Expanded Tern recall
#226
Bikes: Muddyfox Evolve 200, Bicycles4u Paris Explorer, Raleigh Twenty Stowaway, Bickerton California, Saracen Xile, Kona Hoss Deluxe, Vertigo Carnaby, Exodus Havoc, Kona Lanai, Revolution Cuillin Sport, Dawes Kingpin, Bickerton, NSU & Elswick Cosmopolitan
Quoted: 297 Post(s)
Liked 33 Times
Again, false choice. Obviously--you folks are deliberately dense when it suits--is not between Hi-Ten and Al, but rather between Hi-Ten and Chrome Molybdenum Steel.
You know, I know, we know that if the shoe were on the other foot, that is, if the Dahons and other blue-collar folders were made of Hi-Ten, you'd view that add further evidente if they their low quality. Once again, evidente if the elitism and bias that afflicts this channel.
https://brompton.zendesk.com/hc/en-u...my-frame-last-
The way its worded above it is stating no mention of high tensile steel but I read something in the past that indicated that it was a mixture which was ok as brazing had no problem connecting the different steels at full strength. However it could be simply the frame is chromoly but the forks are high tensile steel I guess that would be accurate and fit in with the statement above. However I thought it was explained differently in the past with both metals used in the frame to give the right properties in the right places. I.e. a little bit of flex in the main downtube but rigidity in the bottom bracket. I guess the main frame could be chromoly but the rear section high tensile or vice versa as another option. The point is Brompton have designed their frame using different steels and also use brazing which is more expensive but gives a stronger frame.
I'd have no problem with Dahon using high tensile steel. I'm a huge fan of steel as anyone who reads my posts would know. I was the one saying the Dahon Curl should use a steel frame to give it better ride quality and help make it a more compact design. A few high tensile steel Dahon models with a 120kg weight capacity would be pretty good I think.
#228
Not from Brompton, but I have no reason to doubt its accuracy:
Every Brompton hand-brazed hi-tensile steel main frame is essentially identical: the steel tubing, the hinge, the dimensions and the geometry.
from the link:
https://www.edinburghbicycle.com/info/brompton/
from the link:
#230
from the link:
from the link:
#232
Quoted: 297 Post(s)
Liked 33 Times
from the link:
from the link:
4140 High Tensile Steel | Interlloy | Engineering Steels + Alloys
So both statements are accurate although I think Brompton would be well advised to only mention Chromoly due to cyclists often having low regard for high tensile steel due to its common use on entry level bikes. All the 41-- series steels are chromoly steels. Mystery solved.
#233
Bikes: Trident Spike 2 recumbent trike w/ e-assist
Quoted: 1321 Post(s)
Liked 374 Times
I fail to understand why Brompton only offers a 5 year frame warranty when, theoretically, 4140 is stronger than 4130 (which is used in Bike Fridays with lifetime frame warranty). Is it because of the hinge or brazing or something?
#234
Bikes: Brompton H6L-X, Dahon Curve D3
Quoted: 56 Post(s)
-HANK RYAN-
Norman, Oklahoma USA
#235
Liked 374 Times
Warranty terms are (theoretically) market driven. Also, keep in mind that, in the bicycle industry, a "lifetime warranty" on a frame usually means "for the useful life" of the frame --- not "forever". Most bicycle warranties are not transferrable to subsequent owners, and a "lifetime warranty" is pretty much worthless if the entity making the warranty no longer exists.
-HANK RYAN-
-HANK RYAN-
#236
Quoted: 297 Post(s)
Liked 33 Times
The Brompton frame parts (front frame, main frame, rear frame, forks and handlebar support assembly) are covered by a 5 year warranty against manufacturing or material defects (please note that normal wear and tear is not covered). Compared to the frame warranty widely offered on conventional bikes - often referred to as “limited lifetime” - this may seem quite short. However, the nature of our frame design, with its regularly folded and unfolded frame sections, and with the majority of Bromptons used in day-in, day-out commuting, our bike can be subject to the stresses more comparable with bikes with full-suspension frame parts, for which a 5 year warranty is the norm. Nevertheless, if your Brompton is over 5 years-old and develops a fatigue failure, please report this to your local Brompton dealer so that the circumstances of the failure can be discussed with the factory.
#237
Palmer
Quoted: 1659 Post(s)
Liked 1,805 Times
#238
**thusi*st
Pricepoint Boardwalk and SUV models are made from Hi Ten Steel.
Speed D7 and Speed D8 models are made from Chome Moly Steel.
I am not sure what Speed Uno's are made from.
Molybdenum adds quite a bit to the quality of many steels, not just Hi Ten, stainless steel in particular. It tends to make steels more resilient and in other situations less prone to corrosion..
#239
Quoted: 297 Post(s)
Liked 33 Times
A little knowledge is a dangerous thing. The Young's Modulus of various structural steels doesn't vary all that much.
See no.7 here;
https://app.aws.org/wj/2000/09/0015/
#240
Liked 374 Times
Trek and Specialized both have lifetime limited warranties. They don't apply that to the suspension forks/parts but the frames are warrantied even on the mountain bikes. I've never seen anyone on a Brompton put their bike through anything even close to what a mountain biker does, they mostly pootle to transit. Daily use is a problem? If there are specific parts on the frame that are over-stressed, design them better with better materials (or exclude those specific parts if you cannot).
I'd buy what they're saying if the Brompton was in Dahon price range, but not at the price Brompton charges. I think they owe their customers more. Imo, it's a premium bike at a premium price with a low-end warranty. A quality steel bike should last decades and the warranty should reflect that.
#241
Bikes: Many Downtube Folders :)
Quoted: 282 Post(s)
Liked 24 Times
I was just contacted by a Bay area medical researcher whose Tern frame failed last week. I encouraged him to post information and pictures into this thread.
Thanks,
Yan
Thanks,
Yan
Designer of Downtube Folding Bike
Ph.D. Temple University ( Math )
Biked across the USA twice
Semi-active chess player ( two time Bahamas National Champion )
Sivananda ( Bahamas ) Trained Yoga instructor ( 2013 ) and ThetaHealer since 2013
Bicycle delivery worker for Jimmy John's. Delivering is the best workout I have ever had.
#242
That would be me (the medical researcher). This is my first post here so can't upload a picture yet, but it was a clean break at the weld at hinge in the middle of the bike. Tern 20 inch bike; I was sent to the trauma unit at the hospital with several head injuries (even with a helmet on). Recovering now (this happened last Thursday so I'll get some stitches out tomorrow).
#243
Best wishes for a speedy recovery, joewiems, and hoping that you will have your bike replaced under warranty.
#244
Quoted: 28 Post(s)
#245
LET'S ROLL
Saw this on the London Brompton Club FB page last month;
supposedly by Unruly’s (Advertising Agency) reception in Whitechapel.
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
#246
#247
Quoted: 282 Post(s)
Liked 24 Times
I also wish him a quick recovery. He told me he bought two Tern's. The one that failed was a Link that was purchased in 2016. He said it was not part of any current recall.
He said he will stay away from public posting until his attorney gives him permission.
Thanks
Yan
Thanks
Yan
#248
Quoted: 321 Post(s)
Liked 7 Times
If Tern had any business sense, they would speedily replace this guy's two frames with the improved versions, no questions asked, and pay for his expenses, and get a non disclosure agreement.
#249
Quoted: 282 Post(s)
Liked 24 Times
Based on what I saw in the various failure pictures, it seems to me this was a design problem not a manufacturing problem; if this is correct it therefore affects ALL Terns made before the weld design was changed and augmented, and the recall is a red herring. There will therefore very likely continue to come cases to light of frames that broke exactly as the others did and not be part of the recall.
What about the hundreds if not thousands riding these bikes that have not been recalled that have the same problem???
FYI I went to Tern's forum yesterday and I was officially kicked out However it seems that they changed the forum to hide the tern frame failure thread. Is that true? Anyone have access to the forums? I have a backup copy at home, but I'm away teaching until December and won't have access until then.
I just noticed they changed their recall page. Take a look at https://www.ternbicycles.com/2014-li...luntary-recall . It all looks fishy to me....the recalled bikes have a serial number why not share the recalled serial numbers. Why require all this stuff. Something is not ok.
It's a good thing they sued me over the summer. They provided an address and partial corporate structure in the complaint. Hopefully this helps future victims.
Thanks,
Yan
