Sliming tubes???
Dances with Rocks
Putting Slime, (a tire sealant), in the tube to prevent leaks from small punctures. They also sell tubes with slime already in them.
Slime is a brand name of sealant but there are others.
https://www.slime.com
If everything seems under control, you're just not going fast enough...
To become a registered member of BikeForums Click Here
Quoted: 430 Post(s)
Liked 460 Times
weighs you down a lil bit if you're picky about that... then again, i just popped my tire today also slime only works for like small punctures 1/8 inch in diameter
I’ve only had problems when I added slim to my tubes. First off, it never prevented my flats, even the smallest thorns gave me problems. Second, once a flat occurred the slim leaked everywhere (not a major problem mind you, but it still caused me to clean my rims.)
NOT a weight weenie
We use a product in the store called True Goo. Coupled with a semi descent tire liner, we give a gurantee of 1 year with no flats. If you do then yu get a tube for free. So far we have not gotten anyone back in. Yes it adds weight but.....
