1inch(25.4mm) threaded to 1 1/8inch(28.6mm) threadless adapter
Bikes: Paratrooper, Dahon D7, freeride 12", Yizhe 14"(1-sec-folding)
Quoted: 12 Post(s)
Hi Forum of folding bikes, Good Evening!
I am looking for a part to extend my folding bike's front post. The adapter should be solid on both end except a hole for the long screw to go through. It's hard to find because the 1 1/8 inch end has to be at least 6 inch long.
Attached please find a picture of the bike. The inner diameter of current front post is 1 1/8inch(28.6mm). Current adapter is also 1inch(25.4mm) threaded to 1 1/8inch(28.6mm) threadless, but it's too short on the 1 1/8 inch end. I need it to be longer so that I can lift the entire post with handlebars more (with some spacers to go into the gap created).
Any info is appreciated. I found several items but they don't look like right fit.
This one: https://www.amazon.com/Sunlite-Cromo...ZD5XY04MCZ5Y4P
It's fat end is hollow with an inner diameter at 25.4mm. Hence it's an extender instead of an adapter.
Another one: https://www.amazon.com/gp/product/B0...=ADIKZAFTSWMNW
It looks hollow on the fat end too.
3rd one: SpeedPark 2052-594 Insert Conversion for Bike 28.6mm Stem / 22.2mm Fork - SLV | eBay
Its size for thinner end is unknown 'cuz it's said to be 1-inch(22.2mm), but 1-inch is actually 25.4mm. Also it has some kind of hook on the fat end, which might be a good indicator for hollowness as well. Unless it's a cap?
I am having trouble understanding exactly what you need, so forgive me if this isn't what you need, but Velo Orange has a 180 mm one that might work.
Quoted: 12 Post(s)
Quoted: 12 Post(s)
thanks @jur and @12boy
Sorry for the confusion. Basically I need something like this but much longer on the fat end:
Dimension Steerer Adaptor 1 quill to 1-1/8 Threadless Black
Bikes: Origami Gazelle, Origami Crane 8, Origami Cricket 7
Quoted: 452 Post(s)
Liked 405 Times
Paul Pinigis
Owner of Origami Bicycle Company
Paul Pinigis
Quoted: 12 Post(s)
Quoted: 12 Post(s)
Quoted: 12 Post(s)
@all
Correction: the thinner end's outer diameter is 22.2mm. Just measured this morning.
Quoted: 12 Post(s)
Add a picture of current adapter.
It's threaded to threaded, correct?
Quoted: 380 Post(s)
Liked 106 Times
I do not believe those adapters are designed to be used daisy chained together. Use one and one only not one on top of another on top of another which is a daisy chain. Please do not quote me on this as I then have to go through and get rid of them on my account. I can and do go back on my own and look at posts. Multiple use of those adapters could lead to a catistrophic failure. They are designed to work with leverage put on by one of them not by several of them. Roger
Quoted: 8 Post(s)
Is this what you are looking for:
High Rider Stem Adapter 28.6/22.2 | SOMA Fabrications
I used one of these on my Raleigh Twenty.
Quoted: 12 Post(s)
@veloceleste Thanks!!!
Quoted: 12 Post(s)
It's done. 1 longer adapter + 3 x 20mm Carbon Fiber spacers
Thanks for all the info!
