Building winter bike shoes hack
Quoted: 68 Post(s)
I have an idea to build a cheaper more practical winter solution for real cold riding .
So first you will need a pair of cycle shoes . what kind you get , where you get , and how much you pay will be up to you.
You will then get some layers , i choose to use two layers of wool socks and a cheap water proof cycle shoe cover s
You will need some materials , you will need some insulating materials. , i would choose flexible stuff maybe an old coat or stuff you buy , you will also need a bottom seal . i thought to use some radiator backing or plastic , you will need two layers of this .
So you start your build by cuting the bottom seal to the shape of your shoes then pull the first socks over the shoes . to make it easier build it on your feet . use some glue to form the first layer attaching it to your sock
layer put as much as you like , but try not to make it to constricting . put the next sock layer over you r insulation layer and attach the bottom seal to the out side and inside (remove the layers carefully or start with the inside seal on the inside first)and try to make note of where your cleat holes will be , cut the cleat hole and put the waterproof layer over the socks layer and glue it as tight as you can to the cleat area leaving room for the cleat area , maybe sew the socks to the waterproof layer
You should have a real cheap solution , if you already have some old shoes laying around 😄.....
Quoted: 18372 Post(s)
Liked 4,507 Times
Do you have some photos?
Each person's winter needs are different. Here the biggest issue is WET. So, good waterproof shoes, and not that much to worry about frostbite. Uncomfortable... perhaps, but frostbite no.
I've been down to the mid twenties with my Shimano MW series shoes. And, if you're that cold, then there is less of a need for perfect waterproofing (although melting snow could be an issue for some).
Bikes: HP Velotechnik Streetmachine GTE, 2015 Devinci Silverstone SL4, 2012 Cannondale Road Tandem 2, Circe Morpheus, 2021 Rose Backroad, 2017 Devinci Hatchet
Quoted: 181 Post(s)
Liked 14 Times
How do you close your shoes with so many layers permanently over top ?
Quoted: 68 Post(s)
you just roll them down or build a zipper into the back , if you have the skills , but i have a boa dial on the top ... i could take pics once i remake them , oh and they would be perma-attached i messed up the layers will be glued to the plastic ( or ridigid material ) bottom you can then make a weather seal around the cleat hole ..
Tycho Brahe
Road Cycling
29
02-07-13 07:31 PM
