Training at low cadence and knee pain
Bikes: Rivendell Romulus
I have recently incorporated some low cadence pedaling, 50-70 rpm, into my training. Normally I experience little to no knee pain but with the switch to lower cadence my knees have been hurting some during the ride and then for a few hours afterward. The next day I'm fine. The pain seems to be toward the front of my knee.
I have been taking daily glucosamine chondroitin supplements regularly as I'm 54 and figure I need all the help I can get.
I don't think my position, e.g. saddle height, is a factor as I've put in about 1,600 miles since January 1 of this year and did about 4,000 miles last year without any knee problems.
I would like to continue this low cadence training but I don't want to damage my knees. Any reasonable guidelines out there?
Bikes: Cervelo Soloist / Cervelo P3
Is this lower cadence and bigger gears while cycling uphill (which can produce knee pain), lower cadence in the same gear on flat ground, or some other set of circumstances?
What benefits do you see (or expect to see) from lower cadence training?
Chris
Chris
Knows Bigfoot's Momma
Bikes: yeah; got a couple...
Lower cadence and bigger gears will make you stronger, but can also cause knee problems... I suggest you give yourself more saddle time spinning lower gears. Don't be in a hurry to get strong; take your time. BTW- I also take glucosamine, and it seems to help. I like doing hills, and my bike really isn't geared for it (42-30 is my lowest gear), so my knees aren't always happy either.... They're much happier when spinning.
nice lugs baby!
nice lugs baby!
In "The Ultimate Ride" Carmichael recommends doing Tempo training in a 70-75 cadence range. That's what I've been doing. I know that's a higher cadence than I originally posted. I should have been more careful to post the correct cadence. Carmichael recommends something similar on hills.
I find it hard to even get my heart rate up to the Tempo HRZ at this cadence as my muscles just aren't strong enough. So I am doing it to increase my leg strength and I'm doing it on hills and on the flats. I think it's a good training technique.
If you're putting in lots of miles on varied terrain you can't help but suffer from knee pain at times, especially if you do steep climbs. People who train on fixed gear or single speed bikes must be forced to mash on lots of hills. I suspect their knees must complain.
I spin at a high (> 90 cadence) most of the time. Spinning taxes the aerobic system more than mashing. It's also easier on your chain, feet, etc. But lately I've been noticing that I run out of muscle before I run out of breath. Lower cadence workouts will help me build more muscle.
I've done months of training at high cadence so I don't think it's premature to be doing this type of training.
What I want to know is how much or what kind of knee pain is too much. At what point should I give it a rest?
_______________
-Craig
_______________
-Craig
Lets Ride
Bikes: Trek 1200, Lemond Sarthe, Gary Fisher Tass
_______________
-Craig
_______________
-Craig
Now my quick answer: Give it a rest when it hurts.
Phil
When I first integrated muscle tension intervals into my training, I got some residual interior knee pain too. I reduced the intensity and duration and gave my knees the opportunity to get stronger. For me that lack of strength was definitely an issue going in. After my knees got stronger, the MT and big gear work has gotten a lot easier. Occassionally I end up having one knee, which had some cartillidge damage and repair a few years back, that I will need to ice after climb repeats. Otherwise, I found that I was able to benefit a great deal from adding these to my workout. It just took some time for the physiological changes to result.
Having said all of that...you, and what might work for you, could well be completely different. Listen to the feedback your body is giving you and act accordingly. When in doubt, ease up.
Ride it, don't fondle it!
Bikes: Raleigh M80, Bacchetta AERO, Bacchetta GIRO, BikeE, 83' TREK 970, Catrike Speed, IRO Fixie/SS
Originally Posted by operator
Why would anyone actually train in low cadences. That is unless you really don't like your knees.
Go back to spinning those low gears and do Nautilus and weight training for leg strength.
Guest
Posts: n/a
Quoted: Post(s)
Cycling at low cadence just makes you good at being slow. I don't know how many times I've told this to some cyclist that's grinding away in high gears. C'mon, if you want to get stronger, get to a gym and lift weights! THAT will make you strong. Low cadence/high gears just makes you slower, gives you knee pain, and does NOT build strength, sorry to say.
Koffee
Koffee
Nonsense
Bikes: Affirmative
Quoted: 880 Post(s)
Liked 541 Times
Koffee
Koffee
Thank you all for your concerns and thoughts. I appreciate this forum and the range of advice one can receive on it.
-Craig
-Craig
