helmet light for Giro Atmos?
Does anybody know of a light that could attach to a Giro Atmos? The design is such that there's not enough room for certain attachments.
(I'm actually a speed skater, but this is a popular cycling helmet, I guess.)
Caffeinated.
Bikes: Waterford 1900, Quintana Roo Borrego, Trek 8700zx, Bianchi Pista Concept
Hey Skater-welcome.
I've attached a Petzl MYO XP to my Giro Pneumo. The rear "vents" of that hemlet keep the lamps strap in place, and I use 2 "zip" ties on either side of the lamp portion to keep it stable. No problems with it "flopping" about or anything on a 300K ride last weekend.
The "zip" ties I use are very low break strength-just in case I happen to have an incident involving gravity (and my head). The lamp will break away. Now I have no idea if this voids my helmets safety rating or not-but having the lamp there in the first place offers a lot of "being seen" protection. This gives me the ability to point it directly at drivers eyes when I can't be sure that they have seen me-folks who may have attempted to turn in front of me in paticular.
I just took a look at my Atmos, and my lamp will easily fit with a similar setup (zip tied in front). One way to make "break away" zip ties, if you can't get any low strength ones, is to cut a small notch or slice part way through the zip tie once attached. This will take trial & error, but worth it from an added safety perspective. Should you go down (stressing "should")-you'd want anything attached to your helmet to come off--and away from your face.
I also have a Planet Bike sport spot 4 LED (in blink mode)-attached just above the Petzl Myo--as a passive "be seen" light. This light has a small strap that wraps between & around vents, but the light itself attaches to the strap with a plastic "quick/slide" release. This lamp is an excellent one "to be seen", but not enough light to see with.--I picked it up on closeout for a third the price listed at REI.COM (seems there all out). This model also can be mounted on your bike. I had this light mounted to my handlebar, in steady mode, to meet the legal requirement (a white light must be mounted to the bike)-on last weekends ride.
--You might get other (better) headlamp ideas by moving this thread, say to advocacy&safety-or perhaps even to the Commuting forum.
[EDIT] Added pictures of my setup (on my Pneumo), with and without my rain cover-and with the MYO XP on in daylight (camera flash used):
Sorry it took so long to respond...I'd lost the link to the forum, lol.
That PETZL thing's exactly what I was looking for. Thanks a ton.
On a side note, you've really accessorized your helmet!
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
Or you can get a cateye el-400. It's designed to strap to a helmet vent and is adjustable.
Ready to go anywhere
I got a Petzl Myobelt 5 a while ago. The biggest advantages with this helmet, for me, is:
The halogen light is probably overkill on roads with street lights, and I'm not sure how much light the halogen lamp gives on its own since I always run it together with a hub dynamo powered Lumotec light.
Some pictures I took when I first got it:
- Combined led/halogen light.
- No batteries on the head.
- It uses C-size batteries, giving over 10 hours halogen light or 200+ hours led light.
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
To see where you are going? So you can be seen from the front? So you can be seen from the rear?
All of this?
