Polar HRM - changing battery
Has anyone tried changing the battery in a Polar HRM themselves (I've got the S725), rather than sending it back to Polar as they recommend? If so, any problems? When mine eventually runs flat, I'm not keen on sending it away and being without it for a few days (weeks?). Thanks.
Guest
Posts: n/a
Quoted: Post(s)
I've never tried, but they do say if you try to change it and something goes wrong, they can't help you or do much for you. They really do their best to put the fear of God into you.
On the other hand, you can call around to jewellers in the area and see if any of them can do it for you.
Koffee
Koffee
On Your Right
I changed the battery in my old Polar Coach and it worked fine until I replaced with with a S625X.
"You never fail, you simply produce results. Learn from these" - Anonymous
Aluminium Crusader :-)
A watch shop guy did my old Polar Edge a few years ago with no problems.
The last I heard, Polar say they must be pressure and water tested, but I don't swim with mine, so there
But, I just had my 2+ year old Polar A3 sent off for a new battery, and they "coincidentally" found that the belt was no good, and therefore needed replacing. Total service cost: $72 AUS for a $170 Monitor.
The cynic in me wonders how often customers get the call that "an extra fault has been detected; we recommend you spend much more money."
Bikes: Aegis Swift, Titus Racer x
A few years ago, I had a guy in a fitness equipment store swear that he was authorized to replace the batteries in Polar HRM's so I let him do it. The seal was broken and even though I don't swim with it every time I went out on a humid day the face fogged up.
Fortunately, Polar knew about this guy and replaced the unit for free. Whew!
I now have a 610 and last week I got a message when I downloaded my exercise information that my battery is low. I will definitely send it back to Polar for repair. I won't take a chance again.
In the meantime I ordered a Cambriatta www.cambiatta.com. as a substitute. I only need an uncoded HRM strap. It should be in Tuesday.
Kathi
Kathi
Bikes: Litespeed Liege, Motorola Team Issue Eddy Mercxk, Santana Noventa Tandem, Fisher Supercaliber Mtn. Bike
Quoted: 14 Post(s)
Liked 11 Times
I changed the battery in my s710 with no problems.. The biggest issue is finding the battery.. I called 5 watch shops and many other places and could not find a battery..
I ended up buying 2 on ebay and then did it myself.. If you have the right screwdrivers its very easy..
They use a model CR2354. Here is the link to seller, I had them checked and they were full strength..
https://cgi.ebay.com/ws/eBayISAPI.dll...sPageName=WD1V
Bikes: Scapin EOS7 sloping, 10v Record, Ksyriums
If you want to maintain warranty, send it back to Polar to do. Otherwise, any local jeweller.
Originally Posted by 531Aussie
Ed
you've ventured onto the training forum? bit of a rarity
I'm bored, shags.....I'll see who I can stir up around here.
Just did it on my s710 . seems to work good. Just be sure the seal ring is clean and
just another gosling
Quoted: 3885 Post(s)
Liked 1,938 Times
I changed the battery on my 725 several times until I must have made some mistake and had to send it in to have the guts replaced. I don't think I came out on it, but it was close. I sent it to a local authorized repair guy and got it back in 2-3 days. A jeweler is not an authorized Polar facility unless they say so. I'd just as soon do it myself.
Bikes: 2006 Specialized Ruby Pro aka "Rhubarb" / and a backup road bike
Quoted: 7 Post(s)
Liked 13 Times
I took my Polar RS800CX into a local jeweler / authorized Polar repair; and he had a very difficult time getting the wristwatch unit plastic back removed without tearing it up.
The dime slot took a beating, Polar had it torqued down too tight.
Next time (very soon) it will have to go back to Polar. The jeweler said he wouldn't be able to work on it again.
The HRM was marketed as "multi-sport" so imagine my surprise when it did not transmit while swimming.
So I will be using my swimming HRM on the bike while the RS800CX is getting serviced.
It won't show my cadence in the polarpersonaltrainer.com website but it handles the important stuff - speed, distance, heartrate.
My employer gives us financial incentives to log our physical activity using the VirginHealthMiles site; it only accepts the web-uploadable Polar HRM's and the GoZone pedometers.
So I am pretty much locked into Polar for now.
Liked 1,938 Times
https://www.polarusa.com/us-en/support/service
You took it to one of these? I've had very good experiences with the center that serves my part of the country.
They're not supposed to ruin it and give it back to you. That's the opposite of what they're supposed to do.
sknhgy
3
09-14-10 12:43 PM
Reynolds
0
03-19-10 09:27 PM
