glass in tire - how to fill the hole it left?
I'm sure you folks around here have gone over this so feel free to redirect me to a previous thread. I picked up a flat on the steed last night in my rear tire. Dug a triangle shaped piece of glass out of the center rubber. The hole isn't all the way through the tire and patched the tube and rode it tonight. My question is that there is still a small but noticeable hole in the tire...well, if you go over your ride with a meticulous eye. Should I fill the hole? Is it a problem? What should I use? I think I've seen folks recommend Crazy Glue or Animal Glue.
Thanks for the wisdom.
oaxacarider
these are couple options, or if the whole its too big just get a cheap new tire and dont even bother, if money is an issue you can make your own "tire shoe" out of an old tire or a leather piece from an old shoe.
https://www.performancebike.com/shop/...tegory_ID=5412
https://www.nashbar.com/profile.cfm?c...eid=&pagename=
Chronic Tai Shan
Bikes: Pake Single Speed
I had this happen too. I moved the tire to the rear. I put about six layers of electrical tape of the hole on the inside of the tire. There is no bulge where the tape is and I haven't had any problems since February.
Edit - Your hole doesn't go all the way through, never mind. --- Do you believe that lightning doesn't strike twice. Move it to the back and forget about it.
Bikes: Mercian, (KOM),Waterford Paramount,Schwinn tempo,Pretenamount ss,Custom Kirk, Reserectio and many more.
Same thing happened to my front tire about 500 miles ago. I left the big hole open, next ride I see something in the hole...grit from the road working it's way into the tire. I dug out the rock and filled the hole with Shoe goo. That worked great! I can't find the spot now! Any flexible glue that will stick to rubber should work, lots at the hardware store. Good luck
Perineal Pressurized
Tiny holes I hit with a little bit of super glue. Holes big enough to potentially catch another stone in get a dabble of Shoe Goo. If I feel the tire is comromised I just mount another, always keep a couple cheapies hanging from the rafters.
This is Africa, 1943. War spits out its violence overhead and the sandy graveyard swallows it up. Her name is King Nine, B-25, medium bomber, Twelfth Air Force. On a hot, still morning she took off from Tunisia to bomb the southern tip of Italy. An errant piece of flak tore a hole in a wing tank and, like a wounded bird, this is where she landed, not to return on this day, or any other day.
Bikes: Trek 5300
Any hole in the tire that is big enough to be seen should be taken care of immeadiately since dirt will work through and ultimately cause another leak in the tube. One boot that worked sucessfully for the life of the tire was made as follows. A one inch sqare of heavey duty kitchen aluminum foil secured in place by a two inch square of cloth tape.
(Grouchy)
when i first got my pursuit bike (early '02), i was riding around an old vittoria tubular in the front. after a while, the tire developed a small gash in the rubber. the inside and the casing was still good, but there was a gap in the rubber in this one spot. i was only riding it for a couple weeks until i got my new front built up...anyway, to sort of correct this gap, i filled it in with rubber cement. the rubber cement melted some of the rubber, which got soft and putty-like, and never re-hardened. fortunately, i got wise and stopped riding the bike before it became a problem. about a year and a half ago, i decided to play around with that front wheel and tire to practice my tubular mounting technique. the spot where i rubber cemented it was still like putty.
moral: never EVER use rubber cement. just because it says rubber in the name, doesn't mean it's good to use on rubber products.
2-Cyl, 1/2 HP @ 90 RPM
Bikes: 04' Specialized Hardrock Sport, 03' Giant OCR2 (SOLD!), 04' Litespeed Firenze, 04' Giant OCR Touring, 07' Specialized Langster Comp
I's just patch the inside of the tire with a large glue tube patch. Those things are thick and should work pretty well. Put a small piece of sheet metal between the patch and tire.
polishing my grill
Bikes: Croll
Park makes a boot. I've never used it, but I do carry one around in my tool bag. I think it was like two bucks at Performance.
likes avocadoes
Bikes: heh, like that info would fit here...
I still swear by the inch-long strip of cotton hbar tape. Usually I have lots left over after taping my bars, so I just throw what's left of the roll in my bag and use it to patch up any tears in the tire. I don't worry about holes in rubber, just torn threads...rubber is the least important part of the tire.
Spoked to Death
Bikes: Salsa La Cruz w/ Alfine 8, Specialized Fuse Pro 27.5+, Surly 1x1
I second the recommendation to use some Shoe Goo, that stuff is super-duper.
Put something on the inside of the tire like some cloth tape (though it doesn't matter what, really, just something that isn't stretchy, and won't abrade the tube, like mentioned, dollar bills are good 'quick fixes' for this on the road. Then goop some shoe goo to fill in the hole. The tire will be good as new, or maybe even better, since you now have a mini-flak-jacket on that one tiny part of the tire. Someone should just make an entire tire out of dollar bills and shoe goo sometime.
peace,
sam
peace,
sam
Bikes: Cannondale tandems: '92 Road, '97 Mtn. Mongoose 10.9 Ti, Kelly Deluxe, Tommaso Chorus, Cdale MT2000, Schwinn Deluxe Cruiser, Torker Unicycle, among others.
Quoted: 279 Post(s)
Liked 207 Times
Save those extra bits of Velox rim tape - it works great as a tire boot. The adhesive holds it in place and the material is stout enough to last a long time. Easy to carry in your repair kit and practically free! (Save the dollar bill for coffee )
Quoted: 321 Post(s)
Liked 7 Times
Is it silicone based or rubber/latex based? I was thinking of using some silicone sealant after reading this thread, but perhaps someone has tried that and found it to be a dumb idea?
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
Bikes: GT3 trike,Viper chopper, electric assist Viper chopper,Electric moped(Vespa style)
Originally Posted by 2manybikes
Have you done this and put many miles on the tire afterwards?
I live in Oz and have used Tazans Shoe glue with great success for craters left by glass, just force in as much as you can, wipe of excess and reapply if not completely filled when dry.
I tried that on my cheapass tires, and the tube sealant/cement/solvent didn't react or whatever, so the patch didn't stick.
Deported by koffee
You guys saved my tire.
I thought I was going to throw away my old tire(about 500 miles old) because of a hole in the side wall. I have tried a tire patch from the inside but didn't work, the hole was too big. After I read all the posts in this thread, I decide to try something else. I picked up the old tire from the trash can, patch it with duct tape in 2 layers. It seems like holding up pretty good even though I haven't gone out yet since I replaced it.
Cycle Year Round
Originally Posted by BostonFixed
Shoe goo:
In the US, most hardware stores carry the stuff.
Cycle Year Round
