Rear brake sticks when handlebar turns!
I had a flat on my rear tire. I took the wheel off, put a new tube in and replaced the wheel. I re-hooked the noodle in my rear brake, which is a "direct-pull" type and everything seemed OK. However, I noticed that if I spin my rear wheel and then turn my handlebar to the left to an acute angle, the wheel stops spinning immediately, seemingly due to the brake coming into contact the rim. Is this a typical issue? Would I have to adjust the brake to fix it?
Thanks in advance.
PS. The bike is a Trek 7300FX and the brakes are the Shimano "direct-pull" type as I have mentioned above.
Thanks in advance.
Bikes: Gilmour road, Curtlo road; both steel (of course)
Quoted: 273 Post(s)
Liked 10 Times
The brake cable is being pulled tight when the bar is turned. If it did not do this before your flat fix you must have not replaced everything correctly.
Check that all cable housing ends are properly seated in their stops and that the cable end is properly seated in the brake lever.
Today, I believe my jurisdiction ends here...
Quoted: 273 Post(s)
Liked 10 Times
Don't you just hate it when those cables and housing spontaneously shorten themselves for no apparent reason?!
Thanks for the responses. I *think* it was OK before I put the wheel back in. I was trying to get the "noodle" back in and had a h*ll of a time getting it in place. I think I may have pulled something too hard doing this. The odd part is that the brake engages when the bar turns left - which I thought should have actually increased the cable slack rather than pull it taut.
Once again, thanks for the feedback. I'll check whether the cable ends sit properly in the cable stops.
