Why not a Titanium handlebar?
Light Makes Right
Bikes: Gianni Motta Criterium, Dean Hardtail
Hi,
THere are a couple of titanium handlebars on the market, but I never hear anybody talking about them.
Are they just too flexy, or what?
Thanks,
Chris
Thanks,
Chris
Quoted: 12191 Post(s)
Liked 1,495 Times
They were a way to get some shock abosrbtion. Now that most bikes have shock absorbers they cost too much to bother with. If Airborne still sells them, they had a good price.
Light Makes Right
Yeah - but they don't cost any more than Carbon. Weigh slightly more - about the same as a really light Al bar.
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
Seems like with that last statement you answered your own question.
Light Makes Right
So why not Ti to solve these problems? It's not as cheap as Al, but needs replacing less often. About the same as Carbon but not as brittle. So in the long run maybe cheaper than either. The only down side I see is flex, but if it doesn't flex so much as to really affect the handling but does flex enough to dampen vibrations............
Too Much Crazy
Bikes: Eriksen 29er, Gunnar Roadie, Niner RLT, Niner RIP 9
Quoted: 116 Post(s)
I think that most mtbers perform a cost benefit analysis on each piece of equipment they buy. The cost of Titanium bars is just too high to justify I think. Despite what you say, in my experience they do cost more than carbon. Unless there are some cheap ti bars I don't know about.
The Moots Riser bar looks sweet. But it costs more and is heavier than an easton monkeylite ec70. And I am happy with my carbon bars so far.
I have ridden with the Ec70 monkeylite on my rigid bikes. For me, there IS NO DEBATE whether they dampen vibrations.
Get the stick.
Bikes: 12 Y.O. Litespeed MTB, IRO Jamie Roy fixie, Custom Habanero Ti 'Cross, No name SS MTB, Old school lugged steel track bike (soon)
Originally Posted by GV27
Hi,
Thanks,
Chris
Thanks,
Chris
Light Makes Right
OK, now we're getting somewhere.....perhaps it is the design rather than the material. Because you're right - the Ti bars I'm talking about are straight with a stem spacer. Maybe some internal butting - I'm not sure. With the same design and the same weight, the Ti should be WAY stronger. This should easily justify the cost for all these guys I see breaking or bending expensive bars. BUT if the center bulge, tapering, etc. means that the Ti bar is NOT significantly stronger than aluminum - and I would guess that would make it weaker than carbon - then there you have it.
edit: well, this discussion has become academic for me - though I do think it's interesting. I just bought a straight carbon bar for $49 from Cambria Bike Outfitters. That price does make it hard for Ti to compete.
la vache fantôme
If you get your carbon goodies from a reputable company such as easton, there should be no issue with strength. These things have huge strength
C://dos
C://dos.run
run.dos.run
C://dos
C://dos.run
run.dos.run
Liked 1,495 Times
chopsockey
Bikes: Monkey SS everythingbike, Ti frankenroadbike
To add to the list:
https://www.moots.com/ticomp-handlebars.php
At the same diameter and tube wall thickness as AL, they should be about twice as stiff and twice as heavy. I doubt they're made of the same wall thickness.
The real nice thing is elongation (always nice): Ti will bend a lot more than AL, CF, and even Fe before it breaks. Also, you can bend it back.
Additionallyl, it's quite fatigue resistant, and should last a long long time.
As said before - cost is the real issue.
Gravity Is Yer Friend
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
I used a WhiteBros DH Ti riser for 8yrs until I bent the shyte out of it. It did feel much better then aluminum and a lot safer then carbon. I prefer the ti but the al is much easier on the pocket when you need to replace.
Light Makes Right
https://www.sears.com/sr/javasr/produ...&bidsite=CRAFT
Bike parts are relatively fragile in general so it just makes sense all over the bike. I use my torque wrench more often on my bike than I do on my cars and motorcycles.
Sorry for the O/T - not using a torque wrench is a pet peeve of mine!
I actually got my bars slightly cheaper than $50 that due to some other business I'm doing with them, so it was a deal I couldn't pass up. Easton says if you do it right and use the right parts, you can cut the bars I ordered down to size and even run bar ends. That's all that I want.
One thing about cost though - I finally see the difference in perspective. I'm pretty old-school and have just been looking at flat XC bars. They're a lot cheaper relative to carbon and aluminum vs. riser bars. Ti riser bars are f'n expensive!
Sheesh, bar shopping has gotten complicated in the 12 years since I last bought one! I've been agonizing over this for a couple of weeks and when Cambria offered me a deal, I took it as a way out of my misery. That is until I mis-use my torque wrench on my non-compatible bar ends and crack my brand-new carbon bar!
C
