Octalink Compatible Cranksets?
Bikes: '01 Kona Caldera
I'm building up a 74' Raleigh International Frame into my first fixie. I have an unused Ultegra cartridge bearing BB that I would now like to put onto this bike. However, it has an octalink splined interface. The only fixie specific crankset that I know of is the Dura-Ace Track which costs more money than I'm willing to spend. Are there any other options or should I find a different BB and use the Ultegra somewhere else? Thanks.
I think the shortest Octalink BB is 109.5. I'm guessing you won't have a perfect chainline... well- it might be OK, but it won't be excellent.
Frankly, there are all sorts of decent cheap square taper BBs that come in every conceivable length- and will open your options.
If you insist on using your BB, you could obviously use a road crank, and whatever 130BCD chainrings you can find.
I'm a bit confused at your reference to a "fixie specific crankset" when your BB is designed for the road. Many people don't use a fixie specific crankset, or even chain...
Total Hack
Grab a used (recent) 105, ultegra, DA crankset on ebay and just pull a ring off of it.
Also, you can get new, closeout-priced DA cranksets in the $130 - $160 range and you can sell the big ring on ebay for $30. I looked at these recently and can point you to a couple of sites if you want them.
I recently got a set of octalink of DA cranks w/BB and I love them. Super smooth, light, and stiff.
Mo' Senior
Bikes: 1984 Norco Monterey SL (Ishwata 3X butted), matte black, 42-15 fixed
I think FSA's track crank (the big flat black carbon disc flying saucer thing) uses Octalink. Pretty bling. I doubt it's much, if any, cheaper than the DuraAce.
blacksheep the blemish
Bikes: 1973 Schwinn World Voyageur (manufactured by panasonic), Italvega Super Speciale (fixed, primary ride now), Kona 2004 JTS 10 spd
Without a serious help of luck you are going to have some chainline issues (already mentioned).
Bikes: https://www.jacobsbicycles.com
Without some SERIOUS help/retapping/luck, that BB isn't going into your Nottingham threaded frame.
Sorry.
Sorry.
