Were do you guys get your CO2 carts?
Fat Guy in Bike Shorts!
Bikes: Specialized Allez
I am having a heck of a time trying to get 16g threaded CO2 cartridges for my inflator. I thought that I'd be able to walk into any store that sold paintball stuff and pick up a whole box for like $20, but all I can find are 12g unthreaded ones. I can use them in my inflator, but I won't get enough pressure in my road tires unless I use 16g.
My LBS has them, but I am of the mind that it's rediculous to pay what they want ($5 for a single cart there!!)
Toyota Racing Dev.
Bikes: 2004 Kona Hoss Dee-Lux
exactly haha. You should have gotten an inflator that doesn't need threaded cartridges.
Work hard, Play hard
Bikes: Cannondale super V 500, Bianchi Piaggio(hopefully getting a new road bike when I get some money)
can you use a small tank? Alot of paintball places sell small 4oz refillable co2 tanks.
Jesus, everywhere I look online is like $6.50/$8 for two cartridges. Aren't there pumps that use the non-threaded ones?
my inflator has an emergency pump on it, but it's pretty crappy. I can use unthreaded carts, but they HAVE to be 12g. I know that if I empty a 16g, I'll have the right amount of pressure in my tire. 12g is not enough, and I'd be afraid of putting too much air in with those larger tanks they sell for paintball guns.
I got the inflator because it is small and will fit in my wedge pack. I don't really have a good place to mount a frame pump, but if I can't find cheap cans of air anywhere, I may end up having to buy a frame pump anyway.
Toyota Racing Dev.
I *really* like the crank bro Mini Pump. The road morph by topeak gets rave reviews too.
DEADBEEF
Location: Catching his breath alongside a road near Seattle, WA USA
Bikes: 1999 K2 OzM, 2001 Aegis Aro Svelte
Liked 6 Times
I bought a container of 20 16g threaded cartridges for about $25 several years ago when I saw them on sale at a LBS. I have used three of those cartridges in as many years. I don't get many flats and one of those cartridges was used on a friend's bike when he got a flat.
1999 K2 OzM 2001 Aegis Aro Svelte
"Be liberal in what you accept, and conservative in what you send." -- Jon Postel, RFC1122
I was told not to use the paintball or BB gun type cartridges due to the fact they have oil in themto lube the parts and it kills the o-rings on your attachment which you wont find out until its too late.
oil? Shouldn't have oil in them. Bad o-rings on a paintball gun is very bad. Especially when you have a couple hundred psi going through the gun.
I doubt there is any difference till you get into the food grade carts.
I get them at walmart about 8.00 for 25 12g. if your careful you can use part of one.
You need a new bike
Guest
Posts: n/a
Quoted: Post(s)
Just bring your hand pump and use the 12g cartridges from Walmart. I never have issues with my wheels as long as I use both.
Pump in about 30- 40 psi, then fill the rest with your CO2 cartridge.
Koffee
Koffee
Cannondale Shill
Bikes: '06 CAAD8, SRAM Rival/Force and fixie of unknown origin
I got a bulk pack of 12g unthreaded carts from Walmart. I carry three of them in my seat wedge. A 12g cartridge should get you to 90psi, which will be enough to make it home, although I won't be riding nearly as aggressively as if I had a fully pumped 110psi tire.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
Bikes: Vision R40 - recumbent, Gunnar Crosshairs
Do a google or froogle search. You can find packs of 16g's if you want. Innovations makes a 10-pack, and I found it for $20 at one retailer very quickly:
https://64.224.10.246/product_info.ph...readed-10-pack
That's $2/fill, but less than half of the price of your LBS's 16's.
If you want to buy 50, you can get down to $1.39/fill:
https://store.botachtactical.com/in16gth.html
acciaio is real
Bikes: Yes, bicycle(s) I own!
Good post, dude. Might help other's to find the 16's at reasonable cost. For example, I had a flat Sunday and used a 12g on my rear road bike tire. It barely had 85 lbs. when I checked it after returning home. Decided I didn't want to deal with that anymore, so I went to the LBS for a 16g - almost $9. each!! No way I was going to pay that much.
Eff that crap. I should have ordered a box of the 16's a long time ago, but I've been putting it off because I rarely get flats.
BTW - Speedgoat has 16g threaded for $2.50/ea. I think that includes shipping, but call to make sure. https://www.speedgoat.com/product.asp?part=40659
Bikes: 2 many
Quoted: 1266 Post(s)
Liked 323 Times
I can fit the Crank Bro mini Pump, the full size non threaded cartridge inflator, 3 cartridges and plenty of tools into a small seat pack on my mtb. If you fill the tire part way with the hand pump first you can put whatever pressure you want in a tire with a 12g non thread cartridge. Plus you have a plan "B" if something goes wrong. Like it's below freezing and the carts don't work.
Originally Posted by 2manybikes
Good point, also....
Good advice
Bikes: 2 many
Liked 323 Times
Originally Posted by akarius
If the O-Rings are made of nitile and not of rubber oil will have absoloutley no effect on them. I imagine the O-rings in paint ball gun would be nitrile. To look at them nitrile O-rings look the same as rubber.
I don't believe there is any printed material claiming oil in the BB gun cartridges. I'm not sure. But if you put some oil in your tubes it takes a heck of a long time to do something to a tube any way.
Bikes: 2 many
Liked 323 Times
Originally Posted by samp02
Good advice
That's why I replace my inflator with a Crank Bro power pump. The way I see it if you pinch a lot you want a pump in case you run out of cartridges, if you pinch once in a while you will not mind the extra exercise of inflating a tire with a mini pump. If you need to inflate fast then you really want an Ultraflate with unthreaded cartridges.
SWS: Small Wheel Syndrome
Bikes: Bike Friday Pocket Rocket/PedalForce RS2/Specialized Rock Hopper Xtracycle/Periscope Hammerhead
Funny, just got these on ebay
Got these on ebay -- 20 pack for around 23.00 shipped
https://search.ebay.com/_W0QQfgtpZ1QQ...sassZslickum01
