Rim brakes for Tandem?
Old 03-20-17, 04:59 AM
Road Fan's Avatar
Quoted: 1853 Post(s)
Liked 659 Times in 502 Posts
I need help to identify a few good options for tandem brakes for canti posts that will work well with drop-bar road levers - I like Ergopower, but I can go a different way. I'm looking for suggestions (gonna duck now!)
On my steel Meridian frame, which I'm now building for the first time, I have cantilever posts. I see three options for what calipers to use.
1. Paul vintage-style cantis with Campagnolo or TRP drop-bar brake levers. I have these on my 650b with the silver drillium TRPs, and they work well, but are sensitive.
2. Used Shimano low-profile cantilever calipers - these seem to be kind of a Tiagra grade?
3. a V brake or mini-V brake.
I'm planning for this tandem to use Gen 2 Campy Ergopower levers, but I realize the pull ratios on some of these might not be well-suited to a heavy tandem with heavy riders. I put a set of Paul Mini-V (Mini-moto?) brakes on my wife's Terry, and they are quite powerful but also very sensitive. They also need a better optimized lever than a Campy Gen 3 Ergopower.
A really good combination doesn't just jump out at me.
Road Fan is offline
Old 03-20-17, 12:58 PM
Bikes: Chinook travel/gravel/family tandem, Chinook all-road, Motobecane fatbike
Quoted: 232 Post(s)
Liked 34 Times in 25 Posts
There was a similar thread recently:
https://www.bikeforums.net/tandem-cyc...el-agents.html
Use the Ergopower levers if you like them. As you already know, you'll have to pair them with road brakes (or mountain brakes and a cable travel adjuster).
How big tires [and fenders] do you plan to run? If you're staying under 45mm, I'd go with Tektro 926 or RX6 mini-V and some Koolstop cartridge pads. For bigger tires/fenders you'll need to use cantilever brakes or V-brake with Travel Agents. I think you can get some low profile Shimano XT cantilever brakes a few places still.
Your wife's bike might be better off with a less sensitive brake like Spooky, Empella, or Tektro CR720.
OneIsAllYouNeed is offline
Old 03-20-17, 01:05 PM
oldacura's Avatar
Bikes: 1998 Co-Motion Co-Pilot, 2015 Calfee Tetra
Quoted: 177 Post(s)
Liked 6 Times in 5 Posts
If you can find a pair a Dia-Compe 287V brake levers, these work great with V brakes (don't need a Travel Agent) and provide great stopping power. You'll also have to use bar-end shifters but these work better than the "brifters" that most people use.
oldacura is offline
Likes For oldacura:
Old 03-20-17, 02:01 PM
Jedi Master
kingston's Avatar
Bikes: https://stinkston.blogspot.com/p/my-bikes.html
Quoted: 1759 Post(s)
Liked 488 Times in 313 Posts
Cantilevers are the obvious solution given that they work with road levers and your frame has canti posts. What am I missing?
kingston is offline
Old 03-20-17, 03:20 PM
Quoted: 2488 Post(s)
Liked 735 Times in 520 Posts
Shimano LX-V v-brakes will clear any size of tire/fender combination made that will fit on a 26" rim. And if one isn't married to a specific kind of lever (like a brifter or something) Tektro makes drop levers in both long and short pull ratios. I had long pull calipers (disc) and could have really made use of the long pull Tektro levers, but I wanted to use Cross Levers as well and Tektro only makes those in short pull grrr. So I had to use Travel Agents, which is an option the o.p. could also make use of. As I understand it, standard Travel Agents for v-brakes outperform noodles. They are considered an upgrade. The same is not true of inline Travel Agents used with disc calipers. Avoid those.
Leisesturm is offline
Old 03-20-17, 03:58 PM
Disco Infiltrator
Darth Lefty's Avatar
Quoted: 3126 Post(s)
Liked 2,102 Times in 1,366 Posts
My bike came with the 287V or a similar product and I switched it back to flat bars. I wanted the V brakes more than I wanted the drop bars.
Genesis 49:16-17
Darth Lefty is offline
Old 03-21-17, 05:19 AM
Road Fan's Avatar
I don't think brake clearance of the fenders will be a big issue. Wheels are 700c with Dyad rims (23 mm wide outside, 18 mm inside), and my tires will range from 28 mm to 38. Not sure I can fit 38s with fenders, but if I can I would want 50 mm fenders. I'm not sure standard cantis like Neo-retros are needed, but I have a set on my 650b that I want to swap out. I think the extra performance of Neo-retros would be better used on a tandem than a single-seat rando bike.
Road Fan is offline
Old 03-21-17, 06:56 AM
Paul J's Avatar
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times in 65 Posts
We are using Avid V brakes on our tandem with cantis. We've been using these for years with Travel Agents and have had no problems at all. Early on I had thought about switching out to traditional cantilevers but have found these to work better the the cantis on my cross bike. We are happy with to braking and the adjustment possible. We've had none of the issues some people have talked about on using V brakes with the Travel Agents.
Paul J is offline
Old 03-22-17, 01:39 PM
Quoted: 232 Post(s)
I can confirm that the Shimano Deore XT cantilever brakes work well on a loaded or unloaded tandem with road levers, Dyad rims, 32-37mm tires, and 52mm fenders. The initial setup is slightly time consuming (as with any cantilever brake). They hold their adjustment well enough that we could wear through cartridge brake pads and only adjust the cable barrel adjuster. (As an aside) I wish I could say the same about my Avid BB7 with 203mm rotor.
The Paul Neo Retros would be fine too. Stoker heal clearance or pannier clearance could be an issue with the Neo Retros.
Old 03-26-17, 07:18 PM
WPH
WPH's Avatar
Bikes: 2015 Apollo Syncro tandem, 2006 Scott CR1 SL (still a beastie race bike), 1993 Trek T200, 2006 Fuji Absolute Le, 2000 Thorn Club Tour
Quoted: 16 Post(s)
What he said. Tektro also do a good quality, good value v-brake compatible drop-bar brake lever. Bar-end shifters are very good on a tandem, I think they are better than brifters also. I have swapped both my road tandems to this system, excellent braking, excellent shifting!
Post photos and weight when you are done!
W
WPH is offline
Old 04-01-17, 04:31 PM
Nigel
nfmisso's Avatar
Bikes: 1980s and 1990s steel: CyclePro, Nishiki, Schwinn, SR, Trek........
Quoted: 384 Post(s)
Liked 6 Times in 6 Posts
Originally Posted by Leisesturm
.....but I wanted to use Cross Levers as well and Tektro only makes those in short pull grrr. .......
NOT true. They are available in the UK, and probably other places:
https://www.sjscycles.co.uk/brake-le...clamp/?geoc=US
New Tektro RL740 Road Bicycle Bike V-Brake Levers Silver | eBay
and for 31.8mm bars:
nfmisso is offline
Old 04-01-17, 05:52 PM
New Tektro RL741 Road Bike V-Brake Levers Black | eBay
Good to know. I assure you, however, that 3 years ago when I did the conversion Tektro was only making cross levers in short pull. At least in the U.S. I did look pretty hard.
Old 04-16-17, 05:59 PM
Road Fan's Avatar
HERE is what you are missing:
You are assuming they (Paul Neo-Retros) WILL work with my road levers (Campy 10 speed Gen 2 or Gen 3 Ergopower).
So: Will they? Have any of you tried this? With the TRPs they are not bad, but not as good as a regular road caliper. And are the TRPs equivalent to my Campy Ergos? Anybody have any actual insight to share?
Road Fan is offline
Old 04-17-17, 08:24 AM
Quoted: 232 Post(s)
You might have better luck in the mechanics forum. Here's an almost useful thread:
https://www.bikeforums.net/bicycle-me...ll-ratios.html
You'll see in there that Campy road levers generally pull a little more cable than Shimano road levers. This would make Campy levers feel weak with brakes intended for Shimano road levers. Your best bet might be to slap some MTB V-brakes on the tandem, without any travel adjusters. I think I would still err toward shorter V-brakes, in the 90 to 102mm range. Here's a really nice compilation of linear pull brake arm lengths:
Tech Tip: V-Brake Arm Lengths | GRAVELBIKE
Old 04-18-17, 12:59 AM
Bikes: '92 22" Cannondale M2000, '92 Cannondale R1000 Tandem, another modern Canndondale tandem, Two Holy Grail '86 Cannondale ST800s 27" (68.5cm) Touring bike w/Superbe Pro components and Phil Wood hubs. A bunch of other 27" ST frames & bikes.
Quoted: 110 Post(s)
Liked 4 Times in 4 Posts
You can buy travel agent pulleys that change the pull ratio to what you want to make any lever and brake combo work.
I like anything in the Mafac tandem vein. Not sure what Paul calls those these days. Strong brakes. They'll crush rims, so they'll stop the bike when it matters.
Don't forget the drag brake.
mtnbke is offline
Old 05-29-19, 01:46 PM
Hi, Paul --
Wife and I have a tandem with pretty stock Shimano stuff. Brakes are not confidence-producing and I don't really want to to disc brakes. The Avid looks quite nice and I'm pleased to hear you are having success and recommend them. I'm not familiar with Travel Agent (I'll look it up) and I guess I'll have to do some measurements on our bike. Thanks for your comments. They're helpful
Diego
Jazzman715 is offline
Old 05-29-19, 01:51 PM
I am potato.
base2's Avatar
Quoted: 1782 Post(s)
Liked 1,620 Times in 926 Posts
These work good.
base2 is offline
Old 05-29-19, 05:05 PM
Quoted: 612 Post(s)
Liked 387 Times in 270 Posts
Brakes for a tandem should be more powerful than brakes for a single. With few exceptions manufactures make products for fairly light single riders. Paul component engineering makes the Touring Canti. The Neo Retro Canti. The MotoLite and The MiniMoto. All but the MotoLite will work with short pull levers. Paul is a master machinist. Pauls products are strong, lite and emasculate. I have a 15 year old set of MotoLite brakes that I put on my sons Fuji touring bicycle. The difference in ease of setup and stopping compared to the Shimano Deora brakes that were on it was quite noticeable. I have the Paul Klamper on my touring bicycle. If you had disk mounts on your tandem you could even use Campy brake levers or brifters with these. Paul makes long, short and Campy arms for the Klamper. The Klampers have no play in them and I know from experience they stop better than the TRP Spire, Spyke and the Hy/RD calipers that sit in my toolbox. The Rodriguez Big Squeeze looks like it would work well for a tandem. Just remember if you can get past the love affair with drop bars you can get improved braking with Paul's brake levers on all of these brakes.
Rick is offline
Old 05-29-19, 10:11 PM
just another gosling
Carbonfiberboy's Avatar
Quoted: 3879 Post(s)
Liked 1,931 Times in 1,378 Posts
Our 2003 Speedster came with V-brakes, Avid 7, set up with Travel Agents, drop bars of course, Shimano brifters. This has all worked like a charm. Stops the bike. No rim brake is going to stop the bike like a disc. Not possible because of the necessary large travel for the pads. But our system has worked wonderfully for us over the years. We use SwissStop green pads. The Travel Agents have not been a problem.
The main thing we've discovered is that if you're going to ride the thing hard or ride in hilly terrain, you must have deep aluminum rims. We have 28mm deep rims and they work fine. We blew several tires off box section rims before we figured it out. We like our Kinlin XC 279 36H rims.
Results matter
Carbonfiberboy is offline
Old 05-30-19, 07:16 AM
Quoted: 612 Post(s)
My Magura HS66 rim brakes outperform any disk brake that has been made for bicycles. They are on my 1990 Burly Bongo Tandem. The rim is a larger disk. You can only get there flat bar versions now. So if you want dependability and ease of use than get the Magura HS33 for flat bars. The Travel Agents have been discontinued and are not easy to find.
Rick is offline
Old 05-30-19, 11:05 AM
Disco Infiltrator
I wonder if anyone has tried a Wolftooth Tanpan which has a similar function to the Travel Agent. The 10-speed version has decent gain (though more like 3:2 not 2:1) and a nice built in barrel adjuster which is nice to have when attaching brifters to V brakes
Old 06-02-19, 07:11 PM
Bikes: 1998 Bontrager Road Lite, 2005 Trek 9.8, 2008 Santana Arriva Tandem w/ S&S Couplings, 2009 Electra Rat Rod, 2010 Bike Friday Pocket Rocket, 2010 Cannondale SuperSix, 2011 Cannondale CX, 2011 Cannondale Tandem, Xtracycle, Surly Pugsley Necromancer
I am a big fan of the Paul Components MiniMoto for rim brakes w/ short pull road brake levers. I switched from Avid Single Digit w/ Travel Agents to the MiniMoto on our triple tandem and am very happy with the increase in stopping power. They're pricey but worth every penny.
PDub62 is offline
Old 06-03-19, 06:35 AM
Bikes: Merlin Road, Rivendell Road, Arvon custom tandme, Hi-Light G-7
Quoted: 24 Post(s)
Liked 11 Times in 10 Posts
I use some ancient ergopower levers (8 speed) on our tandem. The left lever works fine with Shimano front cantilever due to short cable run. I was only happy with Strange cantilever for the rear after lots of judicious effort at removing cable slack.
When we changed tandem, I switched to TRP Spyre for the rear so switched to dealing with different set of problems.
scycheng is offline
Old 06-03-19, 07:02 AM
Quoted: 612 Post(s)
I am quite heavy and my touring bicycle came with the Spyres. I have Spyres, Spyke and HY/RD disk calipers sitting in my tool box. They are made light and flimsy. I have the Paul Klampers and wished I had had them from the start. You can order them with long, short or Campi caliper length arms. They are expensive and worth every penny that I paid for them. I also use Yokozuna compressionless brake cable housing. It is the best compressionless housing. The Paul Klampers have no play in them and they are not flimsy. Although I would only by Paul products if you like to stop.
Rick is offline
Old 06-05-19, 06:57 AM
Quoted: 24 Post(s)
The reason to switch to disk in the back, other than long cable run, is that I can't tell how hot the rear rim is getting during sustained braking on the rear of a tandem. The front rim I can tell by touch if nothing else. I am blinded with respect to the rear rim.
No rear rim brake can ever get around that problem. I had the long defunct Strange brake on the rear and they worked quite well as a rim brake once I got the slack out. I doubt if Paul Klampers will change that even though they maybe really really good cantilever brakes.
scycheng is offline
