Chain Lube
Bikes: Trek 4500
Chain Lube
After cleaning my bike, what kind of lube should I use for my chain and other parts of the bike that need oiling/lubing after cleaning?
Bikes: Trek 4500
Ok, I just didnt know if there was a kind to stay away from or anything. We have some generic chain lube at the house that you get at Autozone and such and wasnt sure if that was a bad idea.
la vache fantôme
WD40 doesnt last.
like trio flow, im not fond of the spray can because its a pain but i believe it comes in drip bottles which i plan to get next. they have these waxes out there but i seem to need to relube every 50 miles so its rather pathetic. Not to mention it comes off just by riding in humid air, and never mind stream crossings because your chain will rust by the end of the ride
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
biketilldeath
Bikes: 2005 Norco Aline:D
although wd40 does have some lubrication properties its mostly a penetrating oil which meeans it breaks down other oils so mabey ok for a chain but not for anything else.
chopsockey
Bikes: Monkey SS everythingbike, Ti frankenroadbike
Tri-flo synthetic or Phil's Tenacious Oil. Oil (or synthetic oil) is typically better for wetter climates, as oil and water don't mix -> repel. For dustier climates, though, I preferred a teflon based lube (again tri-flow).
Sheldon Brown has some words of wisdom.
I use White Lightning wax lube and it seems to work pretty well. I think the wax type lubes are more suitable for primarily dry conditions and the oil type lubes are aimed more towards wet conditions. This is a subject where there are a ton of different opinions as to which type of lube and which brand is best. Good luck!
Bikes: '04 Specialized Stumpy FSR Pro (Frame and Shock Only)
Whitle Lightning wax is great. Pedro's stuff (all of it) is also exceptional.
As for WD40 are you people friggin nuts? That crap is not made to be used with dirt and grime and will screw up your drivetrain quick, fast and in a hurry.
I'm not sure why some people feel the need to give advice when they literally have absolutely no idea what they're talking about.
la vache fantôme
Pedros ice wax could be better. But you have to reapply it constantly for any positive effect!! Stick with oil
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
eert a ekil yzarc
Bikes: many bikes
I have been using white lightning for a long time now. I clean my chain on a regular basis, and when I lube the chain, I wipe it down. The lube needs to be IN the chain not necessarily on the outside.
I have been considering trying out Hippie Slick on my commuter first, and then trying it on my MTB.
My suggestion is to consider your climate, i.e. wet, dry, snow, etc. then decide on a chain lube. I used to have two boxes, one winter and one summer. Winter had the Pedro's lube, and my cold water boardwax (used to surf), and the summer had a thinner chain lube and my warm water boardwax.
Bicycle Rider & Mechanic
Bikes: Superlight, Dragon Team, Eclipse, Om Flyer
I use tri flow and wet Syn lube made by Pedros it works good.
la vache fantôme
syn lube is great stuff for its application. I give it a 5/5 for rain/snow. I know people complain it picks up dirt but folks on the bottle it says "for extreme conditions". If its a wet oil who woulda guessed it picks up dirt. And after it rains or whatnot your chains clean anyways
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Ride it, don't fondle it!
Bikes: Raleigh M80, Bacchetta AERO, Bacchetta GIRO, BikeE, 83' TREK 970, Catrike Speed, IRO Fixie/SS
Try Bosheilds T-9 it is da best. Lubes without collecting dirt, sand etc. I use it as a cleaner and lube. Spray it on wipe then respray, wait about two hours or overnight and wipe again and ride it. I'm a professional mechanic and shop owner and I have used it all and this is the best chain lube I have ever used. I use it on my MTB, road and commuter bikes as well as in my shop.
la vache fantôme
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
THIS BIKE'S 4 U !!!!
Location: Western, NC .... (Pisgah, Bent Creek, DuPont)
Bikes: HARO Xtreme X2, K2 Lithium 3.0, K2 Beast, K2 Flyin' Monkey, DiamondBack Accent EX, DiamondBack Axis TR
I've used everything from Liquid Wrench, WD-40, Dry Spray Lube, Quaker State 10W40, to the high $$$ stuff....
Bottom line is it don't matter after the 2nd mud hole.... That's why I choose whatever.
Dismember
Bikes: Kona Kikapu/hoss deluxe mix, 1950's Malvern Star gent 28" turned into a stealth commuter with drums and a three speed.
I use a motorcycle spray on chain lube, but it collects sand like flies on sh*t when its dry, though it really hangs on when its wet. I'm still looking for a real good one size fits all system.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
Originally Posted by swifferman
What about WD-40? Maybe he could use that? Might not work very well, I don't know. A heck of a lot cheaper than real lube though.
Back to the topic. Prolink Gold
Pro Link Gold would will suit most conditions, it's pretty wet here in Australia and Pro Link works well in wet and dry! Like with anything that moves on your bike it has a "sell by" date. Cleaning then lubing youe chain will only increase its longevity. Wipe off the excess when lubed up to avoid mud from clinging to it.
When it comes to lubes, there are different types.
Dry:
Goes on wet through a medium, but the wet dries leaving teflon behind. This stuff attracts less dirt. But it also is easier to wash away.
Wet:
Goes on wet, stays wet. Attracts dirt.
Wax:
Goes on wet and leaves a wax residue. It is water resistant and does not readily attract dirt. The downside is it doesn't work so well in the cold.
Extreme Purple:
This stuff is used in drilling rigs. It goes on SUPER wet and smells a bit like wine. It's resilient to wet and doesn't attract dirt. It bonds to the metal and is hard to displace. The downside is you can't just add it. You need to get rid of any other lubricant before you apply it, otherwise it will simply roll off.
The MOST important thing is to clean the chain regularly and make sure you lube it on THE ROLLERS.
DO NOT use spray lubes for chain. The get lube in places it's not supposed to be (like disc rotors and rims).
Originally Posted by Raiyn
Must you troll? You're supposedly a lot more intelligent than this (or so I'm told) why not act like it?
My post seems pretty troll to me seeing as how my post was in the form of a question. Explain to me how my post is a trolling post. Please. Do it.
Or better yet, put me on your ignore list if you find my posts to be "trolling." In general, your posts about me are unwanted. Grow up.
There's no need to generalize your posts so as to seem less offensive. I was the only one in the thread who mentioned using WD-40.
Thanks
