HELP, front wheel problem, stuckat work
山馬鹿
Bikes: Nakagawa
The black knob on the quick release of my front tire come off and reveled a small spring. I have tried putting it back together in various combinations but invariable, the brakes rub the tires before I even put back the quick release of the brakes of my Trek 1000, how is this spring supposed to go in?
Help, Please!
Help, Please!
Become King of the Square! https://kingofthesquares.com
Plan or Find your next ride on Sporra!
Put the small end toward the hub. When the wheel is centered between the drop outs, the tires will stop rubbing the brakes.
ljbike
ljbike
Dances with Rocks
The widest part of the spring goes to the outside, (knob side).
Check the cable release on the brakes, it might be caught and not all the way seated.
If everything seems under control, you're just not going fast enough...
To become a registered member of BikeForums Click Here
山馬鹿
Bikes: Nakagawa
Thanks again
山馬鹿
Bikes: Nakagawa
Thanks, its great to know that I can get help here like this. A real testament to bikeforum!!!!
Dances with Rocks
The wide part of the spring goes in the knob.
山馬鹿
Bikes: Nakagawa
I see one spring!
riding a Pinarello Prince
Bikes: Pinarello, Prince and an FP5
Originally posted by Spire
I see one spring!
I see one spring!
"Racso", the well oiled machine;)
山馬鹿
Bikes: Nakagawa
I found it. I'm going to try and put it together again!
Then you'll have to make do. It will be OK to just tighten it down and ride home. Those springs are just there for the skewer to open up when it is unlocked. It has no effect on the wheel or the brakes or anything else. I've seen many bikes in my day with only one spring. They cost about .25 at the LBS. When you get some time, pick one up.
ljbike
ljbike
山馬鹿
Bikes: Nakagawa
I found the second one, it is a bit bent (on the hallway floor), it looks definitly useable, I'll get a pair for LBS.
Again, thanks everybody for the great help!!!!!!!
