Please recommend me a set of 20" tough wheels for my folder.
I'm looking to buy not expensive but really tough 406 wheels for my Downtube Nova. My weight is 210 pounds and I have constantly true the stock wheels. I'm thinking something like BMX ones with 36 spokes.
I appreciate any suggestion.
Sun rims used on my Bike Friday..36 hole double wall...brilliant..
Quoted: 380 Post(s)
Liked 106 Times
I am also about 200 pounds and my Bike friday Pocket Rocket has 24 spoke wheels, stainless spokes, with Sun MA14 rims in 451 size. I have only retighteed the rims a couple of times in the 24 years I have owned the bike. Roger.
Sun CR18 rims .36 spoke...406 mm...and had my BF since 2003 and never ever touched a spoke at all..Chris
Part-time epistemologist
If you're rough on your wheels, I'd build 36-hole wheels with Sun Rhyno Lite rims and mate them with something like Big Apples. Remember that you don't have to pump them to the max pressure for a fast ride. I'm always a fan of Shimano hubs -- traditional cup and cone bearings that seem to last a long time with regular maintenance -- so I'd go with ordinary Deore hubs with the 135 OLD.
A narrative on bicycle driving.
Great suggestions guys. Thanks a lot.
On Ebay I found Bike Friday 451 32H Capreo hubs wheels. What you think about the deal?
Bike Friday Wheels 451s Fr RER 9spd Capreo R Hub Deore Frntcosmic Tires Sun | eBay
Quoted: 151 Post(s)
Liked 10 Times
i have a few 406 wheelsets in my "inventory" (ugh). i'll have a look. i may have something you can use.
I have Sun 32 hole CR18 on my Bike Friday . your choice up to 3 cross ..
Asian "Weinmann" AS26FL in 28 hole on my Bike trailer.. [ Older Burly flatbed ]
BTW for really harsh treatment 406 rims are drilled 48 hole too ..
a Group of 3 crows foot pattern is clever .. a combination of a radial and a 2 cross on either side of it per side
so opposed by another group , of 3 ; 8 groups of 6.
Thanks.
yep. i still have these.
To the OP ... it really matters who builds your wheelset. 32 spokes is a lot for a well built 20" wheel. The 32 spoke wheels on my Bike Friday are doing great and only had to be trued once as a consequence of an event waaaaaaay outside the norm.
Quoted: 151 Post(s)
Liked 10 Times
Nice wheelset. Although I suspect that the rear OLD on a Downtube is 135. OP should be able to put 2.5 mm spacers on either end -- I'm assuming that the rear triangle is aluminum -- and still have enough of the axle in the dropout.
but, yes. i agree. quality of build and choice of materials means the difference measured in years for the longevity of a wheelset. this is the second set i've had built by Harris Cyclery.
Here it is only 2.5 mm on each side but given that it's cheap and easy, I'd put the spacers in.
Maybe Yan will confirm.
Quoted: 321 Post(s)
Liked 7 Times
I find it hard to believe that you can't put a 130mm hub in a 135mm OLD frame. The later Xootr Swifts have 135mm and I have had no problems shutting the dropout closed on my road hubs over the years, although I did use a 1mm thick washer as a bit of a spacer, and I suppose that brings it almost to the 132.5mm value. Aluminium has a finite number of stress cycles for any amount of stress, unlike steel which has infinite stress cycles if you keep the stress below a certain level. But for the few times you stress the rear triangle to insert a hub... well that is an infinitesimal amount of the total amount. You won't be cracking the frame in your own life even if you removed and replaced the back wheel every day for the rest of your life.
It is a big PITA though, to wrestle a 135mm hub into a 130mm frame.
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
Our old Nova's used 130mm rear axle, the newer ones are 135mm. I have lots of wheels from old bikes I can sell at a discount, however I think OP may only be interested in front wheels as the rears are for cassettes ( the Nova uses a freewheel ).
Thanks,
Yan
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
Bikes: Dahon HSL,NB994 16",Battle FSD 14"
I had built some heavy duty wheels.
this one was ordered by a HongKong cyclist for his folder. XT M785 HUB, DT 2.0 spokes, 406 double-wall rim with eyelets. tuning with high spoke tension 。
Yan you are the best. I didn't even know a freewheel exist. Thank you.
7 speed cassettes are dirt cheap.
Skyway tough wheels (tm) are a fiber reinforced Nylon spoked wheel but only 1 speed ..
you can Really thrash them ..
Quoted: 151 Post(s)
Liked 10 Times
you should probably get something like this.
[TABLE]
[TR]
[TD="colspan: 2"]SPECIFICATIONS[/TD]
[/TR]
[TR]
[TD]AXLE DIAMETER[/TD]
[TD]BOLT[/TD]
[/TR]
[TR]
[TD]AXLE SPACING[/TD]
[TD]135mm[/TD]
[/TR]
[TR]
[TD]COLOR[/TD]
[TD]SILVER[/TD]
[/TR]
[TR]
[TD]FRONT/REAR/PAIR[/TD]
[TD]REAR[/TD]
[/TR]
[TR]
[TD]HUB BRAND[/TD]
[TD]KT ALY ATB FREEWHL[/TD]
[/TR]
[TR]
[TD]HUB FINISH[/TD]
[TD]SILVER[/TD]
[/TR]
[TR]
[TD]HUB TYPE[/TD]
[/TR]
[TR]
[TD]MODEL[/TD]
[TD]RW2015AF[/TD]
[/TR]
[TR]
[TD]RIM FINISH[/TD]
[TD]SILVER[/TD]
[/TR]
[TR]
[TD]RIM MATERIAL[/TD]
[TD]ALEX Y303[/TD]
[/TR]
[TR]
[TD]SINGLE/DOUBLE WALL[/TD]
[TD]SW[/TD]
[/TR]
[TR]
[TD]SIZE[/TD]
[TD]20''X 1.75[/TD]
[/TR]
[TR]
[TD]SPOKE COUNT[/TD]
[TD]36[/TD]
[/TR]
[TR]
[TD]SPOKE FINISH[/TD]
[TD]SILVER[/TD]
[/TR]
[TR]
[TD]SPOKE TYPE[/TD]
[TD]UCP[/TD]
[/TR]
[TR]
[TD]WHEEL SIZE[/TD]
[TD]20[/TD]
[/TR]
[/TABLE]
- Alex Y303 30.5mm wide alloy rims w/ 36 holes for strength and durability
- KT-A1HR ATB 135mm OLD
- Wheels laced four cross for superior strength
- Rear alloy hub uses a 6-8 Spd FW
