Tink, tink, tink in my bars/stem??
I have this issue of hearing a little tink noise when I press or pull on my road bike handlebars. Is it my threadless stem? It only happens when riding, the bike shop cant find the noise when they ride it? Its there, and it bothers me. Its not loud, just a little noise, when pressure is applied. Just started happening. This Bianchi is only 11/2 old and 1500 miles. Any ideas.
What you're hearing is probably a bit of squeak. Grease the threads on the stem bolts [front and back] and tighten them. This is common with aluminum stems/bars.
You can catch more flies with honey than with vinegar. That's great...if you want to attract vermin.
put me back on my bike
Bikes: Airbourne Carpe Diem + own brand fixed gear
I get this A LOT on my bike that has a quill stem with adjustable head angle. It has 2 screws on the clamp around the bars and anotherone holding the adjusted angle in place. I've tightened everything up to max torque and its still there.
I think its a mixture of metals thing.
I've always had this problem on this particular bike. change of stem and change of bars has changed it to a greater or lesser degree, but its never cured it.
Its definitely the bars/stem clamp. Very annoying, but I can't cure it.
Stew
Stew
The older I get the better I used to be.
Life is good
Bikes: 2018 Lynskey Helix Pro
I have a similar problem with my threadless stem.
Every so often when I hit a bump (like crossing RR tracks) I hear a tinkle sound from the stem area. Sounds kinda like a bell on a kids tricycle.
My LBS checked it out said everything was tight.
They said it was probably the spacers clinking together when I hit the bump. They didn't want to make it any tighter. It could cause bigger problems with steering.
Its been doing this for over a year so I just ignore it.
riding a Pinarello Prince
Bikes: Pinarello, Prince and an FP5
the threadless stem has three major part, the Bolt. the spring and the wide washer, when installing the handle bar, place the major part, in this order, the the wide washer, the spring then tighten the bolts, I can assure you the noise will disappear...
"Racso", the well oiled machine;)
If it were me, I would take all of the bolts out of the stem and grease the sides and shoulders of their heads, the full lengths of their shafts, the wedge itself (if a quill stem), and under the rim of the quill cap if so equipped. Basically, if it's not a weld, grease it all over.
A drop of TriFlow between the bar and the stem may silence a noise there, also, but make sure it isn't going to slip as a result.
If it's a threadless stem and headset, I'd do likewise with the entire stack of headset parts. Anything that touches something else has the potential to shift and make noise, including the spacers, the bearing cartridges (if so equipped), the stem on the steer tube, and even the cap where its rim touches the stem. I wouldn't get carried away; it only needs a slight film of grease to provide some lubricity.
A drop of TriFlow between the bar and the stem may silence a noise there, also, but make sure it isn't going to slip as a result.If it's a threadless stem and headset, I'd do likewise with the entire stack of headset parts. Anything that touches something else has the potential to shift and make noise, including the spacers, the bearing cartridges (if so equipped), the stem on the steer tube, and even the cap where its rim touches the stem. I wouldn't get carried away; it only needs a slight film of grease to provide some lubricity.
Originally posted by nikos
Are you saying that the set up is wrong?
Yo
Bikes: 2003 Yeti AS-R, 2018 Waltly ti
Sounds drive me whacko too, so I've spent alot of time tracing them down. You would be surprised how a sound can resonate from some other part of your bike. Start tightening things around the area you think it's coming from, and keep going from there. You'll find it eventually. Or just do like me and ride with people who finally convince me that I'm just being anal and forget about it.
