Can't lose weight
Can't lose weight
Was kinda hoping to drop a few pounds riding my bike. I am only riding 30 miles/day but still thought I would drop some weight. I have been riding for 4 months. got on the scales and have not lost any weight. Oh well
Have you changed your diet at all? Even still, you should be seeing some kind of changes i.e. more muscle and maybe your clothes fit better. Scale weight is deceptive. Try going by inches.
Pete
https://www.viovio.com/anthropete
Pete
Pete
Pete
Also, reducing calories is a must to lose weight. There is really no way around the need to burn more calories than you take in to lose weight.
BOATS AND HOES!
Bikes: Madone
Start measuring your food/calorie intake and I guarantee you'll have results. Guessing how much to eat is not a great way to go about losing weight. When I want to shed pounds, I use a diet program that counts my calories. There are many out there to choose from, the one I use is from healthtech found HERE. It can usually be found on ebay for a fraction of the price healthtech sells it for.
It still amazes me how much of a calorie deficit you need to lose weight. For me, eating 1600 calories a day to lose a pound a week peaty much means I'll be hungry all day. I just accept that as what I have to do to lose weight.
A good website with some great tips on losing weight.
https://www.fatlosstips.com/
Elitist Jackass
Bikes: Cannondale 2.8, Specialized S-works E5 road, GT Talera
1. burn more than you eat and you lose, eat more than you burn and you gain.
2. There is a 15 billion dollar industy devoted to find shortcuts to this, but we are still the fattest country in the world.
3. See number 1.
3. See number 1.
Elitist Jackass
Now riding at lower intensity will burn more fat, higher intensity will burn more glycogen (sugar) but if you burn more calories than you eat, you will lose weight.
Keep riding your 30 miles a day, try and eat no more than what you ate before you started riding. Or if you can, cut back a bit from that.
Note, its simple, I didn't say its easy.
Quoted: 104 Post(s)
Liked 5 Times
I agree that the key to losing weight is to eat less.
Ca-na-da?
Bikes: none at the moment
Low hr, slow paced long rides will shed the pounds, try 50 or 60 miles (or what ever works out to be 3-4hours long), keep your heart rate pretty low though. Maybe go to a fitness / nutrition center to find out your optimal fat burning HR zone and get a hr monitor. And also have them asses your diet. I made a couple of switch's in mine that really helped out (my gf is a nutritionist), veggie hot dogs(taste exactly the same only no fat), whole wheat breads and buns(so it's not just empty calories). Fat free yogourt instead of ice cream. Lots, LOTS of water. Special K cereal bars for snacks instead of chocolate bars. I eat some raw spinach every now and then aswell. Turn off the deep frier and bake or barbecue. And even read the labels at the corner store, some products that might taste close might be very different in terms of nutritional content.
well you get the ideal... gl...
btw, i've droppped 17 lbs since march, and i'm not really trying, i just wanted to lead a healthier life, the fat just kinda diasapeared as a result.
Bikes: 2008 Cervelo RS, 2011 Scott CR1 Elite, 2014 Volagi Liscio
I've lost ten pounds in about 5 months. I used to be and still am a runner, but now I cycle on the weekends. Since I can last a lot longer on the bike than running, I think that, overall, I burn more calories. Another important factor is that I've changed my diet slightly - I try not to stuff myself at dinner and I don't snack after 8 pm.
Keep it up. 30 miles/day sounds like a good program.
BOATS AND HOES!
Bikes: Madone
Read on.
So why then do so many fitness and health experts recommend walking for weight loss? One reason is that people don't want to hear that they have to work hard so they figure some activity is better than none. Another reason is that the body burns more fat for fuel when exercising at an easy pace, however, the total amount of energy used is so small that you end up burning off little body fat. That's also why when you choose the "fat burning" program on your treadmill or bike it has you exercise at any easy level. Yes, you're burning fat, but so little that you'd have to exercise at that easy pace for hours and hours each day.
Stercus accidit
Bikes: Trek Pilot 2.1
Originally Posted by johnny99
Lower intensity does not burn more fat! Lower intensity burns a higher percentage of fat compared to carbs, but since you're burning fewer calories than at higher intensity, your total fat burn is lower. I'm not sure how fast you are riding, but you should raise your intensity at least into the aerobic level. Very high intensity levels are great for your fitness, but they can make you feel more hungry (if you have a weak will) and they can make recovery more difficult (if you ride hard every day).
I'm not sure how true it is, but I've read that for the first 20 minutes of exercise in the aerobic zone, you will burn 20% fat and 80% carbs. From 20 minutes to 40 minutes, you'll burn 50% fat and 50% carbs. After 40 minutes, you'll burn 80% fat and 20% carbs. All of this makes sense, but I'm not sure how accurate the numbers are. You actually burn fat most efficiently through aerobic exercise if you do it long enough. Sooner or later you have to burn up all the available carbs.
Ca-na-da?
i imagine that's why variety is a good part to any excersize program, long "easy" ride, still keeping your hr around 65% max(so you should break a sweat). Then mix in some shorter moderate inensity rides with a strong steady pace. And finaly hilly days are great cause they're like "off" .."on"..."off" ..."on" high intensity days.
Stercus accidit
King of the Forest
Eat well before your ride.
Keep hydrated.
Outside of riding - avoid all snacks. If you must, eat a pickle.
Reduce the amount of meat you eat (fish and pork are better than beef). Replace with greens. No butter or salad dressings.
Eat your main meal in the middle of the day, so you have energy for the day.
Eat a small dinner.
Avoid breads, chips, french fries, and other fatty foods.
Fresh fruit and vegetables are okay.
Keep hydrated.
Eat a small dinner.
Bikes: Trek 7000 and a Trek 1200
As studies have started so surface on the subject of intensity of exersise how hard you ride is very important for many reasons.
Bikes: Road, MTB, Folding, Commuting bikes...
True, but that's not the whole story....
Read on.
https://menshealth.about.com/cs/fitness/a/walking.htm
"So why then do so many fitness and health experts recommend walking for weight loss? One reason is that people don't want to hear that they have to work hard so they figure some activity is better than none."
Read on.
That doesn't mean athletes will lose weight if they ditch their training program and start walking instead
I say watch what you're eating and most importantly watch how you're training. Get a HRM and don't pay any attention to it the first few times you're out doing your thing - then compare what you're actually doing to what you're supposed to be doing in terms of staying in your appropriate zones and adjust. I think you're in for a pleasant surprise. Finally, as others have said; you might be gaining muscle which weighs much more than fat does. Perhaps get yourself a scale that measures body fat. They're not very accurate but it'll at least show you if you're getting fatter or leaner with the same weight.
BOATS AND HOES!
Bikes: Madone
Originally Posted by dfw
Try eating 5 small meals rather than 3 larger ones and stop eating 3 hours before you go to bed. Divide your 1600 calories into 320 calorie meals (or 300 this one, 340 the next, etc). This pretty much means you'll be eating every 2-3 hours. You're not as likely to get hungry during the day, but if you do get hungry, you're not that far away from your next meal. You will be hungry before you go to bed, but you shouldn't be eating before bedtime anyway.
Originally Posted by Bontrager
If someone is sedentary and they start a walking program then they're exercising more therefore they'll lose weight.
King of the Forest
I find that eating a 300 calorie meal only satisfies my hunger for about 15 minutes.
Stercus accidit
I'm already eating 6 small meals a day. I'm also eating nutrient dense food as opposed to calorie dense foods. I find that eating a 300 calorie meal only satisfies my hunger for about 15 minutes.
Eating 5 or 6 meals per day is a very good strategy because it keeps your metabolism higher than eating more less often.
troutbum
Bikes: Trek 1000
Is that 30 miles a day once a month? 4 months of 30 miles a day?! and zero wieght lost? You should go see a Dr. and get the bad news out of the way.
Stercus accidit
Lance Armstrong consumed on average 10,000 calories per day during the TdF and still lost weight. Use that for inspiration.
Ca-na-da?
i was waitting for someone to pull that out, the average trainning cyclist burns 5000 cals a day, according to the american olympic trainning center, i think only wrestlers burnt more.
