hydraulic hose routing, eek!
my IRO Mia frame arrived a few days ago, and i encountered a dilemma when installing my juicy 5's. the cable guides underneath the top tube are spherical, and i'm not sure how i can go about installing the hoses inside the guides. will it be necessary to bleed my brakes to guide that hose through??! these are the first hydro brakes i've installed, and i feel pretty stupid not being able to figure this out. thanks!
Wood Licker
Bikes: Trek Fuel EX 8 27.5 +, 2002 Transition Dirtbag, Kona Roast 2002
Quoted: 23 Post(s)
Some older frames don't have hydro mounts. You may have to use good old fashioned zip ties
Gravity Is Yer Friend
Location: "Over the Hill" and going down fast in the 805.
Bikes: Scott Gambler, Scott Ransom, Kona Bear, Bianchi 928 Carbon/Chorus, C'Dale Rize4
Zip ties or go to your lbs and they should have hose mounts that stick on the frame and are open on top so the hose will snap in.
Another option if you are mechanicly inclined, you could use a dremal to cut open the tops of the current mounts but you would still need zip ties to hold the hoses in. You may also want to check with the manufacturer before doing this and see if it will void the warranty.
Bikes: Lots
There are also these little clamp thingies that you screw into your cable guides and have an open clamp for the hydraulic hose. They work pretty well and I use them on my bike.
"Life is not a journey to the grave with the intention of arriving safely in a pretty and well preserved body, but rather to skid in broadside, thoroughly used up, totally worn out, and loudly proclaiming, "WOW, What a Ride!" - unknown
"Your Bike Sucks" - Sky Yaeger
Bikes: rockhopper comp 05
My friend didn't have disc brake mounts on his frame, so he welded them on !
I'm not sure if it was a good idea, but he did a pretty good job, and they're still there even a few years later.
THIS BIKE'S 4 U !!!!
Location: Western, NC .... (Pisgah, Bent Creek, DuPont)
Bikes: HARO Xtreme X2, K2 Lithium 3.0, K2 Beast, K2 Flyin' Monkey, DiamondBack Accent EX, DiamondBack Axis TR
My HARO Xtreme came with removable clamps on the cable stays that are very handy in that regard.
Otherwise just use the zipties like Mael said. I've also had to use them to snug down the derailleur cable to prevent more chainstay wear. It was almost thru my frame already.
Zipties are right there w/ duct tape, well almost anyways....
