Upgrading from Shimano Alivio -> LX
Bikes: Trek Bruiser 2
Right now I have a 8-speed Alivio on my brusier and I want smoother shifting, so I thought about the better derailluers. Will it fit on my bike? Or will it not because of my shifters, or do I need a bigger cassette? What should I do?
Thanks in Advance.
Thanks in Advance.
Bikes: '03 Fuji Roubaix Pro; '03 KleinGi Attitude; '06 Soma Rush; '04 Surly Cross-Check; '06 Soma Rush; '07 Scott CR1 / Chorus
The derailleur won't care how many gears it's shifting.
Whether the upgraded derailleur will make a significant difference is another question!
Bikes: 2004 GT-Idrive 3.0
As long as the derailer has more possible gears (or equal) as your shifters do, your ok.
Most say 8 or 9 gears, or 7 or 8.
I might be wrong (probably am) but i thought the new LX series was just a new name for the cheaper series. You should probably go for xt atleast. Just order my XT upgraded from either alivio or deore, i forget.
LSU Alum
Bikes: 2006 Trek 2100D - 2005 Giant NRS - 2004.5 Giant Suede
LX is one step above the Deore and is the first level of "Race" level components, LX, XT and then XTR. It is a very nice product. I love mine on my NRS.
Bikes: Trek 4300 X 2. Trek 1000, Trek 6000
You aren't going to notice improved shifting going from Alivio to LX unless: the Alvio is misadjusted or worn out.
It doesn't matter how many 'speeds' the derailleur is asked to shift, so long as it's range of motion (the travel between it's limits) can cover all the gears.
A new, more expensive derailleur is often not the ticket to better shifting. Spend some time to setup and adjust your current system before spending unnecessary money. https://www.parktool.com/repair_help/FAQrindx.shtml
Why Be Normal?
Bikes: 2005 Trek 4300
The more accurate answer is rear derailleurs are designed to move from big to small cassette cogs and remove slack from the chain while doing so. all 9 sp compatible derailleurs will work with lower systems (ie 7 and 8 sp). 8 sp derailleurs will also work with 9 sp systems but cannot remove as much chain slack as 9 sp derailleurs. 8 sp systems and early 9 sp systems can remove up to 39 teeth worth of slack while current Mega 9 derailleurs can remove 43 Teeth worth of slack. to determine how many teeth worth of slack needs to be removed 1) add # teeth on small chain ring + # teeth on small cassette cog 2) add # teeth on large chain ring + # teeth on large cassette cog 3) subtract #1 from #2 and thats the number of teeth your rear derailleur will need to remove. Current Mega 9 systems have 43 teeth of slack (44+32)-(22+11) = 76 - 33 = 43 teeth. I hope that helps...
wow, extra information. So i shouldn't upgrade, won't do much for my Alivio. Right?
Originally Posted by Stubacca
Bulldust.
LSU Alum
You will notice a difference but only if you change the shifters to LX as well as the Derailleur.
I drink your MILKSHAKE
Bikes: 2003 Specialized Rockhopper FSR Comp, 1999 Specialized Hardrock Comp FS, 1971 Schwinn Varsity
The only difference here is range of motion. You can get an 8 speed derailier to shift a nine speed system perfectly as the cassette wdth is exactly the same.
It isn't about chain slack or anything else because that's determined by cage length not how many speeds it was designed for. They had 11 and 34 tooth cogs on 7 speed cassettes and they had 44 and 22 tooth triples way back when as well
Originally Posted by BlkHawkDown
Thnx .
I will break you of this habit
In regards to the question the SHIFTERS will play a bigger role in smoothness and precision than the derailieurs.
Originally Posted by Raiyn
[color=blue]
Should I buy different shifters?
Why Be Normal?
Actually that's highly technical bunk in regards to this conversation.
To be honest, when I had that exact question this is the information that gave me the confidence to step outside the marketing hype and use logic to figure out what would work. I almost take that as a compliment Raiyn, who'd have thought that knowing as little as I know about this stuff I'd be asked to dumb down my answers.
I didn't realize basic math now qualifies as "highly technical".
It's also a moot point as the 8 Speed Alivio shifts 9 just fine. (Though that's not what he's asking)
I'm not sure why you think all the math helped you as it's the range of lateral motion that's important here, not the chain wrap.
Perhaps I should have said "needlessly wordy"?
If I were you I'd just get them properly set up. Alivio stuff should work fine. Make sure your cable moves freely, mech hanger is straight, nothing covered with crap. Don't bother upgrading (yet)
Bulldust (to qoute Stubacca). I have LX on my brand new NRS properly adjusted and setup. My brother-in-law has Deore on his brand new Cannondale properly adjusted and setup and we BOTH notice a big difference between LX and just regular Deore.
There's more difference between the NRS and the Cannondale shifting than just the derailleur. As you rightly point out, the OP will only really notice a difference if he upgrades the shifters as well, which will mean buying new cassette and chain too if he's upgrading to 9 speed. At which point you're better off upgrading to SRAM X.7 triggers and derailleurs IMHO.
The bruiser is a free ride bike. Why are you upgrading components like those?
It would be like an XC rider getting a QR 20 wheelset.
This is certainly true. I was merely answering the question.
I suggest he save up for a better fork or some other such free riding component.
