CX with a triple
Bikes: '05 Ibex X-Ray, '99 Specialized Allez, '94 Stumpjumper, '90 Diamondback
CX with a triple
I understand that CX race bikes usually have double rings. I'm looking at buying a bike for the following priorities:
definitely commuting
likely racing
hopefully touring
the two bikes in contention have a double and a triple. Obviously the triple can do it all but will it be a disadvantage for racing? Why or why not?
likely racing
hopefully touring
Get the stick.
Bikes: 12 Y.O. Litespeed MTB, IRO Jamie Roy fixie, Custom Habanero Ti 'Cross, No name SS MTB, Old school lugged steel track bike (soon)
I'm guessing the racers don't run triples because they don't really need the granny gear-they are off the bike before they would ever use it. I suppose you could argue that the chainline is better with a double, but this is fairly insignificant, IMO. I doubt that the extra 100 grams gained from using a triple is really going to cost you the race. If you want your bike to do it all, go with the triple.
CX is pretty traditional. I think many people are scared to break the mold. Go with what works, not with what everyone else is riding.
human
Bikes: 2005 Litespeed Teramo, 2000 Marinoni Leggero, 2001 Kona Major Jake (with Campy Centaur), 1997 Specialized S-Works M2, 1992 Specialized Rockhopper
triples are a real pain in really muddy [read: classic cyclo-cross] conditions. you are almost guaranteed to (a) drop your chain (b) jam your chain (c) throw you chain with a triple. a lot of guys even run singles in races because of front shifting problems.
moreover, a triple in a race situation is ABSOLUTELY USELESS. got that? it's ABSOLUTELY USELESS. you're probably better off running any hill that requires a gear lower than, say, 38x27.
when walking, just walk. when sitting, just sit. when riding, just ride. above all, don't wobble.
The Irregular Cycling Club of Montreal
Cycling irregularly since 2002
i agree. a triple in cx racing is useless. you're asking for a mechanical in any conditions, dry or wet. depending on where you live (ie. if its hilly or not) you probably wont need a small ring for commuting either. as for touring, this is up for debate, but a small ring can come in handy if you are hauling heavy panniers in a stiff wind going uphill...
Zugster Bags
Bikes: Nishiki fixed gear commuter, Trek 560 road bike
I used to ride a CX bike as my commuter, and I had it set up with just a single front chainring, which I actually think is probably ideal for most moderate commuting (I live and work in San Francisco - my commute is all city streets with moderate to steep hills. It ran a 39 chainring with a 12-25 8-speed cassette and I felt that was all I needed).
It had a double when I bought it, but I took it off when I realized I never ever used the 50-tooth chainring. I just took a few links off the chain to make sure I never dropped it on the 12 tooth cog.
I also rode it offroad with the same 1x8 setup - I think it's great, and there's no worries about rubbing the chain against the front derailleur cage in any combinations, because there ISN'T any front deraileur
. For loaded touring, I'd definitely go with a triple though.
blog :: twitter :: flickr :: zugster bags :: pelican@velospace :: kogswell@velospace
You might want to send a PM to RonH. He as a 2005 Nova he uses for commuting. There are others as well, but they probably haunt the Commuting Forum more than this one. Many commuters ride CX bikes, and that forum is 5-10x more active than this one.
Get the stick.
For racing, you can always tighten the adjustment screw on your front deraileur, and make it into a double. Plus, if you do bail your chain, it will likely end up on the granny, not jammed in between your crank and frame.
Tiocfáidh ár Lá
Bikes: A whole bunch-a bikes.
I've been racing an old touring bike for years. It's a triple that I just take the inner and outter rings off of for racing then put the rings back on for touring. A single 42 chainring up front works great for me. Just lower the FD right over everything for a chain guard. My girlfriend got a Poprad w/ a triple for the same reasons you did and it works out just fine.
I've raced cross on a Seven with a triple (it was a test bike). Didn't take it through heavy mud, but I certainly used all three rings-big ringing pavement and downhill sections, using the middle for hard pack, and spinning the granny in soggy grass and high resistance spots. was actually quite a nice setup, and if I hadn't been drunk on the line I willing to bet it would've quite awesome.
Bikes: 2016 Tom Kellogg steel Spectrum all-road, '89 Eisentraut Rainbow Traut, '81 Marinoni Special, 2018 Ritchey Road Logic, 2006 Ritchey Breakaway Cross, 2009 custom Joe Wells alu Tsunami CX, '71 Favorit (Czech Rep) Special, 2012 Co-Motion Tandem
I have a triple cross bike- you can and do drop your chain more frequently in races than you would on a double- often because you forget which ring you're in (middle or large?). The easy solution is to simply block your front derailleur to not shift all the way over to the granny, and install a third eye to prevent dropping the chain. The third eye comes off easily for your touring/triple ring adventures.
https://www.cambriabike.com/shopexd.asp?id=13686
