Onguard Bulldog Mini U-Lock vs. Onguard Pitbull Mini U-Lock
Proud To Be An American
Bikes: 2004 Giant Cypress SX 2006 Giant OCR 3
Q: What is the difference between the Onguard Bulldog mini u-lock and the Onguard Pitbull mini u-lock?
Hazardous biker
Bikes: 2005 Santa Cruz Blur Classic
I think the difference is the security rating. Check their website,
Ricardo
Ricardo
Yes, the security rating is different. The reason is the Pitbull has a heavier lock bar. In reality however, someone cannot fit a jack inside the U-Lock to break the lockbar because it is a mini, so they need to cut the lock, and no one is going to cut the heavy lock bar when they can cut through the shackle which is the same size on either the Pitbull or the Bulldog.
Get the Bulldog, it's lighter and still requires a powertool to break open.
Bikes: 2006 Specialized S-Works Tricross
And about a 1/2 lb. of weight. I chose the lighter of the two. I figure anyone prepared to break a U-Lock is prepared to break any U-lock so why carry more weight than is useful.
Quoted: 170 Post(s)
Liked 156 Times
Hey all: I was all set to buy one of these as their weight and strength are rated very high. HOWEVER I started thinking about what they can lock onto. Their size is 3.5 x 5.5. I made one out of paper(I know, it will deter many would be thieves) and tried to see what I could attach it to. Not much. A sign pole at best. Now if I'm a thief I'm cutting the sign post and grabbing the bike. The larger ones might be the best bet. I'm going to look at them at lunch. Does anyone know if the minis can wrap around the thicker bike racks???
When using a mini u-lock, Sheldon Brown's lock stategy works the best.
https://sheldonbrown.com/lock-strategy.html
Bikes: Dahon Boardwalk 7
Originally Posted by Ziemas
But you need to find something to lock the bike to. What do you plan to anchor to with such a small shackle? A traffic sign? Those often pull right out of the ground.
The point is the typical thief will choose the path of least resistance and take the bike that's the easiest/fastest to steal.
Quoted: 170 Post(s)
Liked 156 Times
But you need to find something to lock the bike to. What do you plan to anchor to with such a small shackle? A traffic sign? Those often pull right out of the ground. This is why I use a chain. I can always find something to lock up to with very little hassle. In most cases I would be SOL with a mini U-Lock.
Originally Posted by balto charlie
That makes a lot of sense. I'll buy the little one. Thanks
Originally Posted by rgilmore
I don't know about other states but in Maryland the signpost/pole is supposed to be a minimum of 3 feet in the ground - it will take a good hydraulic system to pull one out. I doubt if our specs are much out of line with other places.
Road signage, on the otherhand, even if anchored well one can remove the sign from the top and slip the bike - lock and all - over the top. Heard of it happening.
A parking meter works well.
Parking meters are everywhere in the big city. There are also many solid railings, fences, and such to lock a bike to.
