Weird lactic acid thingy
I am 18 years old and my max heart rate is just under 200. I can get up to 90%, give or take, and sustain it for the majority of a race (my races are like 35 minutes or so). I can also get up to around 95% of my max for shorter amounts of time (3 or 4 minutes) before having to ease off or blowing up. When i sprint, i normally come withing 2 or 3 beats of that tested max heart rate. Now, here's the thing. When i sprint or do these super hard efforts that get my heart rate so high, i almost never feel any lactic acid. My legs will fatigue and tire out, or i will blow up and not be able to keep going, and i can push myself to throwing up with ease (i normally don't for obvious reasons, but i can normally do so in a sprint at the end of a race or something if need be) but i never get any form of burn that is associated with lactic acid production and aneroabic exercise. I'll be the first to admit that i don't know much about lactic acid production from a sports point of view (i know some about it on a celluelar level from bio.), so i was wondering, without having an actual LT test, does it sound like i have a naturally high lactic acid tolerance, or do different people have different reactions to lactic acid, or am i so out of shape that i actually give out and get sick before reaching my LT? I know an LT test is the only way to actually determine this, and one day, i will probablly have that and a VO2 max test done, but i was just wondering af any of the more knowledgeable people on this board had any input based on what i describe. thanks
Guest
Posts: n/a
Quoted: Post(s)
If you could maintain 90% of your heart rate max for 35 minutes and 95% for 3 too 4 minutes, I would suggest you go out for a team on the Tour de France.
Who tested you?
If your legs are fatiguing and tiring out, that's lactic acid. If you're blowing up, that's lactic acid.
I would say that you need to find a professional lab where you can get professionally tested so you can find out what your lactate threshold is for real. It sounds like you're serious about it, but if you're training at too low a heart rate, you won't be able to really be effective during your races.
Koffee
Who tested you?
Koffee
my PT/team mate did the test. Let me say though, my performances at those levels are not too impressive. My power output is very weak relative to most riders at that level. i would be happy to describe the test if you think that would help. Also, i guess that just means that different people have different responses to lactic acid, and that's probablly the cause for the lack of burning (assuming the test got accurate results), right?
Guest
Posts: n/a
Quoted: Post(s)
If your personal trainer did the test, what methodology did he use? My thoughts are that it's WAAAAAAY off.
I posted a 2 X 20 anaerobic threshold test, but I would still say it's better to be tested... let them take blood from you and monitor heart rate as they increase workload over time. Now that's accurate.
The more off you are, the less accurately you're able to train, and when you race, you'll never be at optimal training.
Koffee
Koffee
well, the test started with my bike on a fluid trainer with a fan. We hooked up a powertap to the rear so we could see my cadence, wattage, and speed. We started off at 10 mph in whatever gear i chose at whatever cadence i chose. I kept it at that rate for 2 minutes, and then increased my speed 2 mph. i continued to make these increases at the 2 minute/2 mile per hour interval for as long as possible, keeping my speed constant for those two minutes. When i felt i could no longer sustain the speed for two minutes based on my legs giving out and getting that light headed tingly feeling, i got out of the saddle, shifted down 2 gears or so, and sprinted for 15 to 20 seconds. Like i said i got sick afterwards, so i am confident that i pushed my self as hard as i possibly could. The test was supposed to get my max attainable heart rate, and the training schedule was based off of that. I am headed to a college with a med school next year, so i was wondering if any of them offer this sort of testing and how much it usually costs.
Bikes: Guru Geneo, Specialized Roubaix Pro, Guru chron 'alu, Specialized Sequoia
Who tested you?
Koffee
Who tested you?
Koffee
Guest
Posts: n/a
Quoted: Post(s)
Perhaps for a 10k time trial for a few minutes, but not for 35 continuous minutes....
What dood did describe sounds like a 2 X 20 anaerobic threshold test with a powertap attached to the wheel.
Get to a performance lab. Let them do the test. Without a lactate test, how do you know when you've gotten to your lactate threshold? Estimation just doesn't do one justice if they plan to race.
Koffee
Koffee
bzzzz
I also see nothing wrong with those numbers. I did a 1 hr race last weekend and my average heart rate was 90% of my maximum. The important factor is the power your putting out at that effort. TDF=400+watts (i'm guessing)
Average Joe=200-300 watts (still guessing)
Heart rate alone is insignificant.
climber has-been
Quoted: 3432 Post(s)
Liked 3,567 Times
"At least in theory, the most precise way of determining an athlete's power at LT would be to rely on laboratory-based testing with invasive blood sampling. Very few individuals, however, have access to such measurements on a routine basis. Furthermore, while LT is often defined by sports scientists as the initial non-linear increase in lactate with increasing exercise intensity, this intensity tends to be significantly below that which coaches and athletes tend to associate, on the basis of practical experience, with the concept of a "threshold" exercise intensity. Thus, probably the easiest and most direct way of estimating a rider's functional threshold power is to simply rely on data collected in the field using a power meter."
https://www.cyclingpeakssoftware.com/levels.html
Threshold power: what is it, why is it important, and how do I measure it?
https://www.cyclingpeakssoftware.com/threshold.html
bzzzz
This 2x20 test seems more like a "functional threshold" test, as the results would likely be way higher than blood test results. It may be better to base training zones on "functional threshold" rather than max heart rate (when using a heart rate monitor to gauge intensity) because FT will vary depending on fitness throughout the year, and it is important to adjust training zones accordingly.
