How do you de-grease a chain?
I got some of that "dry" chain lube stuff and the instructions say to degrease the chain first. How do I go about doing that?
mountain troll
Bikes: the hummer brand mountain bike
use "degreaser" on it... they sell it at the hardware store... don't inhale too deeply, don't get in your eyes or other orifices.
Total Hack
If you want a deep clean, follow this:
1. Remove chain and place in container.
2. Fill container with engine degreaser. You only need to fill so that it covers the top of the chain. (Found cheaply at hardware, discount, and auto stores. Shouldn't be more than a couple of dollars for a can.)
3. Let chain soak for a couple of hours or more. If possible, put the chain on top of a washer or clothes dryer for a cycle or two to knock the nasty bits loose.
4. Wash chain down with water. Get that nasty degreaser off there.
5. Put chain back on fixie (or SS).
6. Lube.
6. Lube.
Iguana Subsystem
sheldon sez "drop the chain into a plastic Coke bottle with a couple of ounces of un-diluted citrus degreaser, cap it, and shake thoroughly. Fish the chain out with a spoke, rinse in water, and you are all set! (I am told that Pepsi bottles also work, and are easier to remove the chain from, because they have a wider mouth...but I'm a Coke guy, not a Pepsi guy.)"
SuperstitiousHyperrealist
Bikes: unknown road conversion, half built Benotto track
I posted this in a thread a while back. This is the best way to clean a chain as far as I know:
1) Remove chain
2) Place chain in two liter bottle
3) Pour about 1/4 to 1/2 cup of degreaser in the bottle(it is important to note that the chain need not be totally immersed in degreaser)
4) Put cap on bottle and shake for about a minute and let it sit for a few minutes
5) Repeat step 4 as many times as you wish, I only do it twice
6) Use a screwdriver or other long thin object to remove the chain from the bottle(much harder than it sounds. Most of the time I just end up cutting the bottle open)
7) Run the chain under extremely hot water for a minute or so
8) Try to shake off/wipe off as much excess water as possible let sit until dry
9) Place chain on bike and lube
1) Remove chain
無くなった
Bikes: I built the Bianchi track bike back up today.
Wasn't someone suggesting putting a string through one side of the chain and running it out of the 2 liter so it was even easier to get the chain out in that last thread?
Frankly, Mr. Shankly
LV 99 9999HP/9999MP
Bikes: crappy fake bike
1) Remove chain
1) Remove chain
Bikes: Specialized Langster and saving for dream bike Specialized Roubiax.
A simple technique that I use is to spray some wd-40 into a wrag. Put your hand on the chain and move the pedals around so that the chain goes around a couple times. Then after that is said and done I take a clean rag and do the same thing, then I put the lube on.
Originally Posted by absntr
WD-40 isn't a degreaser though. And it's not good for your chain. Essentially, you're adding a cheap all-purpose grease and then putting another lubricant on top. That's double muck and will attrack all sorts of nasty gunk. Say no to WD-40!
Not Badass, it's Tim.
Bikes: NJS Peloton, 2002 fuji track, 2002 fuji league (MIA), 2005 bianchi pista, Chopper from NoName Customs.
I've been working with it in the Lab at my school on chains for about 2 months now and at my work.
LF for the accentdeprived
WD-40 does dissolve grease and stuff pretty well. I use it on my cogs. But all the guys here are talking about cleaning the chain fully, first and foremost, inside to get those nasty quartz crystals out. For that, you do have to soak the thing in something, not just rub it nice and shiny.
Originally Posted by BadAssBiker
ahhh a WD-40 expert.
Wher'd u Get That Jacket?
Bikes: Calfee Dragonfly, Lemond Poprad, Airborne Manhatten Project, Calfee Luna Fixie
6. Lube.
6. Lube.
dc pirate, 4evah.
Bikes: several. blue. fun.
or, there's the once-a-week quickie method.
1. Buy Simple Green towels (disposable, biodegradable towels pre-soaked in the stuff)
2. Hold one around chain, crank slowly.
3. Be careful not to get hand/towel cranked into cog/chainring (ouch!)
