Bicycle misnomenclature
Quoted: 7348 Post(s)
Liked 2,470 Times
Fulcrum, a word Sturmey Archer misused to mean cable stop.
Main triangle, which refers to the quadrilateral formed by the top tube, head tube, down tube and seat tube.
Rear triangle, which refers to the array of two seat stays, two chain stays, plus those rear fork ends or those things we sometimes call dropouts and then get chastised for calling them dropouts. The shape of the seat tube plus one seat stay plus one chain stay actually does make a triangle, but we use the term rear triangle to refer to the pair of these triangles as a single structure.
Handlebar: Do I put my pair of hands on a pair of handlebars, or am I putting them on my handlebar?
Bottom bracket: In that film that Raleigh made in 1947, the speaker referred to all the lugs as brackets. The one where we put the crank was obviously the bottom bracket. But now, bottom bracket refers not to the bracket but to the bearing (cups, balls, and spindle) rather than the bracket.
Bearing: a bearing is something that bears (weight). A headset is an example of a bearing. Most bearings we see are of the ball type, so they are ball bearings. We inaccurately call the little balls in the bearings "ball bearings" but they are actually bearing balls, i.e. balls for the bearings.
C: 700C is a series of tires, and it refers to the diameter of the bead. To specify a tire size, we often say 700x28C as if it is 700C tall and 28C wide. But it's really 700C x 28mm. C is not a measurement of distance!
Fork: In the US, the fork is the steerer tube, possibly a fork crown, plus a left blade and a right blade. In the UK, this structure is called the forks. Both make a bit of sense. The bigger structure is like a two-prong fork. But a fork blade, with a tip for one end of the wheel axle, is also fork-like in its shape, because of the fork-shaped tip.
What??? Only 2 wheels?
Quoted: 1222 Post(s)
Liked 645 Times
I've heard a lot of people refer to the "front forks". I wonder if they every think there might be rear forks.
Of course toe clips are really cages, and pedal/shoe combinations with integrated clips are called clipless.
And wonder of wonder, the bicycle manufacturing industry went over to using English measurements (mostly) instead of metric.
Real cyclists use toe clips.
jimmuller
jimmuller
Bikes: 1975 Raleigh Sports, Cycles Toussaint Velo Routier, Yuba Mundo, Raleigh Sports (1970)
Quoted: 34 Post(s)
Liked 10 Times
I can never figure out whether the thing in the middle of the pedal is a spindle or an axle. It's all relative to your frame of reference. Maybe Einstein could sort it out.
Aspiring curmudgeon
Bikes: Guerciotti, Serotta, Gaulzetti
Quoted: 111 Post(s)
Liked 26 Times
I had a recent thread about Schwinn's "tubular" wheels, which are not in fact wheels for tubular tires, but rather rolled from tubes of steel.
On wheel sizes, 29" is the same size as 28" and both are smaller than 27". Further, 26x1.25 does not equal 26x1 1/4.
"Party on comrades" -- Lenin, probably
Liked 2,470 Times
I think stuff spins around an axle but a spindle spins inside of something. Or something like that. Or maybe it doesn't matter.
Yeah, the word clipless drives enough people crazy. Clipless systems are clipful, because we clip into them.
Before the clipless systems came out, we didn't say cages, but I'm very happy to use that word, because it distinguishes the old devices from the new ones. At least I'm happy when I remember to say toe cages, which is pretty much never.
Liked 2,470 Times
Oh, we can talk about misconstruing names and mispronounced names, too. When I was growing up, people from certain neighborhoods had their own name system for bike parts:
freewheel: star
rim: frame
tubular tires: tubaliss tires
... more I can't remember.
I'm not kidding!
freewheel: star
rim: frame
I'm not kidding!
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
Aw, come on, Tom, you can do better! There is not a single true misnomer on your list; they are all just oddities of nomenclature.
You want a misnomer? Okay, rake, according to the dictionary, refers to an inclination from the perpendicular. An angle, that is. So the rake of a fork is properly measured as an angle, so 72 degrees or whatever. Forks also have offset, which you could measure in centimeters or inches or whatever. To refer to that offset as the "rake," well, that is a misnomer. No, this is not a misnomer. Obviously a Bowden cable is not a lever, so calling part of the Bowden cable mechanism by the name of part of a lever mechanism is an analogy of sorts, but the purpose of the Sturmey Archer fulcrum is very much like the purpose of the fulcrum in a lever mechanism.
This is true on some bikes, but on some bikes it really is a triangle. And if you recognize that the "diamond frame" is formed from two triangles, then this is the main one.
So it's a double triangle; but it's still a triangle, and it's in the rear. When we speak of the rear triangle we all know what we're speaking of. Do you have a better term for it?
Your call. What's the confusion?
So the term that once referred to a frame part now refers to the bearing set into that frame part. That bearing was previously called the "hanger." Whatever. The meaning of the term has shifted; that's the way language works.
Eh.
Granted, the information contained in the term is not obvious; but it is very specific, and when you order a 700 x 28c tire you are ordering a specific size, as opposed to, say, a "26 inch tire."
And your point ... is... what? Oh, I know, the individual pointy things on a table fork are called tines, while the pointy part of a table knife is called a blade. So the bicycle fork has tines, not blades. That's a misnomer, there.
www.rhmsaddles.com.
www.rhmsaddles.com.
Bikes: Nashbar Road
Quoted: 2934 Post(s)
Liked 341 Times
Maybe you guys can clear this up for me, with your historical perspective.
We have saddle and "seat post". Why isn't it "saddle post" and "saddle tube"? Same goes for "seat stay".
The pipe holding the saddle is "post", but the one on the fork is steerer "tube". Doesn't "steerer post" make more sense? For what reason "head tube"? Seems like steerer tube or "fork tube" since it's the tube that the fork post goes into.
Derailleur, or even Sheldon Brown's "de-railler" makes no sense. There is no rail, but there are cogs.
Liked 2,470 Times
Rudi, none of this needs to boost anyone's blood pressure. I am just musing at how language evolves in funny directions. Some of it irritates me, but not most of it. I might have thought that as we evolve, we would be become more accurate over time, so it's funny that in some ways, we become less accurate, and to understand a word, we have to learn layers of history behind the word.
My observations of our uses of the word triangle are not irritations at all, just curiosities.
Bottom bracket is one that does irritate me, and it's my fault more than anyone's. Newcomers to cycling might find it confusing to hear us speaking of a bracket that isn't a bracket at all.
Aspiring curmudgeon
Quoted: 111 Post(s)
Liked 26 Times
Right, but "derail" is also a verb with meaning outside of train terminology. As in, this thread has become derailed.
Bianchi Goddess
Quoted: 2930 Post(s)
Liked 2,926 Times
Gooseneck.
Sugar "Kane" Kowalczyk
multimodal commuter
Liked 574 Times
Agreed! I forgot to add lots of smiley faces from my post.
As for derailleur, my French is weak and I don't know exactly what the word suggests in that language, but I do know it's a French word that we use in English to refer to a specific bike component. This is the beauty of English and I'm disappointed that St. Sheldon (peace be upon him) thought to anglicize it. We don't anglicize "kindergarten" and if we did, people would ask where the garden is. Not to derail this thread, though!
www.rhmsaddles.com.
www.rhmsaddles.com.
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
Saddle vs seat. I like Sheldon's distinction between the two:
"You'll notice that I do call them "saddles," not "seats." There is a reason for this. A "seat" is something you sit on, and is designed to bear essentially your entire weight. Recumbent bicycles have "seats," but conventional upright bicycles have saddles. A saddle is intended to carry some, but not all of your weight. The rest of your weight is mainly carried by your legs, and some by your hands and arms."
-St. Sheldon, from: https://sheldonbrown.com/saddles.html
And then we have:
Saddle = leather suspended over a cantle plate/frame
Seat = everything else
Also, "shifter" vs "shift lever"
And then we have:
Bikes are okay, I guess.
Quoted: 2647 Post(s)
Liked 2,446 Times
Sponges = Grab On foam grips.
Speed handles = safety levers.
Flettahs = reflectors.
Stretchers = bungee cords.
I always liked the German word for toeclips: Fusshaken (foot hooks).
And the Australian word for trouser clips: boyangs.
Liked 2,470 Times
I worked as a bike mechanic last summer. A customer asked me to raise his chair. That was a first for me.
Liked 2,470 Times
These are great. Where did you hear them? I was in NYC. The terms I listed came from black people.
Bikes: are fun!
Quoted: 466 Post(s)
Liked 864 Times
Re the quote, that wording is Sheldon's, from his site. I'll edit to clarify. Agreed it is well said, just not me who said it.
Liked 2,446 Times
Working at a shop here in Richmond in the late '70s and early '80s. Similar source for the jargon, and the dudes loved them some 27" inch frames. Could not keep some Fuji and Panasonic models in stock, they sold so fast.
Liked 2,446 Times
multimodal commuter
Liked 574 Times
English racer.
www.rhmsaddles.com.
www.rhmsaddles.com.
Liked 2,470 Times
You and I must be the same age. I was born in 1961. And yes, there was a trend of buying much too big bikes! It was sometimes an effort to keep a respectful tone when people were making decisions I would recommend against.
Quoted: 34 Post(s)
Liked 10 Times
I agree, and to my way of thinking the thing in a pedal is an axle, since it stays stationary relative to the crank arm and the pedal rotates around it, but it seems like more people call it a spindle.
Ride, Wrench, Swap, Race
Quoted: 1565 Post(s)
Liked 1,296 Times
...You want a misnomer? Okay, rake, according to the dictionary, refers to an inclination from the perpendicular. An angle, that is. So the rake of a fork is properly measured as an angle, so 72 degrees or whatever. Forks also have offset, which you could measure in centimeters or inches or whatever. To refer to that offset as the "rake," well, that is a misnomer...
I agree here.
In the motorcycle industry they got it right. Rake has always been prescribed as the head tube angle off of vertical, so typically reads from ~32-degrees (for a cruiser or desert sled) down to ~24-degrees for a sport bike.
They publish "rake" and "trail", which is about all that you need to know. Fork offset is rarely altered by the owner, so the "trail" figure (measured the same as on bicycles) is sufficient to complete the picture in practical terms.
My beef is with the term "offset" as applied to bottom brackets.
While the industry universally uses this term to convey how much longer that the right end of the bb spindle protrudes further than the left end of the spindle, "offsetting" a symmetric spindle "4mm" in their terms only offsets the chainrings by an actual 2mm.
Much better imo to refer to "offset" as the distance of the spindle's center off of the bb shell's center.
Oh, the semantics!
There is also the occasional confusion surrounding the terms "upshift" and "downshift". Downshifting to me means going to a lower numerical or "easier" gear ratio, yet I often see this term used as meaning shifting to a smaller sprocket, whether front or rear.
And there is also the related "first position" freewheel cog, which traditionally is the smallest cog if you read up on freewheel building, but witch may not be intuitive or in agreement with the usual meaning of "first gear".
I might have to invent a term for the tire bead fit diameter of a wheel rim, which for hooked-bead rims is still the lower "shelf" diameter of the inside of the rim adjacent to the sidewall, even while the tire bead seats fully against the (more-)critical minor diameter of the rim sidewall's bead hook.
But the inside corner "shelf" diameter is crucial to realizing wire-beaded tire's pressure ratings, and today again it is critical for the seating and sealing of the new tubeless tires, just as it has been on automotive rims since tubeless tires became common there.
