ENO Luv
deep fried goodness
Bikes: rosemary (bstone); fat chance; serotta
ENO Luv
I finally set up my old Fat Chance with a White Industries ENO hub, and if there was a Nobel Prize for bike components, WI should get it. After one frustrating road bump after another putting the bike together one night, abated only by the nector of Shakespeare Stout, I looked at the wheel and chain and dreaded the thought of chainline and tension. Set up the chain as tight as I could and it laughed at me, droopier than sagging breasts. BAH! I adjusted my ENO hub and POOF the sucker was tighter than Hendrix. The few tension adjustments I've had to do on the road have been cake (pie?). This hub has been phenominal and brought my trusty old steel mtb frame back to life. New trails lay ahead.
Pic of my lovely hub and chainline. (Finished bike pics forthcoming.)
Get the stick.
Bikes: 12 Y.O. Litespeed MTB, IRO Jamie Roy fixie, Custom Habanero Ti 'Cross, No name SS MTB, Old school lugged steel track bike (soon)
Yeah, that hub is great. All of my frames have vertical dropouts, and now I can ride them all fixed! Are you riding fixed in the dirt? Cool vintage steel MTB frame, hang on to that.
deep fried goodness
My original plan was that this bike would be my super hilly/heavy stuff commuter and to take it to Alaska with me in a few weeks, but I have been biten hard by the dirt bug after a long hiatus and I'm daydreaming about Moab and Whistler and mass amounts of fun. This frame is the bomb and it feels like the first day I got her 13 years ago right before the suspension fork boom took off. She dances up hills and makes you a better rider - a better technical rider, which is nearly a lost art with today's push-a-button-motocross-soulless-hybrid mtbs.
that is very cool and it has made my list of things jeff wants to buy.
other things on the list? don't worry about it.
jeff
jeff
dangerous with tools
Bikes: fat, long, single & fast
May I be the first to complement you on the photograph? The perspective makes the chainline appear almost parallel. Very compelling.
Get the stick.
deep fried goodness
I shake my head at people who spend $$$ on full suspension machines. For the majority of off-road use, all you need is a well made bike with the right geometry and tubing, and good technique that includes using your body to absorb movement. This steel frame is so subtle and smooth I would never have a need for shocks. Then you add the simplicity of a fixed/ss hub and it completes the circle. I'm stoked.
And graci Halfbiked. That pic did come out nicely.
deep fried goodness
I haven't touched real trails yet. She just got built! It's a 36x16 for now. And I like to call it "pansy" gearing. I revel in my pansiness.
ambassador of good will
Bikes: many.
36:16 is pretty hardcore
deep fried goodness
Originally Posted by bostontrevor
You may find 36/16 to be a bit steep. No joke.
hateful little monkey
consistent inconsistency
looks very nice just from that one pic.
will you be takin' this out tomorrow?
every scar has a story
Beausage is Beautiful
Bikes: Nabiis Alchemy
Quoted: 20 Post(s)
Liked 13 Times
The ENO hub is the single best component I've ever had, hands down.
To Harlot and other ENO users: what's your standard chain-tensioning procedure?
I set tension with the bike upside down, rear wheel between my legs. I get the bolts medium-tight and then use a 3/4" wrench to set tension while making sure the bolts don't slip in the dropouts. I then wrench down and I'm on my way. In practice, this takes me about 10 seconds tops and at this point I think I could do it in my sleep.
Yo. Everything I’m doing is linked on What’s up with Dave? but most of note currently is Somewhere in Japan.
deep fried goodness
Mr. Habitus - Yes I am taking this mighty steed on the ride tomorrow. I have moustache bars on it so it can hold lots of balloons!!
Mr. Dave - I do pretty much the same as you, but it's not upside down and I probably should adopt that. I also find that it holds well if I just adjust the hub with my fingers. It's so stinkin' easy there's not much technique needed. If only everything could be this easy......well hell then everyone would do it.
horizontal drop out
I just got one of those eno hubs for my trials bike recently. It rolls super smooth, and the chainline is perfect. 1.1:1 gear ratio. I haven't tried it fixed yet though. I think trials is hard enough with a freewheel, but it'd be fun to try anyway.
"Great One"
Location: Might as well be underwater because I make less drag than a torpedoE (no aero bars here though)
I want to use this Eno hub, just need to investigate the price.
Unfortunately WI LTA rear hubs are $250. Hopefully this won't be near as expensive.
Cornucopia of Awesomeness
https://sheldonbrown.com/harris/fixed-hubs.html#white
"Great One"
Originally Posted by baxtefer
That look like an pretty awesome hub (if it's like other WI hubs) and I'll bet this rear wheel would be strong as hell since there won't be any dish in a 130mm application (good bracing angle on both sides).
Quoted: 20 Post(s)
Liked 13 Times
I have yet to see any evidence that the Eno hub is anything but an absurdly well made component.
deep fried goodness
Try having your LBS order it through QBP. I got my hub for $130.
"Great One"
It would work obviously with horizontal drop-outs too right?
