I could - especially if I convert the purple stowaway too. Then me and my girlfriend could fly out to europe with them. But I suppose it wasn't a prime consideration in the build.
  14. #14
    Join Date
    Nov 2003
    Location
    Forest Park Il
    Posts
    929
    Purple stowaway? There's a picture to see!
  15. #15
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    Quote Originally Posted by james Haury
    It's in the last picture on the gallery...
  16. #16
    Join Date
    Nov 2003
    Location
    Forest Park Il
    Posts
    929
    Got it . I was thinking Dahon stowaway not raliegh.
  17. #17
    Join Date
    Dec 2004
    Location
    New Hampshire
    Posts
    52
    That's awesome! Great idea with the iPod mount.
    I've slowly been building up my Twenty over the winter. I haven't bothered to paint it yet, still trying to get all of the mechanicals worked out. I'm hoping to bring it out for it's maiden voyage today. I had plans to install a front derailleur, but I scrapped it when I realized that I don't use it enough to make it worth the hassle. I need to get it out to work out the bugs. I'm still trying to decide on handlebars also, right now it has a set of Scott AT-3 bars. I'm debating between that, bullhorn and H-type like yours. I'm also considering building a fixed rear wheel.
    Got to get some pictures up...
  18. #18
    Join Date
    Jan 2005
    Posts
    1,236
    Nicely done! May I ask you where you got those tires and for what price? Do they have more?
    DG1
  19. #19
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    Quote Originally Posted by dannyg1
    DG1
    Thanks to everyone for all the positive comments. Been looking at Harris Cyclery today with a view to getting a 16 or 15 tooth sprocket for the hub so I can get a bit more speed. I've removed the redundant chainring and all is running sweetly.
    In answer to your question about the rubber: The tyres (tires) are 406 1 1/8" Shwalbe Stevio folding tyres. The fabulous 'mango' stripes are to go with the paint on a Dahon Speed Pro (http://www.dahon.com/speedpro.htm) for which the tyre has been manufactured as a special edition. They weren't cheap but I saw them for sale and *had* to get a pair. Have them inflated to 110 psi and they just roll and roll.
    Here's the bike they're *meant* to be for:
    I got them from this UK mailorder site "Cyclesmart" (which is handy living in London); not sure they'd ship overseas but I'm sure a good Schwalbe stockist near you may have them or be able to order them in for you....
    http://www.cyclesmart.co.uk/shop/ind...s/TYS1902.html
  20. #20
    Join Date
    Sep 2004
    Location
    London UK
    Posts
    1,929
    My bars are actually the original chrome/steel originals sprayed black - they're not bad if still a bit heavy - narrower than a lot of bars and the big rise means there's less need to have a lot of stem protruding from the headset; Sadly though the width of the twist shift makes the right-hand brake lever a little hard to reach because it meant the brake fixing had to clamp a little way around the curve of the riser.
    I'm begining to think I'd like to get some "Tora Tora" bullhorns and road levers as I seem to predominantly use the bar-ends - though how that would work in conjunction with the twist shifter is less apparent to me... Anyone got any ideas that wouldn't look stupid?
    (LittlePixel hasn't actually *listened* to any music on his iPod whilst riding yet - he sees it as a 'summery activity' on quiet roads and isn't sure whether to endorse this contentious practice...)
    Quote Originally Posted by ChrisM
    I'd Love to see some pictures of yours: How did the maiden voyage go?
  21. #21
    easy racer
    Guest
    Huw
    Have you thought of using mudguards from HP Velotechnik's Grasshopper recumbent.
    You may be able to get them from: www.bikefix.co.uk/grasshopper.html
    They certainly look quite good, and hopefully won't spoil your bike's cool looks.
    Hopefully this will look as good one day... maybe?
  22. #22
    easy racer
    Guest
    Can I also ask what length UN72 Shimano bottom bracket should I get to fit into the BB shell, with Phil Wood rings?
    Thanks...
    Take it Easy,
    EZR.
  23. #23
    floor sleeper
    Join Date
    Jun 2002
    Location
    Here and there in the US
    Posts
    1,037
    Quote Originally Posted by easy racer
    Thanks...
    Take it Easy,
    EZR.
    What kind of hub are you using? I just found that a UN72 113mm with a SRAM Spectro P5 works lovingly well on the Twenty. It did some math, and the math seems to have been right. yay.
  24. #24
    easy racer
    Guest
    The hub is a 126mm wide 5-speed derailleur gear, lovingly forced into the rear triangle, so chainline isn't that important.
    So the 113mm BB should be fine for my needs.
    Thanks, and Take it Easy,
    EZR.
  25. #25
    Join Date
    May 2004
    Posts
    111
    Is that a non-folding twenty with 406 wheels? I thought they all had 451...
Posting Permissions
  • You may not post replies
  • You may not edit your posts
