Emergency Camping Gear for Day Trips?
Quoted: 18372 Post(s)
Liked 4,507 Times
What are the thoughts on emergency camping gear for day trips?
Last Sunday I got a bit of a late start for my ride, and it started getting dark at about mile 80 of 140 miles. I had good lights, but it did give me plenty of time to think. At sunset, I was really in the middle of nowhere, and hadn't seen a car pass for quite some time, although I did start seeing a few campfires a little later. And it started getting a bit chilly, especially at the higher elevations.
A major break-down could have been bad.
Anyway, I was thinking of an old down jacket. Something to keep the upper body warm at night. Maybe an inflatable pad to sit on. Rain or lack of rain is generally predictable around here in the summer so that isn't a big concern... now.
I've got pants, not shorts so the legs are moderately protected.
Galveston County Texas
Bikes: 02 GTO, 2011 Magnum
Quoted: 1350 Post(s)
Liked 1,243 Times
These work to keep one warm..
I have used mine Twice.
Most of them come without the girl.
https://www.moreprepared.com/emergen...oUkaAjNo8P8HAQ
Fred "The Real Fred"
Liked 4,507 Times
Yeah, I thought about a space blanket. They were handy after the Marathon runs a few years ago. But, I wasn't sure about using one at night. I suppose it would be better than nothing. And I could still improvise insulation if needed.
Liked 1,243 Times
Aluminized mylar space blankets do work if it's not too windy and are cheap, light and compact. Basically single use as they are impossible to repack to original dimensions. There are heavier duty multiple-use emergency bags (Al+PE) such as below, some larger with grommets to double as shelter:
https://www.amazon.com/SE-EB122OR-Em.../dp/B0090AAY6Q
Then there's tube tents, ponchos, tarps (silnylon, tyvek), water purification tabs, compact folding water bladders, etc. Most available at any Walmart. Between Coleman and Coghlan, pretty much anything camping is covered.
Quoted: 659 Post(s)
Liked 7 Times
Bikes: 2016 Fuji Tread, 1983 Trek 520
Quoted: 675 Post(s)
Liked 741 Times
I think of that kind of gear only on winter backcountry ski trips, when a gear failure could really affect your next birthday. On any road I'd bike on, I'd never think of carrying overnight gear. I'd leave the bike and thumb a ride. Or change my plans at midday, have a preset turnaround time, and not get into a bind. But I'm older and think more like that now!
Quoted: 3459 Post(s)
Liked 1,465 Times
Cell phone if you get stranded or just plain run out of steam far from home and a way to tell time so you can try to estimate your time budget.
This is the touring forum, most of the people on this forum are planning to camp some or most days of their trip instead of camping only as an emergency.
Quoted: 5774 Post(s)
Liked 2,571 Times
IMO - better planning is the best protection, but I understand that stuff happens. I guess it depends on where you ride and the point of no return distances. Here in the east, there are few, if any, where a bailout distance would be greater than 30 miles or so, though many years ago a few of rode a60 miles to a hotel, only to find it had burnt down, and we needed to dig down and pull another 40 miles that evening.
Out where you are, distances are bigger, and I can imagine loops with much greater point of no return distances. I guess I'd carry some plastic sheeting or a space blanket, a tough knife and some fire starter. I wouldn't rely on a cell phone since there are fewer, if any, towers in these unpopulated areas.
FB
Chain-L site
FB
Chain-L site
Quoted: 18409 Post(s)
Liked 15,525 Times
Just cut open a Tauntaun and climb inside. If that doesn't sound practical, buy one of these:
Star Wars Tauntaun Sleeping Bag | ThinkGeek
Liked 1,243 Times
110*F Sunny in the day.Dropped quickly to 56*F at night.
The drop is what made it cold.I was not using a sleeping bag.
Liked 4,507 Times
Thanks for the responses so far.
I suppose another option I was thinking about is 50 gallon garbage bags. Dirt cheap, light (both light duty and heavy duty. And, very customizable.
I suppose there are also extremely light weight slickers (pants and jacket?). I always think of reusable, but if one is considering emergency preparedness, then single use would be fine.
LET'S ROLL
Can be used in the rain, takes up little space when rolled, can be used over & over:
Pearl Izumi Elite Barrier Cycling Jacket (For Men) - Save 60%
One day: www.youtube.com/watch?v=20X43026ukY&list=UUHyRS8bRu6zPoymgKaIoDLA&index=1
Quoted: 675 Post(s)
Liked 741 Times
Liked 4,507 Times
As far as loop (or out and back) distances. It really depends on the loop.
My last loop was about 145 miles total, with a 20 mile and a 60 mile segment on back roads, without towns or major highway access (excluding an active RR bridge along one segment). So, a bail point in the middle would be about 75 miles back home, and 30 miles to get to a main road, or a small town. And I'm not sure where all of the motels are. Some undoubtedly would be pretty expensive "resorts". Depending on the ride, shortcuts might only save 5 or 10 miles for the whole loop.
I was wondering about fire stations, but most rural ones are "volunteer" stations with minimal if any on-site night-time staffing. Same with ranger stations (which are also sometimes simply closed).
A 150 mile day trip can rival many short tours. And I'm considering pushing that to 200+ mile day trips... well, partly day trips. And I doubt I could count on sunlight for the whole trip.
Liked 2,571 Times
One of the things I consider when riding alone in sparsely populated areas is the frequency of passing traffic. I consider motorists my emergency backstop, and factor the time interval between cars. We all prefer low traffic, but no traffic isn't necessarily a good thing.
So, think about the "what if"s and consider riding these long desolate routes with a friend or two. Keep in mind that this advice is coming from someone who is far from religious about the buddy system, and when scuba diving operates on a "same ocean, same day" version. Nuff said, it's your call and you don't owe anyone here (certainly not me) an explanation.
Meanwhile back to your original question. As I said initially, planning may be your best friend. Before starting, review the planned route with an eye to bailout options. Make a note of motels, gas stations, police or fire stations, and even clusters of homes, or other possible Plan-B options, with the "point of no return" benchmarks. This is what pilots and navigators do and those Plan-B locations are key to laying out routes. The exercise will serve you well whether it ever gets used.
It may not save your life, but knowing your options can come in very handy. Imagine you catch a pothole and buckle your rear wheel, 10 miles past a gas station. Wouldn't be nice to know if the nearest one is in front of you, or you should walk back for 3 hours?
FB
Chain-L site
FB
Chain-L site
Clark W. Griswold
Quoted: 4347 Post(s)
Liked 3,984 Times
Real Men Ride Ordinaries
Quoted: 17 Post(s)
Location and conditions really make a huge difference in the amount of gear I'd take with me for a 'just in case' scenario. In general, I try to keep enough gear to survive a night out, even if it won't be comfortable. Backcountry ski trips call for a lot more food and insulation than summer trips down the coast, and if surviving the night just calls for checking into a hotel and ordering room service, so be it.
Most conditions I've toured in, surviving the night would just be a matter of pulling off to the side of the road, pulling on whatever jacket I had with me already and lying down.
Quoted: 141 Post(s)
Liked 9 Times
When I am on a long ride where there is a remote chance that I might be caught out after dark, I take one of the mylar emergency space blankets in the spring and fall, and a minimal nylon tarp(5' by 7') in the summer. Just enough to keep me a little drier and if its chilly, a little warmer. I usually have bug spray as well for day use, but would saturate with it to keep ticks off me at night.
In the winter when days are shorter, I will carry both of these. They add about 12 ounces together.
I would not expect to sleep super comfortably. Just be a little less exposed.
Like has been said, a lot depends on time of year, destination, route and how much traffic to expect.
If I was injured or had a serious mechanical, I would try to hitch. But if I just miscalculated my daylight, I would have to tough it out till first light.
Quoted: 598 Post(s)
Liked 283 Times
You're correct but there has been a time or two when B&B/hotel touring where we got delayed and couldn't make it to our predetermined destination for the evening, and of course we didn't have our complete camping gear with us, so in that regard, I'm interested in what others could create as a small emergency or contingency pack.
I never carry overnight stuff on any road day ride. I figure that worst case I could pull an all-nighter walking. Most roads I have ridden on will have a car at least every few hours and the more remote the more likely they are to stop and help. On lightly traveled desert roads I have found that almost every car will stop if you look like you need help.
That said if you must carry something, one option would be a 6 or 7 ounce bivy like the ones from Titanium Goat or Borah. I use my Borah Side Zip as my primary shelter even on some long trips where I camp every night for longish periods. It is small and light enough to fit in my jersey pocket and hardly be noticed.
Another option would be wind pants (3-4 ounces and packs quite small) and windshirt (3-4 ounces and packs quite small) plus maybe a warm cap.
Still another option is a 3 ounce DriDucks Emergency Poncho. I often have carried these on long day hikes.
Sunshine
Quoted: 10954 Post(s)
Liked 7,483 Times
I would never bring overnight gear on a day ride.
If there was a chance I would be out at a time when temps would drop, I would bring appropriate clothing for the temp change.
If I got a late start to a massively long day ride(which 140mi is just that), I would make the changes necessary to still get home at my goal time...so it would be a shorter ride.
A battery pack is with me for all long day rides to ensure my cell phone has enough power at all times. That way, I can just call family if needed.
Calculating for all the what-ifs in the world is an impossible waste of time.
What touring should have taught all practitioners is fearlessness.
Enjoy the moment and what ever happens you'll be able to handle it.
Quoted: 141 Post(s)
Liked 9 Times
Ive walked five miles with a broken forked bicycle over my shoulder, and over 20 cars passed with not one stopping to offer help. And in an area with no cell service.
Its just condescending criticism on the subject. So here, I will rewrite what you said so it sounds less judgmental, and would be an interesting addition to the topic.
What touring has taught me is fearlessness.
I enjoy the moment and what ever happens am able to handle it.
FWIW, I have only needed to hitch a ride a few times with my bike in my 65 years, but I have been with others who have quite a few times and I don't recall any of them waiting much more than 20 minutes if they made it obvious that they wanted help.
A lot depends on where you are and the situation. I have hitch hiked back to my car or to a trail head on backpacking trips and never had a problem. In places like the Yosemite area I have often been picked up by the first or second car to pass. Other places are tougher, but walking, all night if necessary, isn't impossible. The good news is that the more remote or the more threatening the conditions are the more likely folks are to stop.
Also if it was a dangerous situation I'd resort to arm waving and jumping up and down to get motorists to stop. If the distance was only a few miles in fairly benign conditions and there was no injury, I'd just walk.
