View Poll Results: which shock is better for free riding
rock shox psylo xc
13
81.25%
rock shox judy xc
3
18.75%
Voters: 16. You may not vote on this poll
which shock
cycle-powered
Bikes: '02 Specialized FSR, '03 RM Slayer, '99 Raleigh R700, '97 Norco hartail, '89 Stumpjumper
as i understand it, the psylo is set up more for free-ride with more travel and weight compared to the judy which is more an inexpensive xc fork...
i'm more into light-weight than major travel, but i really like the air shocks -- i now have the Fox Float and my old SID was great too -- although both of these cost a lot more than the 2 you mentioned...
sorry i don't know more about the technical differences between the 2, but you should be able to look up in a magazine or the web the stats: weight, travel and adjustability and then try and find out about stiffness...
Bikes: Too many to list!
The Psylo is the answer. The U-Turn Psylo has an external adjustment in terms of travel (80-125mm, I think?) that also compensates and adjusts the spring rate.
I definately prefer air to coil
the psylo is going to require a lot of maint. though b/c it's rock shox
thanks for the info even though it helped none, next time pay atteneion to the poll, marzocchi wasn't an option! so snap out of it and pay attention.
